plaidstallion 9 Posted January 15, 2021 Posted January 15, 2021 (edited) This was working for a bit but seems to have stopped working again today. Edit: It seems to work when I invoke the task manually but not when new items are scanned into the library. Edited January 15, 2021 by plaidstallion
dcol 177 Posted January 15, 2021 Posted January 15, 2021 Not working here as well and doing it manually isn't working either.
radeon 760 Posted January 19, 2021 Posted January 19, 2021 Run into the same issue with youtube changing again, I'll release a fix soon.
plaidstallion 9 Posted February 6, 2021 Posted February 6, 2021 Will you announce here when the update is available?
dcol 177 Posted February 6, 2021 Posted February 6, 2021 How long will this one last? Can't more permanent changes be made? MCM doesn't seem to have this issue.
radeon 760 Posted February 6, 2021 Posted February 6, 2021 3 hours ago, dcol said: How long will this one last? Can't more permanent changes be made? MCM doesn't seem to have this issue. How long is a piece of string. No idea. It's dependent on YouTube not changing things. Sounds like you're already using something else any way?
dcol 177 Posted February 6, 2021 Posted February 6, 2021 I use Media Center Master and it works but is mostly manual downloading trailers. It also pulls in iTunes trailers if they exist. Will ytrailers go get the trailers of movies that already have been added to the library, or do I have to scan the library to pick them up?
ebr 16346 Posted February 6, 2021 Posted February 6, 2021 4 hours ago, dcol said: How long will this one last? Can't more permanent changes be made? MCM doesn't seem to have this issue. You realize Google (YT) is doing this most likely on purpose for the very purpose of breaking things like this, right?
dcol 177 Posted February 6, 2021 Posted February 6, 2021 40 minutes ago, ebr said: You realize Google (YT) is doing this most likely on purpose for the very purpose of breaking things like this, right? Hasn't broke MCM and there hasn't been an update to that program in a long time.
plaidstallion 9 Posted February 11, 2021 Posted February 11, 2021 (edited) My youtube-dl instance running in a docker container works fine also and even a simple little bash script I improved on functions technically. TinyMediaManager sometimes has problems with youtube but can pull from some other sources instead. This plugin (when it works) is more consistent and of course automated though. ...Plus money was paid for this. Also, thanks for the update. Testing now. Edited February 11, 2021 by plaidstallion
roaku 842 Posted February 11, 2021 Posted February 11, 2021 (edited) 24 minutes ago, plaidstallion said: My youtube-dl instance running in a docker container works fine also and even a simple little bash script I improved on functions technically. This plugin (when it works) is more consistent and of course automated though. ...Plus money was paid for this. youtube-dl is updated regularly because older versions break for the same reason being discussed here. https://stackoverflow.com/questions/63816790/youtube-dl-error-youtube-said-unable-to-extract-video-data Edited February 11, 2021 by roaku
plaidstallion 9 Posted February 11, 2021 Posted February 11, 2021 (edited) 30 minutes ago, roaku said: youtube-dl is updated regularly because older versions break for the same reason being discussed here. https://stackoverflow.com/questions/63816790/youtube-dl-error-youtube-said-unable-to-extract-video-data Fair enough. Tinymediamanager stays functional most of the time too though. All of the other things mentioned are free... Edited February 11, 2021 by plaidstallion
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 On 2/6/2021 at 4:25 PM, radeon said: 1.6.6.4 is just up now. I dropped the new dll in the plugin folder last night and restarted my docker container. No go with automatic pulls or by manually activating the task.
CBers 7558 Posted February 12, 2021 Posted February 12, 2021 23 minutes ago, plaidstallion said: I dropped the new dll in the plugin folder last night and restarted my docker container. No go with automatic pulls or by manually activating the task. Any errors in the server log?
dcol 177 Posted February 12, 2021 Posted February 12, 2021 Ytrailers is erroring all over the place once again. Here is an example.This plugin is useless. Works for a day or so when an update comes in then errors. I am going to remove it for good this time. And don't use the excuse that YT changes things, because my other downloaders have no issues. Obviously the method of getting the trailer is wrong. 2021-02-12 09:09:20.493 Error App: YTrailers - Error *** Error Report *** Version: 4.6.0.22 Command line: N:\Emby\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.17763 Framework: .NET Core 3.1.11 OS/Process: x64/x64 Runtime: N:/Emby/system/System.Private.CoreLib.dll Processor count: 16 Data path: N:\Emby\programdata Application path: N:\Emby\system System.MissingMethodException: System.MissingMethodException: Method not found: 'MediaBrowser.Model.Entities.MediaUrl[] MediaBrowser.Controller.Entities.BaseItem.get_RemoteTrailers()'. at YTrailers.Search.YouTubeSearch.Search(BaseItem item, CancellationToken cancellationToken) at System.Runtime.CompilerServices.AsyncMethodBuilderCore.Start[TStateMachine](TStateMachine& stateMachine) at YTrailers.Search.YouTubeSearch.Search(BaseItem item, CancellationToken cancellationToken) at YTrailers.Search.LocalYTrailersVideoDownloader.GetYTrailerVideoUrl(BaseItem item, CancellationToken cancellationToken) at YTrailers.Search.LocalYTrailersVideoDownloader.DownloadYTrailerForItem(BaseItem item, CancellationToken cancellationToken, ILibraryManager libraryManager) Source: test TargetSite: Void MoveNext()
CBers 7558 Posted February 12, 2021 Posted February 12, 2021 6 minutes ago, dcol said: Ytrailers is erroring all over the place once again. Here is an example.This plugin is useless. Works for a day or so when an update comes in then errors. I am going to remove it for good this time. And don't use the excuse that YT changes things, because my other downloaders have no issues. Obviously the method of getting the trailer is wrong. 2021-02-12 09:09:20.493 Error App: YTrailers - Error *** Error Report *** Version: 4.6.0.22 Command line: N:\Emby\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.17763 Framework: .NET Core 3.1.11 OS/Process: x64/x64 Runtime: N:/Emby/system/System.Private.CoreLib.dll Processor count: 16 Data path: N:\Emby\programdata Application path: N:\Emby\system System.MissingMethodException: System.MissingMethodException: Method not found: 'MediaBrowser.Model.Entities.MediaUrl[] MediaBrowser.Controller.Entities.BaseItem.get_RemoteTrailers()'. at YTrailers.Search.YouTubeSearch.Search(BaseItem item, CancellationToken cancellationToken) at System.Runtime.CompilerServices.AsyncMethodBuilderCore.Start[TStateMachine](TStateMachine& stateMachine) at YTrailers.Search.YouTubeSearch.Search(BaseItem item, CancellationToken cancellationToken) at YTrailers.Search.LocalYTrailersVideoDownloader.GetYTrailerVideoUrl(BaseItem item, CancellationToken cancellationToken) at YTrailers.Search.LocalYTrailersVideoDownloader.DownloadYTrailerForItem(BaseItem item, CancellationToken cancellationToken, ILibraryManager libraryManager) Source: test TargetSite: Void MoveNext() Are you running Emby server Beta, or Stable? @radeon 1
roaku 842 Posted February 12, 2021 Posted February 12, 2021 18 minutes ago, dcol said: Ytrailers is erroring all over the place once again. Here is an example.This plugin is useless. Works for a day or so when an update comes in then errors. I am going to remove it for good this time. And don't use the excuse that YT changes things, because my other downloaders have no issues. Obviously the method of getting the trailer is wrong. 2021-02-12 09:09:20.493 Error App: YTrailers - Error *** Error Report *** Version: 4.6.0.22 Command line: N:\Emby\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.17763 Framework: .NET Core 3.1.11 OS/Process: x64/x64 Runtime: N:/Emby/system/System.Private.CoreLib.dll Processor count: 16 Data path: N:\Emby\programdata Application path: N:\Emby\system System.MissingMethodException: System.MissingMethodException: Method not found: 'MediaBrowser.Model.Entities.MediaUrl[] MediaBrowser.Controller.Entities.BaseItem.get_RemoteTrailers()'. at YTrailers.Search.YouTubeSearch.Search(BaseItem item, CancellationToken cancellationToken) at System.Runtime.CompilerServices.AsyncMethodBuilderCore.Start[TStateMachine](TStateMachine& stateMachine) at YTrailers.Search.YouTubeSearch.Search(BaseItem item, CancellationToken cancellationToken) at YTrailers.Search.LocalYTrailersVideoDownloader.GetYTrailerVideoUrl(BaseItem item, CancellationToken cancellationToken) at YTrailers.Search.LocalYTrailersVideoDownloader.DownloadYTrailerForItem(BaseItem item, CancellationToken cancellationToken, ILibraryManager libraryManager) Source: test TargetSite: Void MoveNext() It looks like you're seeing this error because you're running a non-release version of Emby that's made breaking API changes. 1
dcol 177 Posted February 12, 2021 Posted February 12, 2021 Had the same release when ytrailers was updated and working for a few days.
CBers 7558 Posted February 12, 2021 Posted February 12, 2021 27 minutes ago, dcol said: 4.6.0.22 beta I think @radeon and other plugin developers, tend to target the Stable releases, as the beta servers can easily break things. Hopefully this is a simple fix, as it seems to be Emby related rather than YouTube, but I am no coder. Thanks. 1
roaku 842 Posted February 12, 2021 Posted February 12, 2021 15 minutes ago, dcol said: Had the same release when ytrailers was updated and working for a few days. I'm telling you what the error message says.
dcol 177 Posted February 12, 2021 Posted February 12, 2021 I guess the answer is to only use ytrailers on my stable server. I will try it and see if it errors.
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 1 hour ago, radeon said: i dont support any betas I run stable (latest) official docker container and having issues too. I haven't combed the logs yet.
