dcol 177 Posted December 6, 2020 Posted December 6, 2020 (edited) That may be the issue. I had it set to trigger every 2 hours. Changed it to once a day. But it does seem to retry the same movies that don't have any trailers. Most of these are classic pre-1930 movies. I wish I could select which libraries or folders to check. Ideally I want to only check movies made after 2000. Trailers before that are usually not very good anyway. Edited December 6, 2020 by dcol
radeon 760 Posted December 6, 2020 Posted December 6, 2020 2 minutes ago, dcol said: That may be the issue. I had it set to trigger every 2 hours. Changed it to once a day. But it does seem to retry the same movies that don't have any trailers. Most of these are classic pre-1930 movies. I wish I could select which libraries or folders to check. Yeah, that'll likely be it. As for retries, If they don't have a youtube trailer listed against their metadata then it won't do anything and just skip it.
dcol 177 Posted December 6, 2020 Posted December 6, 2020 Then maybe for the movies that it is stuck on, I can change the metadata or use a dummy trailer.
radeon 760 Posted December 6, 2020 Posted December 6, 2020 The only reason it'd be stuck on anything is if a given trailer has been removed for copyright reasons from YouTube or the video isn't available in your country.
dcol 177 Posted December 6, 2020 Posted December 6, 2020 So for these, should I just use a dummy trailer, or alter the metadata and then lock it
radeon 760 Posted December 6, 2020 Posted December 6, 2020 I don't know what you mean by dummy trailer. Just remove the metadata for the did trailer
dcol 177 Posted December 6, 2020 Posted December 6, 2020 Probably best to just remove the trailer tag from the nfo or xml. Some movies have an xml and nfo, which does ytrailers look at? What I meant by dummy trailer is to have a zero byte file like moviename-trailer.mp4
radeon 760 Posted December 6, 2020 Posted December 6, 2020 Neither, it uses the data stored within your emby stored info in the db. I presume if you delete from the UI of the movie then it'll remove from the corresponding metadata files you uses too.
dcol 177 Posted December 6, 2020 Posted December 6, 2020 The trailer data is not in the metadata UI. I just looked at the logs and noticed another error for a trailer that already has a trailer since May for that title. Why would it be trying to fetch a trailer that already exists? Seems to be the same 50 or so videos every day and they all have trailers.
Happy2Play 9814 Posted December 6, 2020 Posted December 6, 2020 1 minute ago, dcol said: The trailer data is not in the metadata UI. I just looked at the logs and noticed another error for a trailer that already has a trailer since May for that title. Why would it be trying to fetch a trailer that already exists? Seems to be the same 50 or so videos every day and they all have trailers. To me that would suggest the database is not updated to show a local trailer vs a online trailer url.
dcol 177 Posted December 6, 2020 Posted December 6, 2020 (edited) Most of these issues are in a different folder organization. I have a folder named Stand Up and within that folder is a folder named Specials. I put all the videos in there as artistname_showname.mp4. All of these have trailers and error every day with ytrailers. Could the way I setup these videos be a reason? Edited December 6, 2020 by dcol
dcol 177 Posted December 6, 2020 Posted December 6, 2020 So how do I update the database. Is the UI suppose to show the trailer url?
Happy2Play 9814 Posted December 6, 2020 Posted December 6, 2020 Just now, dcol said: So how do I update the database. Is the UI suppose to show the trailer url? No it has been requested for the trailer url to be added but has never happened. 5 minutes ago, dcol said: Most of these issues are in a different folder organization. I have a folder named Stand Up and within that folder is a folder named Specials. I put all the videos in there as artistname_showname.mp4. All of these have trailers and error every day with ytrailers. Could the way I setup these videos be a reason? To me this would be expected if you are not following expected structure.
dcol 177 Posted December 6, 2020 Posted December 6, 2020 (edited) The structure seems fine, but the file names are unique to other folders such as movies. What are the recommendations for correct structure? Here is an example how it is setup now Stand Up>Specials>Jerry Seinfeld_23 Hours to Kill (2020).mp4 Should I use something like this. Seems there would be no Season or Special folder needed for Emby. The library type is Movies. Stand Up>Jerry Seinfeld>23 Hours to Kill (2020).mp4 or change the library type to TV Shows and then use this for all the videos Stand Up>Specials>Jerry Seinfeld_23 Hours to Kill (2020).mp4 Edited December 6, 2020 by dcol
dcol 177 Posted December 12, 2020 Posted December 12, 2020 ytrailers is still not working. Gets errors for every movie it tries. Here is a sample of the error in the log. I have dozens of them for every new movie. 2020-12-12 02:00:03.300 Error App: Error downloading trailer for Mickey's Christmas Carol *** Error Report *** Version: 4.6.0.7 Command line: C:\Emby\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.17763 Framework: .NET Core 3.1.9 OS/Process: x64/x64 Runtime: C:/Emby/system/System.Private.CoreLib.dll Processor count: 16 Data path: C:\Emby\programdata Application path: C:\Emby\system System.ArgumentNullException: System.ArgumentNullException: Value cannot be null. (Parameter 'str') at System.Text.RegularExpressions.Regex.Unescape(String str) at VideoLibrary.YouTube.ParseVideos(String source)+MoveNext() at System.Linq.Enumerable.SelectEnumerableIterator`2.MoveNext() at System.Linq.Enumerable.WhereEnumerableIterator`1.MoveNext() at System.Linq.OrderedEnumerable`1.TryGetFirst(Func`2 predicate, Boolean& found) at System.Linq.Enumerable.TryGetFirst[TSource](IEnumerable`1 source, Func`2 predicate, Boolean& found) at System.Linq.Enumerable.First[TSource](IEnumerable`1 source, Func`2 predicate) at YTrailers.Search.YouTubeSearch.Search(BaseItem item, CancellationToken cancellationToken) Source: System.Text.RegularExpressions TargetSite: System.String Unescape(System.String) Any suggestions on what to try?
radeon 760 Posted December 12, 2020 Posted December 12, 2020 (edited) That's not the same error as before. Looks like they've changed their site again. Will need a fix and release. May take a little while for the fix to be released, just bear with me for a little. Edited December 14, 2020 by radeon
dcol 177 Posted December 12, 2020 Posted December 12, 2020 By the way, @radeon I just realized the YTrailer key appears in the log, which I have posted many times for diagnostic purposes. I am sure it has been circulated by now. Do I need a new one maybe?
radeon 760 Posted December 12, 2020 Posted December 12, 2020 7 minutes ago, dcol said: By the way, @radeon I just realized the YTrailer key appears in the log, which I have posted many times for diagnostic purposes. I am sure it has been circulated by now. Do I need a new one maybe? It's tied to your instance and can't be used again
dcol 177 Posted December 12, 2020 Posted December 12, 2020 1 hour ago, radeon said: It's tied to your instance and can't be used again What do you consider 'instance' I plan to change the OS on that system from Windows server to Windows 10 and copy Emby back to it this month. Same hardware. Will the key still work?
radeon 760 Posted December 22, 2020 Posted December 22, 2020 Fraid not. I'm waiting on a update to the youtube lib used to generate the download link. As soon as that's done, I'll be able to release.
plaidstallion 9 Posted December 31, 2020 Posted December 31, 2020 Are the updates to this extension automatic or do they require going to the site and downloading the latest version?
dcol 177 Posted January 1, 2021 Posted January 1, 2021 Until this gets resolved I have to disable ytrailers because of all the errors it creates. I assume the best way to do this is to delete the ytrailer scheduled task. Is this the best way to disable it, or do I need to remove the plugin?
radeon 760 Posted January 1, 2021 Posted January 1, 2021 New version just uploaded. You'll have to download and install manually from https://www.ballingtons.com/products/ 2
dcol 177 Posted January 2, 2021 Posted January 2, 2021 Thanks, replaced the dll with the new one. Did notice that ytrailers throws an error when trailer is not available now. Is that normal? Here is an example 2021-01-02 11:28:44.498 Error App: Error downloading trailer for Beautiful Stranger *** Error Report *** Version: 4.6.0.10 Command line: N:\Emby\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.17763 Framework: .NET Core 3.1.9 OS/Process: x64/x64 Runtime: N:/Emby/system/System.Private.CoreLib.dll Processor count: 16 Data path: N:\Emby\programdata Application path: N:\Emby\system VideoLibrary.Exceptions.UnavailableStreamException: VideoLibrary.Exceptions.UnavailableStreamException: Video has unavailable stream. at VideoLibrary.YouTube.ParseVideos(String source)+MoveNext() at System.Linq.Enumerable.SelectEnumerableIterator`2.MoveNext() at System.Linq.Enumerable.WhereEnumerableIterator`1.MoveNext() at System.Linq.OrderedEnumerable`1.TryGetFirst(Func`2 predicate, Boolean& found) at System.Linq.Enumerable.TryGetFirst[TSource](IEnumerable`1 source, Func`2 predicate, Boolean& found) at System.Linq.Enumerable.First[TSource](IEnumerable`1 source, Func`2 predicate) at YTrailers.Search.YouTubeSearch.Search(BaseItem item, CancellationToken cancellationToken) Source: test TargetSite: Boolean MoveNext()
