Luke 42243 Posted August 30, 2020 Posted August 30, 2020 Ok so essentially it looks like we're trying to direct play something to the Samsung TV that it can't handle, when we should be transcoding it. @SamES
Robert_84 4 Posted August 30, 2020 Author Posted August 30, 2020 (edited) !correct Edited August 30, 2020 by Robert_84 edit
SamES 1084 Posted August 30, 2020 Posted August 30, 2020 Can you please try the latest Beta version on USB (version 1.0.82). It should already be resolved in this version.
Robert_84 4 Posted August 31, 2020 Author Posted August 31, 2020 (edited) Hi, latest is 83, but the problem is not resolved! still 4K transcoding 1080p is not working but now logs are there, with 83, there is progress embyserver.txt ffmpeg-transcode-57d6f3bd-c0f1-46ff-a6be-9ddec169f2fd_1.txt ffmpeg-transcode-6c21dbfc-8551-4c2a-b5fe-452882ebc9b2_1.txt Edited August 31, 2020 by Robert_84 update 1
Luke 42243 Posted August 31, 2020 Posted August 31, 2020 Can you provide the media info of what you're trying to play? Thanks.
Robert_84 4 Posted August 31, 2020 Author Posted August 31, 2020 @SamES after 3rd time there is sound but no image embyserver.txt ffmpeg-transcode-57d6f3bd-c0f1-46ff-a6be-9ddec169f2fd_1.txt ffmpeg-transcode-6c21dbfc-8551-4c2a-b5fe-452882ebc9b2_1.txt
SamES 1084 Posted September 1, 2020 Posted September 1, 2020 9 hours ago, Robert_84 said: si with 83, there is improvement So it is right now, it is transcoding 4K to 1080 automatically?
Robert_84 4 Posted September 1, 2020 Author Posted September 1, 2020 Hi, no. There is sound but no image. I already attached logs above! Improvement is usually better but not "resolved", maybe just if you check last 3-4 posts
SamES 1084 Posted September 1, 2020 Posted September 1, 2020 It's good now that you are getting transcoding, that was what I was expecting from .83. Just so that we are only testing one thing at a time, can you please turn off subtitles on the Details screen, then start playback from the beginning of the file. If that does not work, then please also do a test with Hardware acceleration off
Robert_84 4 Posted September 1, 2020 Author Posted September 1, 2020 hi, as requested still not working Sub on - tanscoding on - only sound, no video Sub off - transcoding on - only sound, no video sub off - transcoding off - no video, no sound title off.zip Title on.zip TR off sub off.zip
SamES 1084 Posted September 2, 2020 Posted September 2, 2020 OK, I think I know what's going on here. I'm not aware of anyone trying to transcode 4K content on a 1080 model in the past, so this has not really been tried before, but it should work fine. There was more than one thing that needed to be fixed for this, so hopefully the next USB release should resolve this. Thanks for your patience. 1
Robert_84 4 Posted September 2, 2020 Author Posted September 2, 2020 hi, thx for the update, I hope it will be resolved.... im only skeptical how no one tried to transcode 4K material on a Full HD TV..... maybe many users are using Emby on a PC... or just laptop...
SamES 1084 Posted September 2, 2020 Posted September 2, 2020 I'm not sure if there were many models that were only FHD in the Tizen series. Maybe a few in 2017 and 2018, but that's it as far as I know
FrostByte 5454 Posted September 3, 2020 Posted September 3, 2020 Samsung also made an evolution kit for 2012 and 2015 Orsay premium sets to upgrade to 2018 Tizen. Most of those were FHD. Wasn't worth the $300 US for me though, but I believe I saw a couple people post they had one.
Carlo 4561 Posted September 4, 2020 Posted September 4, 2020 On 9/2/2020 at 8:31 PM, FrostByte said: Samsung also made an evolution kit for 2012 and 2015 Orsay premium sets to upgrade to 2018 Tizen. Most of those were FHD. Wasn't worth the $300 US for me though, but I believe I saw a couple people post they had one. I was thinking about that for a 75" I had but decided I got a lot more for the money picking up a Shield TV to use with it. 1
