Goldrol 0 Posted March 10, 2020 Posted March 10, 2020 HI There, Emby Connect does not let me login... I have reset my password I can login to here But login in the app (android) or app.emby.media is not working The screen let's me login bu just redirects me to the select server page. Once there I select a server....none of them are working. Htere is no indication that I am even logged in either... What am I missing?
pwhodges 2028 Posted March 10, 2020 Posted March 10, 2020 The Emby Connect login (also used for this forum) is a login to the Emby web site. Your server has its own login or logins, for the administrator and for other users. While those can be linked to Emby Connect, they can be used directly, and it's best to ensure that they are working locally before linking to your server through Connect. But actually, you don't mention your server - are you running one that you have installed and set up? Or has a friend given you a link to theirs? The Emby website doesn't provide and run a server for anyone to use. Paul
ebr 16312 Posted March 10, 2020 Posted March 10, 2020 Hi. What exactly do you mean by "none of them are working"? What happens when you select a server? Is this your server or someone else's?
