deadscope 0 Posted March 8, 2020 Posted March 8, 2020 so just created a CDN for my server and cloudflare said there my be a hosting limit issue are you considered my hosting server?
Luke 42216 Posted March 8, 2020 Posted March 8, 2020 Hi, we're just the software, we're not the hosting provider. Can you describe your issue in more detail? Thanks.
deadscope 0 Posted March 8, 2020 Author Posted March 8, 2020 so when people are trying to load my stuff they get the loading circle but the moving around the server works fine
deadscope 0 Posted March 8, 2020 Author Posted March 8, 2020 i followed this guide on how to do it https://blog.awelswynol.co.uk/2018/01/setting-up-cloudflare-with-emby
Luke 42216 Posted March 8, 2020 Posted March 8, 2020 Are there errors in the server log when this happens?
deadscope 0 Posted March 8, 2020 Author Posted March 8, 2020 yes so it seems the hosting server was being overloaded/limiting my connection
pir8radio 1313 Posted March 8, 2020 Posted March 8, 2020 sometimes....... why are you using cloudflare in the first place? Just curious. You have emby server setup on your home PC right? that is the hosting server.
pir8radio 1313 Posted March 8, 2020 Posted March 8, 2020 Just let me know what i should do Im not sure you even need cloudflare, is there some reason you need it? Otherwise its just another point to possibly slow you down and cause issues when troubleshooting.
deadscope 0 Posted March 8, 2020 Author Posted March 8, 2020 (edited) i use windows and i just followed the guide if you have a better way im open couldnt tell you if i needed it or not if you can tell me a simple guide that would be great making emby the host server Edited March 8, 2020 by deadscope
deadscope 0 Posted March 8, 2020 Author Posted March 8, 2020 my domain in on https://www.namecheap.com/ if that helps
pir8radio 1313 Posted March 8, 2020 Posted March 8, 2020 @@Luke maybe a link normal setup instructions, I have no clue where you keep that stuff
Luke 42216 Posted March 8, 2020 Posted March 8, 2020 You mean normal Emby Server instructions? Or something specific to CDN's?
deadscope 0 Posted March 8, 2020 Author Posted March 8, 2020 so what you are saying is that i can use emby as a host so like in my case all i need is emby and the domain website?
maegibbons 1287 Posted March 8, 2020 Posted March 8, 2020 Yes you do not need Cloudfare or CDN. It just complicates stuff if you dont need it. Just start off with direct access. Krs Mark Sent from my SM-N976B using Tapatalk
deadscope 0 Posted March 8, 2020 Author Posted March 8, 2020 okay but i have friends in the EU dont i need a CDN?
deadscope 0 Posted March 8, 2020 Author Posted March 8, 2020 (edited) well i would love a guide if anyone knows how to setup a CDN for windows 10 Edited March 8, 2020 by deadscope
Luke 42216 Posted March 8, 2020 Posted March 8, 2020 @igeorge, @@ddurdle, @@horstepipe, and @@rechigo may have some tips.
deadscope 0 Posted March 8, 2020 Author Posted March 8, 2020 i hope so really cant seem to figure this out
