M3th0s 14 Posted March 6, 2020 Posted March 6, 2020 Apologies if I'm missing something! Is there a way to see more stream info on the dashboard. At the moment it shows some info, like who's playing what, movie/show and episode and the reason for transcode/direct stream. Is there however a way to show the bitrate (480p/720p/1080p/4K) within a setting somewhere and, if not, is this something that will be implemented in the future? As I have quite a big library I would like to pinpoint what files are causing the problem and what bitrates. Thanks in advance!
maegibbons 1287 Posted March 6, 2020 Posted March 6, 2020 It would be nice to have an info pop up on each active device which gives you a central view of the client "stats for nerds" info in its full glory. Krs Mark Sent from my SM-N976B using Tapatalk 1
Luke 42246 Posted March 6, 2020 Posted March 6, 2020 Hi, yes we plan to expand on this information in future updates. thanks for the feedback.
M3th0s 14 Posted March 6, 2020 Author Posted March 6, 2020 Thanks for that! Thought I was missing something
