Dedone 17 Posted March 6, 2020 Posted March 6, 2020 (edited) Hi everyone, somethinf strange happen. I had add new files to the series folder (like always) and all my series disappear and remain only 7 of the previous. In the original folder all the files are perfect and i havn't touch anything. I had try to reload metadata, scan the library files and cancel and make it new (library). Nothing happend except always give me back only the same 7 series... Thanks in advance Edited March 6, 2020 by Dedone
Dedone 17 Posted March 6, 2020 Author Posted March 6, 2020 after another analisys i found that it recognize only the cartoon and not the series.Everything was always in the same folder
Dedone 17 Posted March 6, 2020 Author Posted March 6, 2020 Update:I had solve the problem by scanning first the TV series and then the cartoon (I don't know why). Now the problem is that if I add anything to the library it doesn't appear, I must scan manually
Dedone 17 Posted March 6, 2020 Author Posted March 6, 2020 Update 2:after a server reboot seems all ok.
Luke 42242 Posted March 6, 2020 Posted March 6, 2020 Hi, yes when you add new content you have to either run a scan or wait for the realtime monitor to pick it up. Thanks for the feedback.
