tienpro113399 1 Posted March 4, 2020 Posted March 4, 2020 (edited) Dear All, Now I'm testing Emby server with my laptop before deploy to bigger server My laptop specs: i5-4300U 8GB RAM SSD 256GB Network now using Unifi AP AC Pro A folder have about 6500 sound files (WAV), the largest one is about 60Mb, below 2Mb take over 75%. It takes about 15sec to load the list but 3mins to direct play one file. I have tested my connection between devices: ------------ PS D:\iperf-3.1.3-win64> .\iperf3.exe -c "192.168.7.15" Connecting to host 192.168.7.15, port 5201 [ 4] local 192.168.3.137 port 7987 connected to 192.168.7.15 port 5201 [ ID] Interval Transfer Bandwidth [ 4] 0.00-1.00 sec 5.50 MBytes 46.1 Mbits/sec [ 4] 1.00-2.00 sec 5.38 MBytes 45.1 Mbits/sec [ 4] 2.00-3.00 sec 5.88 MBytes 49.3 Mbits/sec [ 4] 3.00-4.00 sec 5.50 MBytes 46.1 Mbits/sec [ 4] 4.00-5.00 sec 6.00 MBytes 50.3 Mbits/sec [ 4] 5.00-6.00 sec 5.25 MBytes 44.0 Mbits/sec [ 4] 6.00-7.00 sec 4.62 MBytes 38.9 Mbits/sec [ 4] 7.00-8.00 sec 5.62 MBytes 47.1 Mbits/sec [ 4] 8.00-9.00 sec 5.75 MBytes 48.3 Mbits/sec [ 4] 9.00-10.00 sec 5.88 MBytes 49.3 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth [ 4] 0.00-10.00 sec 55.4 MBytes 46.5 Mbits/sec sender [ 4] 0.00-10.00 sec 55.4 MBytes 46.4 Mbits/sec receiver iperf Done. --------------- Is it a low connection or something else cause the problem? Thanks embyserver-63718838200.txt embyserver (1).txt Edited March 5, 2020 by tienpro113399
Luke 42216 Posted March 4, 2020 Posted March 4, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a problem. thanks. 1
Luke 42216 Posted March 5, 2020 Posted March 5, 2020 Thanks. What screens exactly are causing the problem?
tienpro113399 1 Posted March 5, 2020 Author Posted March 5, 2020 The playing screen. It takes long time to play 34-second file with only 1.2Mb
Luke 42216 Posted March 5, 2020 Posted March 5, 2020 Is the connection coming from inside or outside your local network?
tienpro113399 1 Posted March 5, 2020 Author Posted March 5, 2020 All connection is inside. I'm using LAN
Luke 42216 Posted March 5, 2020 Posted March 5, 2020 Can you try the online web app and see how that compares? http://app.emby.media Thanks.
tienpro113399 1 Posted March 5, 2020 Author Posted March 5, 2020 It has the same problem too...takes long time to play a file
tienpro113399 1 Posted March 5, 2020 Author Posted March 5, 2020 I see that, in a list, if I play the file which have lower order is cost much more time...They are quick in about first 200 file
Luke 42216 Posted March 7, 2020 Posted March 7, 2020 Ok, we're looking into this. Thanks for reporting.
