stompysan 0 Posted March 4, 2020 Posted March 4, 2020 Hey everyone. I posted over on the Reddit, but a user stated the forums are more active. I am trying to get some help on getting hardware acceleration working on my server. I recently acquired an RX 580 to help with transcoding higher quality media. I have installed the latest AMDPRO drivers, and the device is showing up properly. Setting up the hardware acceleration shows the device, and I can use it for some transcoding, but all of my 4K content will not transcode via hardware. I have tried clean installing the proprietary drivers, as well as Emby, with no success. I have screenshots of the server dashboard at https://imgur.com/a/sv9AOTS Looking through logs, I found the following: 16:24:28.988 frame= 0 fps=0.0 q=0.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3331kB time=00:41:06.13 bitrate= 11.1kbits/s throttle=off speed= 659x 16:24:29.043 [h264_vaapi @ 0x97b140] No usable encoding profile found. 16:24:29.043 Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height 16:24:29.061 Conversion failed! 16:24:29.061 Affected codecs: >>>>>> libx264 Software Encoder Color Formats: YUV420P, YUVJ420P, YUV422P, YUVJ422P, YUV444P, YUVJ444P, NV12, NV16, NV21, YUV420P10, YUV422P10, YUV444P10, NV20 Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 10 Profile (Level 6.2), High 4:2:2 Profile (Level 6.2), High 4:4:4 Profile (Level 6.2) Info Previous transcoding attempt failed. Falling back to software transcoding. >>>>>> FindVideoDecoder - MediaType: hevc, Mode: Custom Info FindVideoDecoder - Checking: 'Automatic software decoder' (Priority: 0) Info FindVideoDecoder - Check successful - selecting 'Automatic software decoder' >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: False, Mode: Custom Info FindVideoEncoder - Checking: 'libx264 Software Encoder' (Priority: 0) Info Encoder supports input stream Info FindVideoEncoder - Check successful - selecting 'libx264 Software Encoder' /opt/emby-server/bin/ffmpeg -loglevel +timing -ss 00:41:15.000 -f matroska -i file:"/MainPool/6TB/Video/Movies/Joker (2019).mkv" -threads 4 -map 0:0 -map 0:2 -sn -c:v:0 libx264 -pix_fmt yuv420p -maxrate 59926080 -bufsize 119852160 -preset ultrafast -profile:v:0 high -level:v:0 4.1 -crf 23 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -g:v:0 72 -keyint_min:v:0 72 -sc_threshold:v:0 0 -copyts -vsync -1 -codec:a:0 libmp3lame -disposition:a:0 default -ac:a:0 2 -ab:a:0 192000 -af:a:0 "volume=2" -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_write_temp 1 -segment_list_type m3u8 -segment_start_number 825 -segment_list "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca.m3u8" -y "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca%d.ts" -map 0:3 -map 0:0 -c:v:0 copy -codec:0 webvtt -copyts -vsync -1 -f segment -segment_time 3 -segment_format webvtt -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -write_empty_segments 1 -segment_list_type m3u8 -segment_start_number 825 -segment_write_temp 1 -break_non_keyframes 1 -segment_list "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s3.m3u8" -y "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s3%d.vtt" -map 0:4 -map 0:0 -c:v:0 copy -codec:0 webvtt -copyts -vsync -1 -f segment -segment_time 3 -segment_format webvtt -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -write_empty_segments 1 -segment_list_type m3u8 -segment_start_number 825 -segment_write_temp 1 -break_non_keyframes 1 -segment_list "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s4.m3u8" -y "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s4%d.vtt" -map 0:5 -map 0:0 -c:v:0 copy -codec:0 webvtt -copyts -vsync -1 -f segment -segment_time 3 -segment_format webvtt -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -write_empty_segments 1 -segment_list_type m3u8 -segment_start_number 825 -segment_write_temp 1 -break_non_keyframes 1 -segment_list "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s5.m3u8" -y "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s5%d.vtt" -map 0:6 -map 0:0 -c:v:0 copy -codec:0 webvtt -copyts -vsync -1 -f segment -segment_time 3 -segment_format webvtt -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -write_empty_segments 1 -segment_list_type m3u8 -segment_start_number 825 -segment_write_temp 1 -break_non_keyframes 1 -segment_list "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s6.m3u8" -y "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s6%d.vtt" After disabling hardware encoding, I was able to get VAAPI to properly decode the media, but with my server specs, the encode task just runs terrible. Does anyone have any ideas? If more logs are needed, let me know.Specs: AMD FX-6300 16GB RAM RX 580 Ubuntu Mate 18.106x6TB ZFS Pool
Luke 42246 Posted March 4, 2020 Posted March 4, 2020 Hi there, please attach the complete log file example. thanks.
Luke 42246 Posted March 4, 2020 Posted March 4, 2020 Ok, I'm adding @@softworkz to see what he thinks but we're releasing Emby Server 4.4 very soon which will have significantly improved hardware acceleration support. You could always try the beta channel if you'd like, and let us know how that compares. Thanks.
stompysan 0 Posted March 4, 2020 Author Posted March 4, 2020 Ok, I'm adding @@softworkz to see what he thinks but we're releasing Emby Server 4.4 very soon which will have significantly improved hardware acceleration support. You could always try the beta channel if you'd like, and let us know how that compares. Thanks. How would I go about rolling into the beta? Didn't see any download links, and would love to give it a shot.
Luke 42246 Posted March 4, 2020 Posted March 4, 2020 If available for your platform, our download page will have instructions: https://emby.media/download.html
vdatanet 1619 Posted March 4, 2020 Posted March 4, 2020 Hey everyone. I posted over on the Reddit, but a user stated the forums are more active. I am trying to get some help on getting hardware acceleration working on my server. I recently acquired an RX 580 to help with transcoding higher quality media. I have installed the latest AMDPRO drivers, and the device is showing up properly. Setting up the hardware acceleration shows the device, and I can use it for some transcoding, but all of my 4K content will not transcode via hardware. I have tried clean installing the proprietary drivers, as well as Emby, with no success. I have screenshots of the server dashboard at https://imgur.com/a/sv9AOTS Looking through logs, I found the following: 16:24:28.988 frame= 0 fps=0.0 q=0.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3331kB time=00:41:06.13 bitrate= 11.1kbits/s throttle=off speed= 659x 16:24:29.043 [h264_vaapi @ 0x97b140] No usable encoding profile found. 16:24:29.043 Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height 16:24:29.061 Conversion failed! 16:24:29.061 Affected codecs: >>>>>> libx264 Software Encoder Color Formats: YUV420P, YUVJ420P, YUV422P, YUVJ422P, YUV444P, YUVJ444P, NV12, NV16, NV21, YUV420P10, YUV422P10, YUV444P10, NV20 Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 10 Profile (Level 6.2), High 4:2:2 Profile (Level 6.2), High 4:4:4 Profile (Level 6.2) Info Previous transcoding attempt failed. Falling back to software transcoding. >>>>>> FindVideoDecoder - MediaType: hevc, Mode: Custom Info FindVideoDecoder - Checking: 'Automatic software decoder' (Priority: 0) Info FindVideoDecoder - Check successful - selecting 'Automatic software decoder' >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: False, Mode: Custom Info FindVideoEncoder - Checking: 'libx264 Software Encoder' (Priority: 0) Info Encoder supports input stream Info FindVideoEncoder - Check successful - selecting 'libx264 Software Encoder' /opt/emby-server/bin/ffmpeg -loglevel +timing -ss 00:41:15.000 -f matroska -i file:"/MainPool/6TB/Video/Movies/Joker (2019).mkv" -threads 4 -map 0:0 -map 0:2 -sn -c:v:0 libx264 -pix_fmt yuv420p -maxrate 59926080 -bufsize 119852160 -preset ultrafast -profile:v:0 high -level:v:0 4.1 -crf 23 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -g:v:0 72 -keyint_min:v:0 72 -sc_threshold:v:0 0 -copyts -vsync -1 -codec:a:0 libmp3lame -disposition:a:0 default -ac:a:0 2 -ab:a:0 192000 -af:a:0 "volume=2" -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_write_temp 1 -segment_list_type m3u8 -segment_start_number 825 -segment_list "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca.m3u8" -y "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca%d.ts" -map 0:3 -map 0:0 -c:v:0 copy -codec:0 webvtt -copyts -vsync -1 -f segment -segment_time 3 -segment_format webvtt -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -write_empty_segments 1 -segment_list_type m3u8 -segment_start_number 825 -segment_write_temp 1 -break_non_keyframes 1 -segment_list "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s3.m3u8" -y "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s3%d.vtt" -map 0:4 -map 0:0 -c:v:0 copy -codec:0 webvtt -copyts -vsync -1 -f segment -segment_time 3 -segment_format webvtt -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -write_empty_segments 1 -segment_list_type m3u8 -segment_start_number 825 -segment_write_temp 1 -break_non_keyframes 1 -segment_list "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s4.m3u8" -y "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s4%d.vtt" -map 0:5 -map 0:0 -c:v:0 copy -codec:0 webvtt -copyts -vsync -1 -f segment -segment_time 3 -segment_format webvtt -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -write_empty_segments 1 -segment_list_type m3u8 -segment_start_number 825 -segment_write_temp 1 -break_non_keyframes 1 -segment_list "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s5.m3u8" -y "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s5%d.vtt" -map 0:6 -map 0:0 -c:v:0 copy -codec:0 webvtt -copyts -vsync -1 -f segment -segment_time 3 -segment_format webvtt -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -write_empty_segments 1 -segment_list_type m3u8 -segment_start_number 825 -segment_write_temp 1 -break_non_keyframes 1 -segment_list "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s6.m3u8" -y "/var/lib/emby/transcoding-temp/79cfbaa409d97775600fd867cdc9ecca_s6%d.vtt" After disabling hardware encoding, I was able to get VAAPI to properly decode the media, but with my server specs, the encode task just runs terrible. Does anyone have any ideas? If more logs are needed, let me know. Specs: AMD FX-6300 16GB RAM RX 580 Ubuntu Mate 18.10 6x6TB ZFS Pool This is fixed in the beta cycle 1
softworkz 5133 Posted March 4, 2020 Posted March 4, 2020 This is fixed in the beta cycle Just wanted to respond the same right in this second..
stompysan 0 Posted March 4, 2020 Author Posted March 4, 2020 Strange. Updated to latest beta from the Github. Getting the following in my logs. Still no go with hardware encoding. ffmpeg-transcode-a6ab8e27-a263-466c-81ec-852ea80d53d8_1.txt
Luke 42246 Posted March 4, 2020 Posted March 4, 2020 Did you follow our hardware acceleration setup guide? https://support.emby.media/support/solutions/articles/44001160148-hardware-acceleration-overview
stompysan 0 Posted March 4, 2020 Author Posted March 4, 2020 (edited) Did you follow our hardware acceleration setup guide? https://support.emby.media/support/solutions/articles/44001160148-hardware-acceleration-overview Yes, using the latest AMDPRO driver. Transcoding cache folder is on an SSD to prevent any problems for IO. EDIT: I did not see any notes involving it on Linux, but would running the device headless cause issues? My server is running in another room and is completely headless. I use X2Go for desktop management, and PuTTY for everything else. Edited March 4, 2020 by stompysan
softworkz 5133 Posted March 5, 2020 Posted March 5, 2020 Yes, using the latest AMDPRO driver. Transcoding cache folder is on an SSD to prevent any problems for IO. EDIT: I did not see any notes involving it on Linux, but would running the device headless cause issues? My server is running in another room and is completely headless. I use X2Go for desktop management, and PuTTY for everything else. @@stompysan - Generally, VAAPI can work without a user session and without a connected display, but there's also BIOS functionality coming into play by controlling the onboard graphics configuration (e.g. amount of assigned memory) depending on whether a monitor is connected or not. So, one thing you should check is your BIOS settings to make sure that onboard graphic is always on and has a decent amount of memory assigned. The other part: Could you please retry without selecting subtitles, so we can see what happens in a somewhat less complicated case?
stompysan 0 Posted March 5, 2020 Author Posted March 5, 2020 (edited) @@stompysan - Generally, VAAPI can work without a user session and without a connected display, but there's also BIOS functionality coming into play by controlling the onboard graphics configuration (e.g. amount of assigned memory) depending on whether a monitor is connected or not. So, one thing you should check is your BIOS settings to make sure that onboard graphic is always on and has a decent amount of memory assigned. The other part: Could you please retry without selecting subtitles, so we can see what happens in a somewhat less complicated case? Subtitles disabled for this one. As for the BIOS options, I don't think that is an issue with my machine. I am using an FX-6300, which does not have any onboard video whatsoever. EDIT: Attached file but forgot to upload. Oof. ffmpeg-transcode-a6ab8e27-a263-466c-81ec-852ea80d53d8_1.txt Edited March 5, 2020 by stompysan
softworkz 5133 Posted March 5, 2020 Posted March 5, 2020 Subtitles disabled for this one. As for the BIOS options, I don't think that is an issue with my machine. I am using an FX-6300, which does not have any onboard video whatsoever. EDIT: Attached file but forgot to upload. Oof. Of course you're right: In case of a discrete GPU board, BIOS setting doesn't matter. What model do you have? PS: The attached log is the same as the one you posted previously...
stompysan 0 Posted March 5, 2020 Author Posted March 5, 2020 Of course you're right: In case of a discrete GPU board, BIOS setting doesn't matter. What model do you have? PS: The attached log is the same as the one you posted previously... Sigh... I didn't open it to verify I pulled the right log. Used a different file this time, with same codec and settings. Actually made sure it was the right log this time. lol. I am using an XFX RX 580 GTS Black. ffmpeg-transcode-c51ba2a3-216f-4291-98e1-7912a8dfa27e_1.txt
stompysan 0 Posted March 10, 2020 Author Posted March 10, 2020 Last post. I ultimately abandoned the RX 580 and decided to replace it with a 1050. Hardware acceleration just works now. Thanks for trying to help everyone!
