Kimballslice1890 8 Posted March 3, 2020 Posted March 3, 2020 So I've been beginning to setup cloudflare for my Emby server. Now I was wondering for anyone that has had experience doing this that may be able to shed some light on my concern ( I know there are more than a couple of threads but nothing really touching on this). I use Firesticks and occasionally Chromecasts mainly as my client devices (mixed with some iPhones). All of these devices REQUIRE a signed cert in order to connect and stream from while using the Emby built apps. I am currently using Lets Encrypt for my domain. I was wondering now, if I go through cloudflare and have to use their SSL, will that cause issues with such devices? I am very interested in using this method, but losing the functionality of those client platforms would be a deal breaker. Was using this link as a guide: https://blog.awelswynol.co.uk/2018/01/setting-up-cloudflare-with-emby
mastrmind11 722 Posted March 3, 2020 Posted March 3, 2020 So I've been beginning to setup cloudflare for my Emby server. Now I was wondering for anyone that has had experience doing this that may be able to shed some light on my concern ( I know there are more than a couple of threads but nothing really touching on this). I use Firesticks and occasionally Chromecasts mainly as my client devices (mixed with some iPhones). All of these devices REQUIRE a signed cert in order to connect and stream from while using the Emby built apps. I am currently using Lets Encrypt for my domain. I was wondering now, if I go through cloudflare and have to use their SSL, will that cause issues with such devices? I am very interested in using this method, but losing the functionality of those client platforms would be a deal breaker. Was using this link as a guide: https://blog.awelswynol.co.uk/2018/01/setting-up-cloudflare-with-emby You get a new cert from cloudflare so it'll be signed by cloudlfare, no issue there. While I don't use chromecast/firestick, I have several android streamers set up on external networks that all work perfectly over https. Just follow that guide and you're in business.
Kimballslice1890 8 Posted March 3, 2020 Author Posted March 3, 2020 Definitely some promising information. My experience with Android though is that it is one of the few platforms that isn't particularly picky about certs.
Solution pir8radio 1313 Posted March 4, 2020 Solution Posted March 4, 2020 (edited) So I've been beginning to setup cloudflare for my Emby server. Now I was wondering for anyone that has had experience doing this that may be able to shed some light on my concern ( I know there are more than a couple of threads but nothing really touching on this). I use Firesticks and occasionally Chromecasts mainly as my client devices (mixed with some iPhones). All of these devices REQUIRE a signed cert in order to connect and stream from while using the Emby built apps. I am currently using Lets Encrypt for my domain. I was wondering now, if I go through cloudflare and have to use their SSL, will that cause issues with such devices? I am very interested in using this method, but losing the functionality of those client platforms would be a deal breaker. Was using this link as a guide: https://blog.awelswynol.co.uk/2018/01/setting-up-cloudflare-with-emby No cloudflare cert issues, YET.... Below are the stats on devices that work with my server running CF: *these are actual stats from my logs on my emby server. the count is "hits". Edited March 4, 2020 by pir8radio 1
Kimballslice1890 8 Posted May 5, 2020 Author Posted May 5, 2020 Thanks for the help. Finally just set it up and it seems to be working all good. On the guide, it says to change my public port to 443. I left them as default 8920 because via my USG I forwarded 443 to 8920 anyway (as directed in the guide). And I tested the public emby ports on 443 and 8920, it didn't seem to make a difference since it looks like its forwarding to the locally binded port anyway. Does this sound right or should I be changing my public port to 443? Also even with cloudflare setup, I noticed that the IPs of external users are being reported properly (not a cloudflare IP). I had read somewhere that it would be reporting the cloudflare IP. Is this a normal occurrence? Another follow up question in terms of security. Obviously running cloudflare now. Is running a firewall with IPS/IDS in conjunction with Cloudflare overkill? Or should I favor one over the other? Thanks again for the help and input!
pir8radio 1313 Posted May 5, 2020 Posted May 5, 2020 Thanks for the help. Finally just set it up and it seems to be working all good. On the guide, it says to change my public port to 443. I left them as default 8920 because via my USG I forwarded 443 to 8920 anyway (as directed in the guide). And I tested the public emby ports on 443 and 8920, it didn't seem to make a difference since it looks like its forwarding to the locally binded port anyway. Does this sound right or should I be changing my public port to 443? Also even with cloudflare setup, I noticed that the IPs of external users are being reported properly (not a cloudflare IP). I had read somewhere that it would be reporting the cloudflare IP. Is this a normal occurrence? Another follow up question in terms of security. Obviously running cloudflare now. Is running a firewall with IPS/IDS in conjunction with Cloudflare overkill? Or should I favor one over the other? Thanks again for the help and input! not an overkill.. cloudflare is a different kind of protection than your firewall.. Think of your firewall as your front door to your house with a lock and alarm. only people with the correct keys and codes can get in. CF is more like a security guard at the end of your driveway.. He will stop or deter most intruders, but people can still sneak around the security guard and get to your front door. The main use for cloudflare is not security.. Sure it "can" hide your real IP address, provide SSL, and a few other things, but its not really there to secure anything. 1
