hrco 0 Posted March 3, 2020 Posted March 3, 2020 Can you explain me why i dont see all programs when i add m3u file on live tv? I edit my m3u delete what i dont need,there is only 100 programs and when i go on servers in live tv add m3u files i see only one program? I use this list on kodi,vlc and see all programs. I buy premier because of live tv now dont work like i thought and like on other programs.
hrco 0 Posted March 3, 2020 Author Posted March 3, 2020 Yes,i add link and xml file and map manual some programs to see is it work but no. Dont see others programs in list.
Luke 42216 Posted March 4, 2020 Posted March 4, 2020 Did you check the mapping tool to ensure that each m3u channel is mapped to an xml channel?
hrco 0 Posted March 5, 2020 Author Posted March 5, 2020 Did you check the mapping tool to ensure that each m3u channel is mapped to an xml channel? I mapped manualy few chanels to see will it show then buth still the same.
Luke 42216 Posted March 5, 2020 Posted March 5, 2020 Did you run the refresh guide scheduled task after doing that?
tomok 0 Posted March 5, 2020 Posted March 5, 2020 Of course...that is basic,and i dont know why dont work but ok...can i add m3u list somehow diferent not only on live tv?Every media player can open it withouth problem
Luke 42216 Posted March 5, 2020 Posted March 5, 2020 You can still play your live TV without guide data. What is the problem exactly? Have you checked that your guide data actually has data in it?
tomok 0 Posted March 5, 2020 Posted March 5, 2020 How can i watch m3u file without guide data? Lets say i dont have guide data and load same m3u file in emby and dont see any program? I have 190 programs in that list and see only some of them. Use same m3u file with vlc or kodi i see all programs.
Luke 42216 Posted March 5, 2020 Posted March 5, 2020 You can just play the channel. It will show up in the Channels tab. The guide data will enhance the presentation, but it's not required to play. What exactly did you import as the m3u tuner? It needs to be formatted like this: http://xmtvplayer.com/build-m3u-file
hrco 0 Posted March 6, 2020 Author Posted March 6, 2020 I import .m3u file nothing special...delete some programs and thats it.I watch same list on kodi,vlc,bsplayer ....only on emby i cant see channels dont know why.
Luke 42216 Posted March 7, 2020 Posted March 7, 2020 Does the format of your m3u match the example I gave in my link above?
tomok 0 Posted March 7, 2020 Posted March 7, 2020 The link you sent is making simple m3u file...i have allready m3u file.Same thing you sent.
