GavinCampbell 16 Posted March 2, 2020 Posted March 2, 2020 Hi, I am having issues getting YTrailers to work. It gives me the "Too Many Requests" errors. I have not been able to find any threads with this error. Any ideas as to how I can get this working? *** Error Report *** Version: 4.3.1.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.19.98.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///system/System.Private.CoreLib.dll Processor count: 4 Program data path: /config Application directory: /system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: Response status code does not indicate success: 429 (Too Many Requests). at System.Net.Http.HttpResponseMessage.EnsureSuccessStatusCode() at System.Net.Http.HttpClient.GetStringAsyncCore(Task`1 getTask) at VideoLibrary.YouTube.GetAllVideosAsync(String videoUri, Func`2 sourceFactory) at VideoLibrary.ServiceBase`1.GetAllVideosAsync(String videoUri) at VideoLibrary.ServiceBase`1.GetAllVideos(String videoUri) at YoutubeExtractor.DownloadUrlResolver.GetDownloadUrls(String videoUrl, Boolean decryptSignature) at YTrailers.Search.YouTubeSearch.Search(BaseItem item, CancellationToken cancellationToken) Source: System.Net.Http TargetSite: System.Net.Http.HttpResponseMessage EnsureSuccessStatusCode()
GavinCampbell 16 Posted March 10, 2020 Author Posted March 10, 2020 Pinging @@radeon I haven't been ale to get this to work since I downloaded it a few days ago. Just gives the same error for every video. Any ideas?
radeon 760 Posted March 10, 2020 Posted March 10, 2020 Hey, are you sure you're running the latest version of the plugin? You have to manually update from the website. Cheers.
GavinCampbell 16 Posted March 10, 2020 Author Posted March 10, 2020 Hey, are you sure you're running the latest version of the plugin? You have to manually update from the website. Thanks guys. I am running the latest. I had purchased the license and downloaded it directly from the site right after. I also just double checked and I should have the latest version installed (1.6.6.1). This is what is downloaded from the web site.
