deepac7 9 Posted March 6, 2020 Author Posted March 6, 2020 Ok it's resolved for the next release. thanks. Okay new discovery. It's not just DTS WAV. Master Quality Audio (MQA) FLAC also play just static. For your testing. https://drive.google.com/drive/folders/177QR2A67hof3AfdcUx1_v6s4M05zxe0K?usp=sharing Not sure if the fix for DTS wav can fix this too but wanted to bring this to your attention.
pwhodges 2028 Posted March 6, 2020 Posted March 6, 2020 (edited) That's odd - MQA is designed to be playable at ordinary quality without special decoding. Static noise should not be an option in this case. For me, your test file plays as expected in both the web client and Theatre, also in iOS and Android clients.. Paul Edited March 6, 2020 by pwhodges
deepac7 9 Posted March 6, 2020 Author Posted March 6, 2020 That's odd - MQA is designed to be playable at ordinary quality without special decoding. Static noise should not be an option in this case. For me, your test file plays as expected in both the web client and Theatre, also in iOS and Android clients.. Paul I'm on shieldtv and I hear static. Is it playing direct for you or transcoding?
deepac7 9 Posted March 6, 2020 Author Posted March 6, 2020 (edited) Okay I just played the same track on web client and it is playing perfectly (direct play). I still hear static on shieldtv. Edit :Before I played it on web client, I played two other MQA tracks. One played normally and other one was again static. Now after playing on webclient, I went back to shieldtv and all tracks which were playing static are playing just fine. What kind of sorcery is this? Edited March 6, 2020 by deepac7 1
pwhodges 2028 Posted March 6, 2020 Posted March 6, 2020 Direct playing. It took some effort to force it to transcode; I turned my phone's wifi off and set the audio quality to 64k - the dashboard said it was still direct playing, but a transcoding log was generated which showed that it was generating an aac stream. Anyway, it still played OK. Note that I am using the current beta server 4.4.0.21 (I realise this is not the beta forum). Paul
Luke 42201 Posted March 6, 2020 Posted March 6, 2020 The wav files with DTS will not direct play in the web app, just FYI. Browsers do not support dts.
deepac7 9 Posted March 6, 2020 Author Posted March 6, 2020 The wav files with DTS will not direct play in the web app, just FYI. Browsers do not support dts. Yes, makes sense.
deepac7 9 Posted March 6, 2020 Author Posted March 6, 2020 Okay I just played the same track on web client and it is playing perfectly (direct play). I still hear static on shieldtv. Edit :Before I played it on web client, I played two other MQA tracks. One played normally and other one was again static. Now after playing on webclient, I went back to shieldtv and all tracks which were playing static are playing just fine. What kind of sorcery is this? @@Luke Any idea why this happened?
Luke 42201 Posted March 7, 2020 Posted March 7, 2020 I'm not sure. If you can get it to happen again then we can take a closer look.
deepac7 9 Posted March 15, 2020 Author Posted March 15, 2020 Ok it's resolved for the next release. thanks. Was this supposed to be resolved on the recent Emby client app update or upcoming server update for shield tv? The file still plays static after updating the emby client on my shieldtv. 2
FrostByte 5436 Posted March 15, 2020 Posted March 15, 2020 (edited) I'm on Shield TV beta .93 and Server beta .22 and all by DTS music is static unless I put it into a mka container then it transcodes to 128 bit AAC. Use VLC on the Shield though and it plays just fine. Edited March 15, 2020 by FrostByte 1
Spaceboy 2573 Posted March 15, 2020 Posted March 15, 2020 I'm on Shield TV beta .93 and Server beta .22 and all by DTS music is static unless I put it into a mka container then it transcodes to 128 bit AAC. Use VLC on the Shield though and it plays just fine.yeah ebr needs to fix this
FrostByte 5436 Posted March 15, 2020 Posted March 15, 2020 Might this be a limitation of exoplayer or is it the app/server? I've tried raw .dts files and I've tried remuxing dts music into .wav and .mka containers and nothing works on the Shield except VLC
Spaceboy 2573 Posted March 15, 2020 Posted March 15, 2020 Might this be a limitation of exoplayer or is it the app/server? I've tried raw .dts files and I've tried remuxing dts music into .wav and .mka containers and nothing works on the Shield except VLCif exo can play dts audio in video then my instinct is it must be possible. 1
ltworf13 3 Posted February 25, 2021 Posted February 25, 2021 has this been resolved yet. I would like to play my DTS wav files on my Shield TV android app
ebr 16309 Posted February 25, 2021 Posted February 25, 2021 13 minutes ago, ltworf13 said: has this been resolved yet. I would like to play my DTS wav files on my Shield TV android app Can you please try it with the current beta version of the app?
ltworf13 3 Posted February 25, 2021 Posted February 25, 2021 5 minutes ago, ebr said: Can you please try it with the current beta version of the app? sure thing where can I find the link to the beat app
ebr 16309 Posted February 25, 2021 Posted February 25, 2021 5 minutes ago, ltworf13 said: sure thing where can I find the link to the beat app Click on the link in the message you quoted .
ltworf13 3 Posted February 25, 2021 Posted February 25, 2021 ok i follow the android tv link and signed up for the beta tester. when I go to the playstore on my shield and search for Emby it show "Emby for Android TV(Beta)" so I'm assuming I now have the beta version. Do I need to reconfigure anything. I tried to play one of my wav files and it still plays in static
ebr 16309 Posted February 25, 2021 Posted February 25, 2021 5 minutes ago, ltworf13 said: ok i follow the android tv link and signed up for the beta tester. when I go to the playstore on my shield and search for Emby it show "Emby for Android TV(Beta)" so I'm assuming I now have the beta version. Do I need to reconfigure anything. I tried to play one of my wav files and it still plays in static Can you please confirm the version number of the app shown on its config page? It may or may not have updated immediately. If it is the beta ( >1.8.55) can you provide a sample file for testing?
ltworf13 3 Posted February 25, 2021 Posted February 25, 2021 4 minutes ago, ebr said: Can you please confirm the version number of the app shown on its config page? It may or may not have updated immediately. If it is the beta ( >1.8.55) can you provide a sample file for testing? version 1.8.55g registered
ebr 16309 Posted February 25, 2021 Posted February 25, 2021 27 minutes ago, ltworf13 said: version 1.8.55g registered Okay, that is the standard release. You may need to force an update on the device or wait until tomorrow when it will probably do it automatically.
ebr 16309 Posted February 25, 2021 Posted February 25, 2021 So that is a WAV file but it contains compressed DTS audio? WAV is supposed to be raw PCM and that is what it is interpreted as.
