deepac7 9 Posted February 28, 2020 Posted February 28, 2020 Hi,The libraries on emby app is arranged by default in the order of creation date/time. Clicked on user icon, only logout and switch server option is available.In settings, it's not available neither under "Home screen layout" nor under "General Display".How do I change the order of libraries on shieldTV app?
Solution Luke 42246 Posted February 28, 2020 Solution Posted February 28, 2020 Hi, you can do it from the web app and then it will use the same order. 1
deepac7 9 Posted February 28, 2020 Author Posted February 28, 2020 Thank you. Just did that and it works.
