aptalca 71 Posted April 27, 2020 Author Posted April 27, 2020 (edited) @@softworkz sorry, I should clarify, I tested v4l2 on the new kernel libreelec with emby so I can't confirm whether or not it's specific to emby because emby is all I tested it with. With regards to mmal, here's a log, but it's from "the other app" EDIT: removed link to log Edited April 27, 2020 by aptalca
softworkz 5133 Posted April 27, 2020 Posted April 27, 2020 Can you provide one from ours? Thanks. We don't have mmal included. The reason is that mmal is was only supported with a display context. As can be seen here: https://trac.ffmpeg.org/wiki/HWAccelIntro Look at the second table, column "Usable from ffmpeg CLI" That doesn't seem to accurate anymore. We can look into adding mmal support in the future. 1
heath600 4 Posted April 28, 2020 Posted April 28, 2020 @@softworkz Excited about the new possible decoding on the Pi4. Tried the latest build and it seems to error trying to use the decoder >>>>>> FindVideoDecoder - MediaType: h264, Mode: Custom Info Checking: 'OpenMax H.264' NoMatch Encoder is not compatible with 'None' decoders Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' Any chance of trying to get HEVC decoding working also?
softworkz 5133 Posted May 11, 2020 Posted May 11, 2020 Any chance of trying to get HEVC decoding working also? I'm not sure, could you please post the hw detection log?
heath600 4 Posted May 11, 2020 Posted May 11, 2020 (edited) Hardware Log attached. hardware_detection-63724521353.txt Edited May 11, 2020 by heath600
Luke 42246 Posted July 6, 2020 Posted July 6, 2020 @heath600 how does it compare with Emby Server 4.4.3?
heath600 4 Posted July 29, 2020 Posted July 29, 2020 If I recall correctly I was on 4.4.3 and it wasn't working so I updated to a 4.5.x.x version to see if it would help. Just tested on 4.5.0.15 and same issue.
