cTurtle98 1 Posted February 27, 2020 Posted February 27, 2020 hello the hdhomerun website says the connect was discontinued and replaced by the connect duo and connect quadro I cant tell if the extend is discontinued as well I only see comparisons between the original connect and the extend on the website but not the new ones the connect duo and extend are both 99.99 on amazon which one should I get?
kanipek 230 Posted February 27, 2020 Posted February 27, 2020 Depends on your need. The Extend will transcode on the fly if you need that capability. Sent from my SM-N900T using Tapatalk
cTurtle98 1 Posted February 27, 2020 Author Posted February 27, 2020 Depends on your need. The Extend will transcode on the fly if you need that capability. Sent from my SM-N900T using Tapatalk How do I know if I need transcoding on the fly?
kanipek 230 Posted February 28, 2020 Posted February 28, 2020 How do I know if I need transcoding on the fly? I think if you are asking about it you probably don't need it. But - If you are using CATV and most of your channels are mpeg2 it might be a consideration for you, if you transcode (from mpeg2 to mp4) them as they are being recorded you'll save space on your drive, if you keep the recordings long term you won't have to then convert them to save space, and this is being done by the tuner and therefore doesn't use any system resources. I personally use the connects. Does that help?
