keithwalker80 6 Posted February 26, 2020 Posted February 26, 2020 I know that this is a topic that has been touched on before but I could not find the information that I am looking for. Problem (Issue): I have 145 episodes of a specific series in a folder monitored by Emby. Only 100 of them will show on Emby. They are all named properly based on the recommended naming convention. Please see attached picture for naming convention. Could someone please help me figure out why it will not display passed the 100th episode?
Luke 42214 Posted February 26, 2020 Posted February 26, 2020 Hi there, what is the file and folder structure as well as naming? Thanks.
keithwalker80 6 Posted February 26, 2020 Author Posted February 26, 2020 Here is the path----- "D:\Cartoons\Boruto\Season 1\[Erai-raws] Boruto - Naruto Next Generations - 01 [720p][Multiple Subtitle].mkv"
Happy2Play 9806 Posted February 26, 2020 Posted February 26, 2020 To me they are not being parsed properly. So 100 appears as S01E00 and 101 appear as S01E01, grouping with episode 01 and so one. Okay I see what is happening, have you changed the Series level metadata Display Order to Absolute yet? If not this should resolve your issue as your episodes are in Absolute order, Aired parses 100 to S01E00. Edit metadata on Series 1
Happy2Play 9806 Posted February 26, 2020 Posted February 26, 2020 (edited) @@Luke since they are in a Season 1 folder should this really matter as 100 should be S01E100? Edited February 26, 2020 by Happy2Play
keithwalker80 6 Posted February 26, 2020 Author Posted February 26, 2020 I have tried the "Absolute" option and that did seem to fix the issue. Not sure why since the naming is not that way. Thanks guys!
Happy2Play 9806 Posted February 26, 2020 Posted February 26, 2020 I have tried the "Absolute" option and that did seem to fix the issue. Not sure why since the naming is not that way. Thanks guys! It sort of is as your naming is only a number (01) instead of 1x01, 101, or S01E01. But Luke will have to comment.
Luke 42214 Posted March 19, 2020 Posted March 19, 2020 @@keithwalker80 Are you still running into this?
Solution keithwalker80 6 Posted March 19, 2020 Author Solution Posted March 19, 2020 Putting it in absolute did seem to solve this. Sorry I forgot to say so. 1
