zeilercd 2 Posted February 26, 2020 Posted February 26, 2020 Hello - i ran into something strange yesterday. I have Emby on my Firestick - and LOVE ITBut yesterday - i was playing a show i'd already watched and it popped up this box partially transparent black box showing Playback Info and gave player, display mode, play method etc etc.I stopped the show - came back - still there went back to home screen on the first stick, loaded emby - started show - still theretried playing from beginning - still there...The first time i watched it - it was not there... (I fell asleep half way through- so was "rewatching" it hehe)i tried every menu button and setting i could find - and could not make it go awayfinally rebooted the firestick itself - and loaded into emby and voila, the "display box" was gone...But.. .if this happens in the future, is there some way to get rid of it WITHOUT restarting firestick?thanks in advance!screenshot of what i'm referring to is here - spent probably 30 min checking all menus and options and exit, reload, restart, start from beginning, try another show and come back (stayed there for next show too)... very annoying LOL https://gyazo.com/0f8d3a9efd23927731da599c5d6b3904
Luke 42246 Posted February 26, 2020 Posted February 26, 2020 HI there, can you attach the screenshot? Thanks.
Solution daedalus 434 Posted February 26, 2020 Solution Posted February 26, 2020 popping up by it self should be a bug there must be a menu option somewhere to "show statistics for nerds", that brings up that info box the webclient has it "behind" the cogwheel next to audio/subtitle selection buttons 1
zeilercd 2 Posted February 26, 2020 Author Posted February 26, 2020 (edited) seems it did not upload the photo? I'll try again...and checking for the "nerds" info in settings now...tried again - found picture - browse ok - send it to server - click ok - and says url is missing? sigh Edited February 26, 2020 by zeilercd
zeilercd 2 Posted February 26, 2020 Author Posted February 26, 2020 popping up by it self should be a bug there must be a menu option somewhere to "show statistics for nerds", that brings up that info box the webclient has it "behind" the cogwheel next to audio/subtitle selection buttons YES!!! cogwheel while playing it - bottom of list "stats for nerds" <3 THANK YOU!
ebr 16338 Posted February 26, 2020 Posted February 26, 2020 Hi. I don't think there is a bug here. My guess as to what happened is you accidentally triggered the shortcut to show that information. That is done by long-pressing the select/ok button on the remote. Could be a case of you leaning against or sitting on the remote... 2
