CBers 7554 Posted February 26, 2020 Posted February 26, 2020 (edited) Bug Fixes/Enhancements: Video/Display -Resolves issues detecting Dolby Vision TVs that also support HDR10+ -Resolves brightness issue on TVs that support Dolby Vision and HDR10+ -Resolves cast playback issues when switching between HDR and SDR content -Fixes bug where Dolby Vision would not be detected when connecting to some LG or Samsung soundbars -Fixes bug where screensaver would not be displayed in Netflix -Fixes bug where "Match Color Space" was not working properly on some TVs -Fixes stutter issue observed when playing interlaced video for ~15 minutes -Fixes system hang issue when enabling/disabling "Match content color space" while playing Dolby Vision content on Netflix -Reduces occurrences of red flashes when watching Dolby Vision content -Fixes bug where "Match frame rate" would not work on Dolby Vision content Audio -Disabling "Fixed Volume" will now disable Dolby audio processing -Fixes bug where Atmos streams would still be detected even if non-Atmos content is played -Fixes bug where audio would not be heard on Vizio TVs when streaming from VUDU/Movies Anywhere -Fixes bug where audio popping would be heard on headphones when Dolby audio processing is enabled -Resolves issue with high bit rate audio dropping audio at fixed locations. Note: This fixe will apply to apps using SHIELDs audio engine like -Plex/Photos & Videos. Kodi has its own engine which has not fixed this bug yet so the fix will not apply to Kodi and apps like it. -Adds 16-bit DAC support for Dolby Decoded content -Fixes bug where audio passthrough was not available over USB DAC on 3rd party apps like KODI (Requires KODI 18.5 or 18.6 nightly builds) -Fixes bug when manually setting "Audio formats" would not be applied -Fixes bug when using Google Home where volume would be reduced but not restored -Fixes rare bug where IR volume control would stop working -Resolves audio routing issues when using multiple USB devices (e.g. webcam + USB DAC) -Adds support for Sanskrit USB DAC -Fixes bug where PCM would be streamed if Dolby ATMOS is manually selected in "Available Formats" -Displays correct audio stream name under and adds detection support for EAC_JOC(DD+) streams (Settings -> Status-> HDMI ->Audio Mode) -Fixes bug where audio would not play after enabling PCM output only mode (Available formats) Network -Fixes issue transferring large files when connecting PC to SHIELD -Fixes bug where soft reboot would be seen when "Restart Wi-Fi" was selected Accessories -Adds support for XBOX Elite 2 controller -Add bluetooth support for WeChip G30 remote -Adds IR volume control support for Logitech Z906 speaker system -Fixes crash issues when accessory update notification is seen -Fixes bug where IR control setup would fail on Samsung AVR/soundbars -Fixes bug where IR control would not function when Talkback is enabled -Fixes bug where IR volume control would stop working when enabled -Fixes bug where remote locator would not work when SHIELD is asleep -Improves volume control for 2015 remote and controller -Fixes SHIELD Remote 2019 bug where battery would drain quickly when IR control enabled -Fixes bug where "send Menu command to app" was not working properly -Resolves pointer issue when using RS mouse on network captive portal registration -Fixes rare bug where pressing power button would not sleep SHIELD if video is playing -Improves SHIELD stability when connecting multiple Bluetooth devices Other -Fixes bug where "Dolby Vision" quick setting is not updated according to display setting -Channels DVR app can now store recorded content over NAS -Fixes bug where pre-installed apps would disappear -Fixes issue where long press home would not bring up NVIDIA Share -Fixes bug where settings would crash when selecting system language -Adds message informing user AI upscaling not available on rooted/unlocked devices -Fixes bug where "Ok Google" hotword activation requires reboot -Resolves rare bug where Netflix would crash when invoking app switcher (double press home) -Improves text when displaying most recent SHIELD wake event (Settings -> About -> Status -> Uptime) https://www.nvidia.com/en-us/geforce/forums/shield-tv/9/344754/2019-shield-experience-upgrade-811-released-22620/ . Edited February 26, 2020 by CBers
Sammy 791 Posted February 26, 2020 Posted February 26, 2020 Will this get rid of the annoying "Network Tuner Unavailable" notification that constantly nags me about every 30 seconds?
ebr 16338 Posted February 26, 2020 Posted February 26, 2020 Will this get rid of the annoying "Network Tuner Unavailable" notification that constantly nags me about every 30 seconds? Pretty sure that is coming from the "Channels" app. Check its configuration. 1
Sammy 791 Posted February 26, 2020 Posted February 26, 2020 Pretty sure that is coming from the "Channels" app. Check its configuration.I have multiple times on multiple shields. I should just remove the app. Sent from my SM-G960U1 using Tapatalk
mastrmind11 722 Posted February 26, 2020 Posted February 26, 2020 Will this get rid of the annoying "Network Tuner Unavailable" notification that constantly nags me about every 30 seconds? oh my god so it's not just me! I thought it was network related. Uninstalling Channels when I get home. 1
FrostByte 5454 Posted February 26, 2020 Posted February 26, 2020 Downloading now. Got several updates today for testing. Busy busy busy
kikinjo 294 Posted February 26, 2020 Posted February 26, 2020 Updated my 2019 pro few h ago. Nothing broken (yet)
CBers 7554 Posted February 27, 2020 Author Posted February 27, 2020 Downloading now. Got several updates today for testing. Busy busy busy I hope the 2015/2017 versions get an update and are not now long-lost devices.
Sammy 791 Posted February 27, 2020 Posted February 27, 2020 (edited) Pretty sure that is coming from the "Channels" app. Check its configuration.Apparently the app cannot be uninstalled only have updates rolled back. I've done that and rescanned channels and the problem persists. Maybe this has to do with the loss and replacement of a HDHomeRun Connect Quatro recently. Is Channels just unable to adjust to this? Nowhere does it expose the ip address of the tuners themselves to check. Hmm. I did disable the app and turned off notifications for it too. Sent from my SM-G960U1 using Tapatalk Edited February 27, 2020 by Sammy
Sammy 791 Posted February 27, 2020 Posted February 27, 2020 I hope the 2015/2017 versions get an update and are not now long-lost devices.I'm not seeing an update even when manually checking for it on at least two of my 2017 ShieldTV's. [emoji848][emoji52][emoji19] Sent from my SM-G960U1 using Tapatalk 1
mastrmind11 722 Posted February 27, 2020 Posted February 27, 2020 I did disable the app and turned off notifications for it too. Sent from my SM-G960U1 using Tapatalk Did that work?
Sammy 791 Posted February 27, 2020 Posted February 27, 2020 Did that work?I didn't see the notification in about 30 minutes of watching LiveTV on Emby. Sent from my SM-G960U1 using Tapatalk 1
