Webdoc 2 Posted February 25, 2020 Posted February 25, 2020 Hello UK channels virgin east mids Is there a list with the used abbreviations and the full names of channels, as it takes sometime with some of them to decipher what they are. Thanks
Luke 42237 Posted March 3, 2020 Posted March 3, 2020 Hi there @@Webdoc, what zip code and lineup did you select?
Webdoc 2 Posted March 4, 2020 Author Posted March 4, 2020 Hello @@ebr I used UK LE18 and united kingdom
NeilD7744 3 Posted March 30, 2020 Posted March 30, 2020 Hello mate, I use this for getting the EPG numbers based on Emby's EPG data from SKY HD National: https://www.tvchannellists.com/List_of_channels_on_Sky_(UK_and_Ireland) I ignore the channel description names within Emby and just use the EPG numbers as reference (HD, SD & +1). Works fine for me. Hope this helps. Neil.
wp.rauchholz 5 Posted May 17, 2020 Posted May 17, 2020 Hi, I do have the same question. I'd like to map the channels in US and UK, but can't find fomr some the equivalent abbreviations. Where can I find these? I use ZIP EC1A for US and 60007 for US. Thanks for your help. Wolfgang
Luke 42237 Posted May 17, 2020 Posted May 17, 2020 Hi, I do have the same question. I'd like to map the channels in US and UK, but can't find fomr some the equivalent abbreviations. Where can I find these? I use ZIP EC1A for US and 60007 for US. Thanks for your help. Wolfgang For US you just enter the 60007 zip code.
