JustEric78 24 Posted February 25, 2020 Posted February 25, 2020 @@Luke @@ebr I have been working with Derek over at https://sequematic.com/ to automate my lights turning on and off based off of the event that Emby sends over. I will be posting a write up on how to get this setup for other users but in the meantime, we found that a hook is not sent for pause or resume. I will still add those steps in my write up with the caveat that it is currently not working for those two commands. On a side note, out of my ignorance, what is the scrobble event? I have not set that up so depending on what it is supposed to do, I will add that to the write up. 1
JustEric78 24 Posted February 25, 2020 Author Posted February 25, 2020 What emby app are you testing with? @@ebr Windows Server 2012 R2 and an Nvidia Shield for playback
ebr 16346 Posted February 25, 2020 Posted February 25, 2020 Please test this with the next release of the app. Thanks. 2
JustEric78 24 Posted February 25, 2020 Author Posted February 25, 2020 Thank you @@ebr Thank you, in that case I will leave that functionality baked into the sequence that I posted about separately in the home automation section.
pir8radio 1313 Posted March 13, 2020 Posted March 13, 2020 (edited) OOPS WRONG THREAD Edited March 13, 2020 by pir8radio
MRobi 161 Posted March 14, 2020 Posted March 14, 2020 @@ebr I'm using version: 1.7.92g and am seeing a pause event but not the unpause event
ebr 16346 Posted March 14, 2020 Posted March 14, 2020 @@ebr I'm using version: 1.7.92g and am seeing a pause event but not the unpause event In exactly what context?
MRobi 161 Posted March 14, 2020 Posted March 14, 2020 In exactly what context? Using the web app I get a playback.unpause event with webhooks. Using the Android app I do not. I only get playback.start, playback.stop and playback.pause 1
ebr 16346 Posted March 16, 2020 Posted March 16, 2020 Using the web app I get a playback.unpause event with webhooks. Using the Android app I do not. I only get playback.start, playback.stop and playback.pause Playing what?
MRobi 161 Posted March 16, 2020 Posted March 16, 2020 Playing what? TV Episode I didn't test with movies or music. I can give those a test this evening.
JustEric78 24 Posted March 16, 2020 Author Posted March 16, 2020 (edited) Is the pause/resume triggers supposed to be working now? Unless I have the hooks worded wrong, they are still not working for me via an Nvidia Shield and Server 2012 R2. Currently I have it looking for playback.pause and playback.resume Edited March 16, 2020 by JustEric78
MRobi 161 Posted March 16, 2020 Posted March 16, 2020 (edited) @@ebr @@Luke TV Series: I receive playback.start, playback.stop, playback.pause I do not receive playback.unpause Movies I receive playback.start, playback.stop, playback.pause I do not receive playback.unpause Music I receive playback.start and playback.stop When paused it sends a playback.stop followed immediately by playback.scrobble When resumed it sends a playback.start instead of playback.unpause This is android tv only. On the android mobile app they all work as expected. Another thing I've noticed in my testing is that the webhooks seem to stop sending after the server has been running a while. To do the above test I had to reboot the server and I noticed the same thing yesterday as well. I'll pull the logs if I notice it persists. @@JustEric78 you should be looking for playback.unpause not resume. playback.pause is working Edited March 16, 2020 by MRobi
MRobi 161 Posted March 16, 2020 Posted March 16, 2020 @@Luke 4:58pm and currently watching Westworld S03E01 Last webhook was sent at 3:11pm and you can see numerous playback starts and stops afterwards. In the logs though I don't even see where Westworld even started to be played. You can see the playback start reported at 16:55 but no details in logs showing what it was. embyserver.txt
Luke 42255 Posted March 16, 2020 Posted March 16, 2020 Thanks, looks like the app needs to be updated to send the unpause event.
ebr 16346 Posted March 16, 2020 Posted March 16, 2020 Music I receive playback.start and playback.stop When paused it sends a playback.stop followed immediately by playback.scrobble When resumed it sends a playback.start instead of playback.unpause Perhaps we just need to send unpause in addition to start here because there is no distinction with music between pausing and stopping. How do you treat unpause differently from start?
MRobi 161 Posted March 16, 2020 Posted March 16, 2020 Perhaps we just need to send unpause in addition to start here because there is no distinction with music between pausing and stopping. How do you treat unpause differently from start? In my specific use case I treat an unpause exactly the same as a start. But I can't speak for everyone. Others may have a better use for it. I only mention it for consistency since android mobile sends an unpause while android tv sends a start. switch(status) { case ["playback.start","playback.unpause"]: status = "playing"; break; case ["playback.pause"]: status = "paused"; break; case ["playback.stop","playback.scrobble"]: status = "stopped"; break; }
JustEric78 24 Posted March 17, 2020 Author Posted March 17, 2020 In my specific use case I treat an unpause exactly the same as a start. But I can't speak for everyone. Others may have a better use for it. I only mention it for consistency since android mobile sends an unpause while android tv sends a start. switch(status) { case ["playback.start","playback.unpause"]: status = "playing"; break; case ["playback.pause"]: status = "paused"; break; case ["playback.stop","playback.scrobble"]: status = "stopped"; break; Same, pause is the same as stop and unpause is the same as start.
ebr 16346 Posted March 17, 2020 Posted March 17, 2020 The thing is "stop" just doesn't exist in the current world of music players. I doubt you can show me one with a stop button on the interface. But, as far as actual operation (from the computer's standpoint) goes, it makes more sense to me to treat the pause of music as a stop because that is the only way to stop a current music player.
MRobi 161 Posted March 18, 2020 Posted March 18, 2020 The thing is "stop" just doesn't exist in the current world of music players. I doubt you can show me one with a stop button on the interface. But, as far as actual operation (from the computer's standpoint) goes, it makes more sense to me to treat the pause of music as a stop because that is the only way to stop a current music player. Is it possible for pause to be sent when paused and stop to be sent when backing out of the music screen? Otherwise I do agree that leaving it as-is for music would be best with just start/stop and add the unpause to tv and movies.
ebr 16346 Posted March 21, 2020 Posted March 21, 2020 Is it possible for pause to be sent when paused and stop to be sent when backing out of the music screen? Backing out of the music screen does not stop music playback.
