PhantomCircuit 6 Posted February 25, 2020 Posted February 25, 2020 Hi,i have a mp3 playback quality issue where the audio will have a pause every second. Android 9 or 10 will have same problem. However, it work fine on iPhone and Web browser. Please let me know if i can send you a copy of the audio file? Thanks
Luke 42244 Posted March 3, 2020 Posted March 3, 2020 Hi, what device are you testing on? The file is playing OK for me. Are you inside or outside of your local network when playing?
PhantomCircuit 6 Posted March 4, 2020 Author Posted March 4, 2020 Hi, what device are you testing on? The file is playing OK for me. Are you inside or outside of your local network when playing? on Android, iPhone and Web Player. I am on outside network as the server is hosted. it only occur on Android app.
Luke 42244 Posted March 4, 2020 Posted March 4, 2020 Then try lowering the internet music quality setting. Anytime you get stuttering it usually means the bitrate is too high.
PhantomCircuit 6 Posted March 4, 2020 Author Posted March 4, 2020 i change it to the lowest - 64kbps, close and relaunch the android app and it's still the same. no problem on iphone app and web player
Luke 42244 Posted March 4, 2020 Posted March 4, 2020 Ok I'll see if I can think of anything but I'm not seeing any problems here with that file on a remote connection. You could always use the download feature to have a local copy of it.
PhantomCircuit 6 Posted March 6, 2020 Author Posted March 6, 2020 which android phone you using ? i download the audio and it's still the same.
