MBSki 1115 Posted August 4, 2020 Posted August 4, 2020 @Luke This still seems to be an issue in the latest .25 beta.
MBSki 1115 Posted August 16, 2020 Posted August 16, 2020 @Luke This is still an issue. Can you please fix this?
DJX 18 Posted September 29, 2020 Posted September 29, 2020 Hi Any update on this? On my android, I able to scroll down. But if I try scroll up, it does the refresh instead and reloads the current directory.
Luke 42244 Posted September 29, 2020 Posted September 29, 2020 We're looking into it. Thanks for reporting. 1
DJX 18 Posted October 20, 2020 Posted October 20, 2020 Hi. Just want to update that on a Sony Xperia XZ, the scrolling issue doesn't exist, but on my Samsung S7, it does. (If I scroll down in a folder, and let my finger off the display, I am stuck there. Trying to scroll up causes the page to refresh)
Luke 42244 Posted October 20, 2020 Posted October 20, 2020 6 hours ago, DJX said: Hi. Just want to update that on a Sony Xperia XZ, the scrolling issue doesn't exist, but on my Samsung S7, it does. (If I scroll down in a folder, and let my finger off the display, I am stuck there. Trying to scroll up causes the page to refresh) That's very helpful. Thanks for the info.
Richard Branches 338 Posted October 20, 2020 Author Posted October 20, 2020 It's been months (since may) that we don't receive an update of the Android mobile app, are you prepping something new?
Luke 42244 Posted October 20, 2020 Posted October 20, 2020 29 minutes ago, Richard Branches said: It's been months (since may) that we don't receive an update of the Android mobile app, are you prepping something new? Yes. You can explore the testing area of the community to learn about it.
Richard Branches 338 Posted October 20, 2020 Author Posted October 20, 2020 Hope you finally add the features I've been waiting for so long...
Richard Branches 338 Posted October 20, 2020 Author Posted October 20, 2020 (edited) 4 hours ago, Luke said: Yes. You can explore the testing area of the community to learn about it. I signed up for the mobile beta and I still don't see implemented what I requested... I'll keep waiting then The issue in this topic is still present in latest 3.1.44 beta as well. Edited October 20, 2020 by Richard Branches
Luke 42244 Posted November 13, 2020 Posted November 13, 2020 Can you try the new 3.1.59 release? How does that compare?
Richard Branches 338 Posted November 13, 2020 Author Posted November 13, 2020 If that's a beta please share the link to download the apk, I'm not signed up anymore, thank you.
Richard Branches 338 Posted November 13, 2020 Author Posted November 13, 2020 Oh, I checked a few minutes ago and still wasn't available. I just installed it and unfortunately the problem is still there, it's not that heavy like before but scrolling is not fluid, it stops at any point of the list abruptly, when I scroll down it still gets scrolled up by its own.
DJX 18 Posted November 13, 2020 Posted November 13, 2020 (edited) I just updated it on my S7. The app crashes every time I open it up This is all the log file has Fri Nov 13 16:15:16 GMT+00:00 2020 AndroidCredentialManager: null or empty credentials Fri Nov 13 16:15:16 GMT+00:00 2020 Scheduled periodic work 'EmbyCameraUpload' with id = 'ece79bb8-2d68-4061-b44a-070f771fab9c' Fri Nov 13 16:15:16 GMT+00:00 2020 Scheduled periodic work 'EmbyAppSync' with id = 'f9ab8a1f-ae9b-4406-bee3-f065e1498bab' Fri Nov 13 16:15:16 GMT+00:00 2020 Scheduled content uri trigger work 'EmbyCameraUpload' with id = 'f07b4dc0-b057-4425-b611-501313224d08' Fri Nov 13 16:15:16 GMT+00:00 2020 External dir: /storage/emulated/0/Android/data/com.mb.android/files isExternalStorageEmulated: true isExternalStorageRemovable: false Fri Nov 13 16:15:16 GMT+00:00 2020 External dir: /storage/6463-6130/Android/data/com.mb.android/files isExternalStorageEmulated: false isExternalStorageRemovable: true Fri Nov 13 16:15:16 GMT+00:00 2020 Environment.getExternalStorageDirectory: /storage/emulated/0 Fri Nov 13 16:15:16 GMT+00:00 2020 MediaBrowser.connect Edited November 13, 2020 by DJX Log
Luke 42244 Posted November 13, 2020 Posted November 13, 2020 17 minutes ago, DJX said: I just updated it on my S7. The app crashes every time I open it up This is all the log file has Fri Nov 13 16:15:16 GMT+00:00 2020 AndroidCredentialManager: null or empty credentials Fri Nov 13 16:15:16 GMT+00:00 2020 Scheduled periodic work 'EmbyCameraUpload' with id = 'ece79bb8-2d68-4061-b44a-070f771fab9c' Fri Nov 13 16:15:16 GMT+00:00 2020 Scheduled periodic work 'EmbyAppSync' with id = 'f9ab8a1f-ae9b-4406-bee3-f065e1498bab' Fri Nov 13 16:15:16 GMT+00:00 2020 Scheduled content uri trigger work 'EmbyCameraUpload' with id = 'f07b4dc0-b057-4425-b611-501313224d08' Fri Nov 13 16:15:16 GMT+00:00 2020 External dir: /storage/emulated/0/Android/data/com.mb.android/files isExternalStorageEmulated: true isExternalStorageRemovable: false Fri Nov 13 16:15:16 GMT+00:00 2020 External dir: /storage/6463-6130/Android/data/com.mb.android/files isExternalStorageEmulated: false isExternalStorageRemovable: true Fri Nov 13 16:15:16 GMT+00:00 2020 Environment.getExternalStorageDirectory: /storage/emulated/0 Fri Nov 13 16:15:16 GMT+00:00 2020 MediaBrowser.connect Hi, is that the only log file?
DJX 18 Posted November 13, 2020 Posted November 13, 2020 (edited) 1 hour ago, Luke said: Hi, is that the only log file? Yup As it wasnt working after updating, i did a fresh install including cleaning the data and cache partition. Thats why the old logs went! EDIT: Is there any way to download the older version? Edited November 13, 2020 by DJX
DJX 18 Posted November 15, 2020 Posted November 15, 2020 Update. Downloaded the APK with fix for android 8.0.0 and scrolling works for me now! Thank you!!!
