Richard Branches 338 Posted February 25, 2020 Posted February 25, 2020 (edited) I'm getting vertical and horizontal scrolling problems on the latest Android mobile app (3.0.97) on a Moto E6 Plus phone. Edited October 20, 2020 by Richard Branches
Luke 42244 Posted February 25, 2020 Posted February 25, 2020 Hi there, can you please describe the issue?
Richard Branches 338 Posted February 25, 2020 Author Posted February 25, 2020 When I try to scroll down through the list, it goes back to the top again, when I try to move left or right through the tabs, it goes back to the one selected, it's very annoying.
Luke 42244 Posted February 25, 2020 Posted February 25, 2020 Ok, please try again with the next update to the app. Thanks.
Richard Branches 338 Posted March 7, 2020 Author Posted March 7, 2020 Ok, please try again with the next update to the app. Thanks. Today I received an update to version 3.1.5 and this problem is not fixed.
Luke 42244 Posted March 7, 2020 Posted March 7, 2020 Please try again with the next update to the app. Thanks.
Richard Branches 338 Posted March 9, 2020 Author Posted March 9, 2020 Still nothing on version 3.1.7...
Richard Branches 338 Posted March 9, 2020 Author Posted March 9, 2020 (edited) Deleted. Edited August 30, 2020 by Richard Branches
Luke 42244 Posted March 9, 2020 Posted March 9, 2020 OK thanks. Does that only happen in the Songs tab or does that happen elsewhere? What version of android does that run?
Richard Branches 338 Posted March 9, 2020 Author Posted March 9, 2020 (edited) OK thanks. Does that only happen in the Songs tab or does that happen elsewhere? It happens everywhere inside the app. What version of android does that run? It's Android 9.0. Edited March 9, 2020 by Richard Branches
Luke 42244 Posted March 10, 2020 Posted March 10, 2020 Do you have any accessibility settings enabled on the device that might impact this?
Luke 42244 Posted March 10, 2020 Posted March 10, 2020 What version of the Android system webview app do you have?
Richard Branches 338 Posted March 26, 2020 Author Posted March 26, 2020 Still no fix on version 3.1.12 . Please don't ask me for another video, it's the same as the previous one.
Luke 42244 Posted March 26, 2020 Posted March 26, 2020 Apologies. I believe you, I just haven't seen this happen yet. It is probably device specific.
godfuture 5 Posted June 17, 2020 Posted June 17, 2020 The vid is not available anymore, therefore i simply explain my experiences.. I have issues with scrolling, too. Scrolling down (moving finger up) is fine, but trying to go back does not work (only if you go quickly down and "throwing" up the screen immediatly). Trying to scroll up (moving finger down) triggers a page refresh. A refresh sets you back to start. I noticed this is not happening to my movie or series library, but to mixed folders.
Luke 42244 Posted June 18, 2020 Posted June 18, 2020 We'll look into improving it. Thanks for the feedback.
Richard Branches 338 Posted June 18, 2020 Author Posted June 18, 2020 (edited) 18 hours ago, godfuture said: The vid is not available anymore, therefore i simply explain my experiences. Sorry!, I deleted the video, I always assume Emby devs download them immediately so I delete it after a few days, won't happen again until an issue is fixed. Edited June 18, 2020 by Richard Branches
Richard Branches 338 Posted June 18, 2020 Author Posted June 18, 2020 You can use this app to record the screen, then share it here: https://play.google.com/store/apps/details?id=com.kimcy929.screenrecorder
MBSki 1115 Posted June 20, 2020 Posted June 20, 2020 I have the same problem. it's been like this for months. The main issue seems to be trying to scroll back up after scrolling down. Same as @godfuture Mentioned. I'm on v3.1.23 and Moto G6 Plus.
