C_J 1 Posted February 24, 2020 Posted February 24, 2020 1. Is there a way to load artists with pictures only but without artist info. The info provided by musicbrainz is often too long. 2. which metadata downloader must be enabled to load artist pictures?
Luke 42241 Posted February 24, 2020 Posted February 24, 2020 2. which metadata downloader must be enabled to load artist pictures? Hi, the available image fetchers are shown in your library settings. Does this answer your question?
Luke 42241 Posted February 24, 2020 Posted February 24, 2020 1. Is there a way to load artists with pictures only but without artist info. The info provided by musicbrainz is often too long. The descriptions actually generally come from audiodb and lastfm. You could try turning those off if you really want to.
C_J 1 Posted February 25, 2020 Author Posted February 25, 2020 Hi, the available image fetchers are shown in your library settings. Does this answer your question? Hi, thanks. All metadata downloaders and image data fetchers are enabled. Album images are loaded but artist pictures not.
Luke 42241 Posted February 25, 2020 Posted February 25, 2020 We'd have to go over an example. Did you ensure that your artists have musicbrianz id's assigned?
C_J 1 Posted February 28, 2020 Author Posted February 28, 2020 We'd have to go over an example. Did you ensure that your artists have musicbrianz id's assigned? Thanks, I reinstalled the program, and most artists are shown now. I have only musicbrainz and audiodb, no plugins and no lastfm.
