uspider7 17 Posted June 24, 2014 Posted June 24, 2014 Not the media folders, I was able to get those to show up, these are the views generated by Mediabrowser server, which have default icons which after inspecting the html code appear to being pulled from C:\Users\<UserID>\AppData\Roaming\MediaBrowser-Servera\System\dashboard-ui\css\images\items\list All the list views (Moves, Tv, Channels..etc) are pointing to the default "collections.png" file, the other ones are missing from the directoy above, but adding them from another server install didn't help.
Luke 42180 Posted June 24, 2014 Posted June 24, 2014 just mouse over them, click the edit pencil and update them.
uspider7 17 Posted June 24, 2014 Author Posted June 24, 2014 yeah got it figured out... it was a combination of my proxy server and the fact that windows 2012r2 has a "Internet Explorer Enhanced Security Configuration" enabled by default, which was creating some issues when trying to grab them from https://raw.githubusercontent.com/MediaBrowser/MediaBrowser.Resources/master/images/folders/movies.jpg thanks for the help.
uspider7 17 Posted June 24, 2014 Author Posted June 24, 2014 Hope someone has some idea as to how I can fix the missing images for the "My Views" collections (see screenshot). Just want to say that I did move the server folder to a new server (better hardware), I do understand that this is not supported but everything is good so far accept for those missing images. Any help is appreciated.
Happy2Play 9798 Posted June 25, 2014 Posted June 25, 2014 Luke explained it here. http://mediabrowser.tv/community/index.php?/topic/8271-mbs-media-folder-icons/?p=109108
BATTLE DONKEY 98 Posted June 25, 2014 Posted June 25, 2014 If you mean switch to icons you have already placed in media browser, click the pencil beside the my views heading, then click web client, finally under home page setting one: switch it to "media folders"
