Arkapravo 0 Posted February 24, 2020 Posted February 24, 2020 (edited) hey sorry at first place i may hear stupid..but apparently i was so frustrated about not able to use samba(not of the emby's) on my pc after a furious uninstallation,i removed every file with a 'samba' in it.then i realized i deleted a whole lot of emby server files also.. :'''( i am completely screwed up right now...i have tried everything from uninstalling with 'apt remove' then installing,'apt --autoremove remove' then installing, even 'apt --autoremove purge' then installing again..nothing is working whatsoever.the server is firing up and i can browse it through http://localhost:8096 in my pc but that's it. cant access from any other device in my network. please fix anyway.. _/\_ please don't say it can't be fixed. thanks in advance Edited February 24, 2020 by Arkapravo
sfatula 208 Posted February 24, 2020 Posted February 24, 2020 And, I presume the most basic item there is, backups, none?
Arkapravo 0 Posted February 24, 2020 Author Posted February 24, 2020 conviniently, No, I don't.i didn't realize i would mess up so badly.
mastrmind11 722 Posted February 24, 2020 Posted February 24, 2020 if you can access it from localhost, then it's not an emby issue. Did your IP change?
Arkapravo 0 Posted February 24, 2020 Author Posted February 24, 2020 I don't know what exactly did this,but, YAY!! it fixed..,tried so many things but exactly what fixed this, idk. so desparate i was, even tried plex...*it was awful* but i can wildly guess, that it might be some firewall issue..while deleting those samba files i might have deleted some firewall rules [don't know how is that possible], but allowing the 8096 port or maybe another change, its working well again.
sfatula 208 Posted February 24, 2020 Posted February 24, 2020 (edited) Better get backup going now, lol. It is hard to guess what you may have done, so many ways to break things. Edited February 24, 2020 by sfatula
Arkapravo 0 Posted February 25, 2020 Author Posted February 25, 2020 Better get backup going now, lol. It is hard to guess what you may have done, so many ways to break things. I definitely want to take backup, but can i back up server with out emby premiere? If i can, can you please let me know how..?? \
Luke 42246 Posted February 25, 2020 Posted February 25, 2020 I definitely want to take backup, but can i back up server with out emby premiere? If i can, can you please let me know how..?? \ Hi there, our backup guide can be found here: https://support.emby.media/support/solutions/articles/44001159936-backup We work very hard on Emby and we thank you for your support.
Arkapravo 0 Posted February 25, 2020 Author Posted February 25, 2020 Hi there, our backup guide can be found here: https://support.emby.media/support/solutions/articles/44001159936-backup We work very hard on Emby and we thank you for your support. so without premiere, no backup?
sfatula 208 Posted February 25, 2020 Posted February 25, 2020 You can use any system software you want. I take a server image every 3 months with Clonezilla and store it in bank vault, I use Back In Time, I use Raidz2 (not a backup really), and I use Duplicati to store offline at B2 Cloud. There are lots and lots of backup software out there. Backing up Emby does you little good if you lose your server with some accident or whatever and have to start over.
Luke 42246 Posted February 25, 2020 Posted February 25, 2020 so without premiere, no backup? You can still backup manually.
Arkapravo 0 Posted February 25, 2020 Author Posted February 25, 2020 You can use any system software you want. I take a server image every 3 months with Clonezilla and store it in bank vault, I use Back In Time, I use Raidz2 (not a backup really), and I use Duplicati to store offline at B2 Cloud. There are lots and lots of backup software out there. Backing up Emby does you little good if you lose your server with some accident or whatever and have to start over. nope, backing up config will be enough, i dont use raid and chances of server blowing up is fat.. so any help with config backup? any how-to?
Arkapravo 0 Posted February 25, 2020 Author Posted February 25, 2020 You can still backup manually. yes, please, tell me the process man...
