PlayOn Integration: aka Netflix and Hulu on MB
The developer says earlier in the thread that the plugin requires a development server build.
saitoh183
yeah, you need to change to Dev if you want it
snazy2000
You should now see the plugin in the catalog even if your on release
  • Like 1
saitoh183
Yup...did a refresh and its there now
  • Like 1
Bear on the job
Doesn't seem to be working. I have PlayOn running on same machine as MBS, installed the PlayOn plugin, and configured it to point to 127.0.0.1. The PlayOn plugin shows up in my Channel list for MBS, but when I open it, there are 0 items listed. I can see the normal PlayOn content from other devices on the network when browsing over DLNA. But the MBS plugin always shows 0 items.
snazy2000
Try restarting MBS
Sent from my HTC One using Tapatalk
Bear on the job
Yeah I restarted MBS a couple of times. And just to be clear, this issue is happening in the web interface (right-click MBS tray icon, choose "Browse Library"). I tried opening the web interface in multiple browsers, but it still shows 0 items for the PlayOn plugin. Other channel plugins work fine, like Twitch and ITV.
