tsunami1701 6 Posted February 21, 2020 Posted February 21, 2020 Hi experts, I don't want a domain for my server so it seems impossible to have a certificate for secure connections. Which are the risks? Can I create a special user in windows to be used in emby to limit the access only to media server and media folder like I do with shared folders? Are there other possible solutions? Thanks!!
mastrmind11 722 Posted February 21, 2020 Posted February 21, 2020 (edited) Assuming you're referring to external connections, you don't need a domain for a cert. https://letsencrypt.org/ Self signed certs aren't ideal, but they work for most things. You can also get a dynamic dns address and a real cert from Cloudflare. Plenty of documentation on the interwebs for both approaches. Edited February 21, 2020 by mastrmind11
pwhodges 2028 Posted February 21, 2020 Posted February 21, 2020 It's true that LetsEncrypt do not issue certificates for IP addresses. A few registries do still, and of course you can generate your own self-signed certificate (with the limitations that brings of not being automatically trusted). However, it seems to me to be perverse to want a secure connection, but to want not to have the usual means of specifying it (using a domain). Not having a domain doesn't change the risks involved, though - such as they are. And why so you want a special user to Windows to limit access to Emby? Emby already has a user login system for controlling access. Paul
lordfiSh 0 Posted February 22, 2020 Posted February 22, 2020 You can use - a SSH-Reverse Tunnel - VPN like OpenSSH or Wireguard - just use a Self-Singed Certificate Question is why don't want a (Sub-)Domain? Also you may be better off, if you don't know what are you doing.
