paddl82 5 Posted February 21, 2020 Posted February 21, 2020 Hallo zusammen. Ich habe in meinem Content-Ordnern einige Ordner mehr als Serien/Filme in meiner Emby-Bibliothek. Nach was muss ich in der Emby-Log schauen um herauszufinden welche Serien/Filme er nicht gescannt hat? Gruß paddl82 @@Happy2Play @@cayars
Carlo 4561 Posted February 21, 2020 Posted February 21, 2020 You could look for "error" in the log but probably the best method will be to compare the directories to what shows up in your TV library.
paddl82 5 Posted February 24, 2020 Author Posted February 24, 2020 I try to avoid that. There are several hundred folders Any other options?
Happy2Play 9811 Posted February 24, 2020 Posted February 24, 2020 It is really hard to say. You would have to go over a specific example covering folder content and naming schemes. Es ist wirklich schwer zu sagen. Sie müssten ein bestimmtes Beispiel durchgehen, das Ordnerinhalte und Namensschemata abdeckt.
