Anixd 9 Posted February 20, 2020 Author Posted February 20, 2020 sir, this time IPv4 address changed to 192.168.1.8 C:\Users\Additional Director>ping 192.168.1.2Pinging 192.168.1.2 with 32 bytes of data:Reply from 192.168.1.8: Destination host unreachable.Reply from 192.168.1.8: Destination host unreachable.Reply from 192.168.1.8: Destination host unreachable.Reply from 192.168.1.8: Destination host unreachable.Ping statistics for 192.168.1.2:Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),C:\Users\Additional Director>ipconfigWindows IP ConfigurationEthernet adapter Ethernet:Connection-specific DNS Suffix . :Link-local IPv6 Address . . . . . : fe80::cbe:b91d:b190:9ba0%11IPv4 Address. . . . . . . . . . . : 192.168.1.8Subnet Mask . . . . . . . . . . . : 255.255.255.0Default Gateway . . . . . . . . . : fe80::1%11192.168.1.1
maegibbons 1287 Posted February 20, 2020 Posted February 20, 2020 Ok this is a basic network failure. From the server PC can you see the internet? Can you ping 192.168.1.1 from server? Krs Mark Sent from my SM-N976B using Tapatalk
Anixd 9 Posted February 20, 2020 Author Posted February 20, 2020 (edited) here are ping result from server PC of 192.168.1.1 and 192.168.1.2 normal internet is working fine on both laptop and pc C:\Users\ZEN>ping 192.168.1.1 Pinging 192.168.1.1 with 32 bytes of data: Reply from 192.168.1.1: bytes=32 time<1ms TTL=64 Reply from 192.168.1.1: bytes=32 time<1ms TTL=64 Reply from 192.168.1.1: bytes=32 time<1ms TTL=64 Reply from 192.168.1.1: bytes=32 time<1ms TTL=64 Ping statistics for 192.168.1.1: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 0ms, Maximum = 0ms, Average = 0ms C:\Users\ZEN>ping 192.168.1.2 Pinging 192.168.1.2 with 32 bytes of data: Reply from 192.168.1.2: bytes=32 time<1ms TTL=128 Reply from 192.168.1.2: bytes=32 time<1ms TTL=128 Reply from 192.168.1.2: bytes=32 time<1ms TTL=128 Reply from 192.168.1.2: bytes=32 time<1ms TTL=128 Ping statistics for 192.168.1.2: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 0ms, Maximum = 0ms, Average = 0ms Edited February 20, 2020 by Anixd
maegibbons 1287 Posted February 20, 2020 Posted February 20, 2020 Pinging 192.168.1.2 is itself so should always work. Can you see internet from laptop? If so then EITHER there is still a firewall running on the ROUTER or on the server PC. If it was working before router change then probably Router. If you are sure ALL firewalls are off on PC then it has to be router. So you would need to ask on router forum what issue could be. Point them to this thread so they can see diagnostic steps taken this far. Otherwise get another router!! Out of the box it really shouldnt be that complicated. Krs Mark Sent from my SM-N976B using Tapatalk
