Happy2Play 9802 Posted January 28, 2021 Posted January 28, 2021 1 minute ago, wakeboarder141 said: No luck with Fade to Black so I will keep looking. You could move it out of the folder it is in and Emby will remove it from the database by Realtime Monitoring or a library scan. Do you save nfo files with media? If so open that nfo file from that movie folder. Otherwise we need the server log for when the item was imported into Emby.
wakeboarder141 40 Posted January 28, 2021 Posted January 28, 2021 4 minutes ago, Happy2Play said: You could move it out of the folder it is in and Emby will remove it from the database by Realtime Monitoring or a library scan. Do you save nfo files with media? If so open that nfo file from that movie folder. Otherwise we need the server log for when the item was imported into Emby. It was suggested that I change to using the nfo files so I will try that when I get home. Thanks for all the suggestions.
wakeboarder141 40 Posted January 28, 2021 Posted January 28, 2021 Got it! Not sure where it was hiding, but I pulled it out of the folder, renamed it "IT (1990) [imdbid=tt0099864]" with all of the metadata providers enabled, ran a library scan, and it popped right up just like it should. Then I added it to my IT collection, and it caused both of the other IT movies to disappear so I'm still fighting my collections problem, but at least that one movie is solved.
Happy2Play 9802 Posted January 28, 2021 Posted January 28, 2021 (edited) 10 minutes ago, wakeboarder141 said: Got it! Not sure where it was hiding, but I pulled it out of the folder, renamed it "IT (1990) [imdbid=tt0099864]" with all of the metadata providers enabled, ran a library scan, and it popped right up just like it should. Then I added it to my IT collection, and it caused both of the other IT movies to disappear so I'm still fighting my collections problem, but at least that one movie is solved. Can you post the server log for this action. If you search "it" does is return results? Also has a scheduled task library scan finished? Edited January 28, 2021 by Happy2Play
wakeboarder141 40 Posted January 28, 2021 Posted January 28, 2021 Just now, Happy2Play said: Can you post the server log for this action. If you search "it" does is return results? Yes, it does find them that way. I managed to fix them by logging into my admin user that has access to both movie libraries and splitting the 2 versions apart so that my 4k and 1080p version are no longer grouped. This kicked the 1080p version out of the collection and made it accessible in the 1080p library and I can add it back to the collection. It seems like there is something screwy going on with my collections, and maybe having grouped versions from 2 libraries has something to do with it? Although, the only movie that was actually showing in my Marvel Movies collection is Spiderman Homecoming even though it was grouped with it's 4k version. After splitting, then manually adding back to the collection I am able to group the versions again and they both seem to be properly accessible. embyserver.txt
