PenkethBoy 2068 Posted November 8, 2020 Posted November 8, 2020 upload an example album somewhere we can download it to see exactly what tags you have and folder name structure so we have the same as you
Georg.E 2 Posted November 12, 2020 Author Posted November 12, 2020 I think it is a parsing-problem...
Luke 42204 Posted November 13, 2020 Posted November 13, 2020 On 11/12/2020 at 2:08 AM, Georg.E said: I think it is a parsing-problem... Hi, what do you think is not being parsed correctly? Can you zip up and upload a sample album as he asked?
Georg.E 2 Posted November 19, 2020 Author Posted November 19, 2020 Hi, I uploaded 2 Zips, so you can download it. Please find the direct messages in your inbox. BR, Georg
PenkethBoy 2068 Posted November 19, 2020 Posted November 19, 2020 i have just loaded these into a test beta server 4.6.0.5 BB King looks fine this not so much - but this is down to the files having very limited or missing metadata a quick edit in Mp3Tag and Note: track number i made up I have not re read the thread but to me these are fine with no problems - if you clean up the metadata
Georg.E 2 Posted November 23, 2020 Author Posted November 23, 2020 Hi, what does the folder's view say? I use this most of the time. There, I see "B.B" and "Peter I". So nothing changed - I use the latest Beta. If I navigate into the Albums, Artists look fine, there you are right. BR, Georg
PenkethBoy 2068 Posted November 23, 2020 Posted November 23, 2020 dont know - moved on and deleted the files
Luke 42204 Posted November 24, 2020 Posted November 24, 2020 It probably came from internet metadata. I would just rename it how you want using the metadata editor, then disable the metadata fetchers that you don't want for your music library.
Georg.E 2 Posted January 2, 2021 Author Posted January 2, 2021 Hi, happy new year everybody In the folders view, the problem still exist. Are there any news about that? Its a pain to always rename the Folders after the rescans. I also upgraded to the latest beta... BR, Georg
Luke 42204 Posted January 2, 2021 Posted January 2, 2021 6 hours ago, Georg.E said: Hi, happy new year everybody In the folders view, the problem still exist. Are there any news about that? Its a pain to always rename the Folders after the rescans. I also upgraded to the latest beta... BR, Georg Can you show a new screenshot of folder view? Thanks.
Georg.E 2 Posted January 3, 2021 Author Posted January 3, 2021 Hi, ... and the "Edit Metadata"-Window from one "B.B"-Entry: Regards, Georg
Luke 42204 Posted January 3, 2021 Posted January 3, 2021 I notice you've added an SMB location into emby server. Instead of doing this, try mounting the SMB share to a local share using the tools in the server operating system, then add the local share into emby server instead of the smb share. Please see if that resolves your issue. thanks.
Georg.E 2 Posted January 12, 2021 Author Posted January 12, 2021 OK, thank. So I will try this and stick back to you.
Georg.E 2 Posted January 14, 2021 Author Posted January 14, 2021 I have mounted the storage via NFSv4 directly in the OS. Now it looks all good. Thanks for the hint.
