Krma 1 Posted February 16, 2020 Posted February 16, 2020 (edited) Hello, I have a tv box, and emby works excellent, the only thing that the interface has problems in showing some things. I leave images to understand me. thanks https://ibb.co/B63W3rK https://ibb.co/d0QsvDR https://ibb.co/K7xVTK9 Edited February 16, 2020 by Krma
Luke 42246 Posted February 16, 2020 Posted February 16, 2020 Hi, can you please describe the problem a little bit more? Thanks !
Krma 1 Posted February 16, 2020 Author Posted February 16, 2020 Hi @@Luke have you see the pictures? The resolutions in the tv boxes are not good, and they overlap as if they had a zoom.
ebr 16338 Posted February 16, 2020 Posted February 16, 2020 Hi. If this device is not running a true Android TV OS (has an Android TV launcher) then there may be some oddities like this but be sure the resolution, zoom and text size settings are all at defaults.
Krma 1 Posted February 16, 2020 Author Posted February 16, 2020 Hi @@ebr , yes i know. They are generic tv box, but it has no zoom or resolution changed, it is more if I force it to 1080p everything looks good, less emby. That's why more than anything the query. Is there an internal way to solve? or force resolution in the application in another way?
ebr 16338 Posted February 16, 2020 Posted February 16, 2020 I'm not sure why those particular items are exhibiting that behavior. It is as if the device is not reporting its pixel density properly. Is it only on those screens...?
Krma 1 Posted February 16, 2020 Author Posted February 16, 2020 Yes, its only on those screens, Every video or live TV is played perfectly, at a resolution of 1080. But it has that detail on that screen. Do I have a way to modify that? or what would be the correct density? to try tests on my own. I have 2 tv boxes that have the same detail.
