HackitZ 0 Posted February 16, 2020 Posted February 16, 2020 how do i make a pre roll play without trailers playing? i have changed some settings. either i get trailers and my pre roll or no trailers and no pre roll.
ebr 16346 Posted February 16, 2020 Posted February 16, 2020 Hi. You unchecked all of the "trailer" related checkboxes? 1
HackitZ 0 Posted February 16, 2020 Author Posted February 16, 2020 i did same issue, had to also remove include trailers from movies in my library.
Luke 42255 Posted February 16, 2020 Posted February 16, 2020 Can you go over an example and also show a screenshot of your Cinema intros settings?
ebr 16346 Posted February 16, 2020 Posted February 16, 2020 i did same issue, had to also remove include trailers from movies in my library. So, you had told it to play trailers from your library but were wondering why it was playing trailers? I guess, we could allow you to select "0" for the number of trailers to play if that would be more obvious...
HackitZ 0 Posted February 16, 2020 Author Posted February 16, 2020 does the include trailers from movies in my library, mean if i have local trailers in each movie folder it will play them?
Solution ebr 16346 Posted February 16, 2020 Solution Posted February 16, 2020 does the include trailers from movies in my library, mean if i have local trailers in each movie folder it will play them? Yes. Selecting any of those options is telling the system to use those sources to find trailers to play before playback. 1
