colleycol 3 Posted November 16, 2013 Posted November 16, 2013 What are you guys going to use in conjunction with MB3? ffdshow? LAVfilter? What should I use for best picture and sound? I have a WHS based 15TB server with mkv files. I use a separate win7 machine as the HTPC.
CBers 7554 Posted November 16, 2013 Posted November 16, 2013 What are you guys going to use in conjunction with MB3? ffdshow? LAVfilter? What should I use for best picture and sound? I have a WHS based 15TB server with mkv files. I use a separate win7 machine as the HTPC. If you're going with MBT, then you need LAVFILTER.
ebr 16331 Posted November 16, 2013 Author Posted November 16, 2013 If you're going with MBT, then you need LAVFILTER. That is correct, and MBT will install it for you.
colleycol 3 Posted November 16, 2013 Posted November 16, 2013 That is correct, and MBT will install it for you. Nice! Anything else you guys think would be a good idea for a newbie?
Gander 0 Posted November 16, 2013 Posted November 16, 2013 Can MBT change the refresh rate of the media based on the source material? Would be nice not to have to use the external player option....
makakam 2 Posted November 16, 2013 Posted November 16, 2013 You'll definitely want to use madvr if picture quality is your top priority.
ebr 16331 Posted November 16, 2013 Author Posted November 16, 2013 You'll definitely want to use madvr if picture quality is your top priority. Is that really going to have any impact on HD video?
pagali 62 Posted November 16, 2013 Posted November 16, 2013 Is that really going to have any impact on HD video? The improvement might not be as obvious with HD video as it is with SD (which some of us still have a lot of if we like classics and foreign movies) but it sure doesn't hurt HD.
makakam 2 Posted November 16, 2013 Posted November 16, 2013 (edited) No doubt about it, I've been using it for some time and there's new debanding option being tested. @Gander: madvr can do this. Edited November 16, 2013 by makakam
Gander 0 Posted November 16, 2013 Posted November 16, 2013 Are you suggesting still using MPC-HC as the external player for Madvr, instead of using the MBT internal player?
Luke 42235 Posted November 16, 2013 Posted November 16, 2013 Are you suggesting still using MPC-HC as the external player for Madvr, instead of using the MBT internal player? no
Gander 0 Posted November 16, 2013 Posted November 16, 2013 Got it - thanks! Looking forward to the preview!
MSL_DK 35 Posted November 16, 2013 Posted November 16, 2013 Is that really going to have any impact on HD video? Yes http://mediabrowser.tv/community/index.php?/topic/1983-can-someone-explain-madvr/&do=findComment&comment=37730
lorac 119 Posted November 17, 2013 Posted November 17, 2013 It's not going to have much of an impact on anything IMO, except your time.
dylanrellis 8 Posted November 17, 2013 Posted November 17, 2013 is the lav filters an optional part or the install? and where can I download it lol
Luke 42235 Posted November 17, 2013 Posted November 17, 2013 it's not optional, although it will be skipped if it's already installed.
Gander 0 Posted November 17, 2013 Posted November 17, 2013 Is it best to uninstall Codec/codec packs such as Shark007 when installing MBT? Does MBT incorporate most codecs or should it be used in conjunction with another package?
Luke 42235 Posted November 17, 2013 Posted November 17, 2013 it uses Lav Filters. Don't worry about pre-installing anything ahead of time. The MBT startup wizard will walk you through it and install anything that is needed. 1
legacybev 2 Posted November 17, 2013 Posted November 17, 2013 Can mbt also use ffdshow if I want it to,thanks.
dylanrellis 8 Posted November 17, 2013 Posted November 17, 2013 I could really use a hand here, I made the mistake of installing my movies 4... it downloaded covers as a differently named file but then somehow replaced mediabrowsers folder.jpg's... now all my covers are dodgy, if I batch delete them all mb will revert to thumbnails and therefore a refresh wont update the covers. is there somewhere I can delete all the thumbnails so that a refresh will download new covers? or is there something else I should do? needless to say mm4 is gone now and all associated files. posting here since its an issue to do with mbt preparation lol, and to be seen!
Luke 42235 Posted November 17, 2013 Posted November 17, 2013 you can delete the individual images and refresh the individual items from the edit page in the web client. since bulk editing is not yet implemented, if you want to do them all in one shot you'll need to delete the images and then your library db file.
dylanrellis 8 Posted November 17, 2013 Posted November 17, 2013 where are the images located? just the thumbs. would I lose anything else from the library.db file? like watched status etc. sorry for hassling your probably busy, I hope.
Luke 42235 Posted November 17, 2013 Posted November 17, 2013 the folder.jpg/png files in your media directories. no you won't lose anything else.
