mbevacqua_1999 0 Posted February 15, 2020 Posted February 15, 2020 Emby Server running on Synology with HDHomerun connect for live tv. Channels mostly work fine, except one. It continually breaks up. Signal Strength is 94% and Signal Quality is 86%. Regardless of whether transcoding or playing direct, it will not stop breaking up every 5 - 10 secs. Tried on mobile device and Nvidia Shield. The HDhomerun native app does not have the issue on either device nor does Live Channels on the Shield. Any thoughts on what could be effecting just a single channel in Emby, but nothing else? I thought maybe streaming rate, but I checked two different channels and they are both streaming from HDHomerun Connect at same rate. The issue happens regardless of whether watching live or recording. Thanks
Luke 42242 Posted February 15, 2020 Posted February 15, 2020 Hi there, what version of Emby Server are you running?
mbevacqua_1999 0 Posted February 15, 2020 Author Posted February 15, 2020 4.3.1.0 This may be a new problem, was there an update that could have caused issues? Thanks
Luke 42242 Posted February 15, 2020 Posted February 15, 2020 No, can you please attach the emby server log? Thanks !
mbevacqua_1999 0 Posted February 15, 2020 Author Posted February 15, 2020 (edited) Attached. Do you need others, or just this one? embyserver.txt Edited February 15, 2020 by mbevacqua_1999
Luke 42242 Posted February 18, 2020 Posted February 18, 2020 That's good. There's nothing obvious here but there's a lot of changes in the upcoming 4.4 release so you could try that once available. Thanks.
