mohoelx 12 Posted February 14, 2020 Posted February 14, 2020 Working on an upgraded box for my Emby server. I created a new user account and installed Emby 4.3.1.0. When Emby Server is running, my system will hang (hard freeze) at some point to where I have to power-cycle to get it back up. Right now, the server is not really doing anything ... I have two 30 minute OTA shows "loaded" into the one library for testing and such, but no clients attempting to access this server. Right now, I have the server turned off (still installed) and the system seems to be staying up. Here are a couple logs from the most recent "hang". Thanks in advance for any help you can share! embyserver-63717281767.txt hardware_detection-63717281523.txt
Luke 42216 Posted February 14, 2020 Posted February 14, 2020 Hi there, are you sure this is the right log? This is probably from just after it occurred and you restarted, right?
mohoelx 12 Posted February 15, 2020 Author Posted February 15, 2020 Thanks for the feedback. I went to check on that and to ensure I send a log during the time of a lock-up, and of course since asking the question it has not done it.... If it does in the next day or two, I'll update with fresh logs, otherwise I guess we just call it a 'fluke' that went away. The only significant difference is the Emby web interface is running under Edge instead of Chrome this time, but I would be surprised if that really means anything. Just thought I'd mention it.
