rffalcon77 0 Posted February 15, 2020 Author Posted February 15, 2020 Will do. I think I have it nailed. I took the Hardware acceleration off and have not had a problem since. I just did this at around 1 p.m. But I will still send you those logs as soon as I figure out how to attach them.
rffalcon77 0 Posted February 15, 2020 Author Posted February 15, 2020 Here are the logs. embyserver-log 1.txt ffmpeg-directstream-8806aa11-6496-4e41-85b1-7b1bfd236039_1.txt
Luke 42237 Posted February 15, 2020 Posted February 15, 2020 Will do. I think I have it nailed. I took the Hardware acceleration off and have not had a problem since. I just did this at around 1 p.m. But I will still send you those logs as soon as I figure out how to attach them. If that's true then hardware acceleration is improved in the next release, so that may help. 1
gillmacca01 220 Posted February 15, 2020 Posted February 15, 2020 (edited) How did you manage to get this working in Emby. I have pasted the m3u link, channels appear, but I get a playback error (no compatible streams available), but if I immediately try the same channel on the site, it plays Solved it. I was pairing to the wrong device Edited February 15, 2020 by gillmacca01
rffalcon77 0 Posted February 16, 2020 Author Posted February 16, 2020 I think this is a channel pear issue more than an Emby issue. I have other m3u's that work perfectly with emby. That said, please give me a heads up when you release the newest update. Thanks for your help!
rffalcon77 0 Posted February 16, 2020 Author Posted February 16, 2020 How did you manage to get this working in Emby. I have pasted the m3u link, channels appear, but I get a playback error (no compatible streams available), but if I immediately try the same channel on the site, it plays Solved it. I was pairing to the wrong device It appears that Channel Pear is down at the moment. so if it is not working for you that may be the issue.
Ejime 0 Posted March 27, 2020 Posted March 27, 2020 Hey any one know what i may be doing wrong? I am trying to sync my channel pear live TV to my emby server, all i get is no channel available on the emby server I have followed all the necessary steps, but not getting any where.
Luke 42237 Posted March 28, 2020 Posted March 28, 2020 Hey any one know what i may be doing wrong? I am trying to sync my channel pear live TV to my emby server, all i get is no channel available on the emby server I have followed all the necessary steps, but not getting any where. Hi there @@Ejime, how did you set it up?
Ejime 0 Posted March 29, 2020 Posted March 29, 2020 (edited) Hi I got these walk-through from the channel pear self help section. 1. Click Live TV in the settings menu on the left-hand side of the page 2. Click the plus icon next to TV sources to add a source 3. Select M3U tunner from the drop down menu under type 4.You now need to enter your accounts custom URL into the file or url field. To get this to go to your libraryand select "pair" then Emby 5. Copy the url from the pop up. Note that this url is uinque to your account and should not be shared with any one. 6. Go back to the previous Emby configuration settings page and paste your url in the file or url field and then click save. 7. You should then see your configured M3U Tunner as a TV source 8. Navigate to your Emby Server's Live TV page from the menu and you should see your channel pear library sources. 9. Congratulations, you have successfully configured Emby with channel pear ! You can now watch your channel pear library with Emby on all the devices Emby support like Roku, fire TV, Apple TV, iOS, Android, PS4 and more. Thank you! Edited March 29, 2020 by Ejime
Ejime 0 Posted March 29, 2020 Posted March 29, 2020 Hi I got these walk-through from the channel pear self help section. 1. Click Live TV in the settings menu on the left-hand side of the page 2. Click the plus icon next to TV sources to add a source 3. Select M3U tunner from the drop down menu under type 4.You now need to enter your accounts custom URL into the file or url field. To get this to go to your libraryand select "pair" then Emby 5. Copy the url from the pop up. Note that this url is uinque to your account and should not be shared with any one. 6. Go back to the previous Emby configuration settings page and paste your url in the file or url field and then click save. 7. You should then see your configured M3U Tunner as a TV source 8. Navigate to your Emby Server's Live TV page from the menu and you should see your channel pear library sources. 9. Congratulations, you have successfully configured Emby with channel pear ! You can now watch your channel pear library with Emby on all the devices Emby support like Roku, fire TV, Apple TV, iOS, Android, PS4 and more. Thank you!
Luke 42237 Posted March 30, 2020 Posted March 30, 2020 @@Ejime can you please refresh the guide in emby server settings, then once it completes attach the emby server log? thanks.
