denz 501 Posted February 14, 2020 Posted February 14, 2020 Sometimes after watching videos the timeline doesn’t appear anymore the only item it has is top logo so you can forward or rewind as the buttons are not there anymore. I use the new edge chromium or something like that. The only way to restore is close the page and go into emby again. When that happens is there something I can do to gather information to assist to help fix this issue. I like using edge so it is always default.
Happy2Play 9806 Posted February 14, 2020 Posted February 14, 2020 Does this happen in a different browser? I would check the browser console for error and probably post server log.
denz 501 Posted February 14, 2020 Author Posted February 14, 2020 I am not sure since I always tend to use edge. Thanks for the suggestions I will try a different browser and look at the browser console for errors.
denz 501 Posted February 20, 2020 Author Posted February 20, 2020 (edited) It says 8 errors and 5 exclamation point but clicking on them doesn't take you to the error this is again edge and next to this line it has 3 in a circle manifest.json:1 Manifest: one of 'url' or 'id' is required, related application ignored. DevTools failed to parse SourceMap: http://myip:8096/web/bower_components/hlsjs/dist/hls.min.js.map I think these are the errors apiclient.js?v=4.3.1.0:1 WebSocket connection to 'ws://myip:8096/embywebsocket?api_key=281e34a3746549abace9074ba5dc67d3&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzc5LjAuMzk0NS4xMzAgU2FmYXJpLzUzNy4zNiBFZGcvNzkuMC4zMDkuNzF8MTU3OTc2NzQwODkxMA11' failed: Invalid frame header It has many of these errors Failed to load resource: net::ERR_CONNECTION_REFUSED :8096/emby/videos/21…trateExceedsLimit:1 embyserver.txt Edited February 20, 2020 by denz
Luke 42216 Posted February 20, 2020 Posted February 20, 2020 Can you attach the complete console contents? Thanks.
denz 501 Posted February 21, 2020 Author Posted February 21, 2020 This time it took while to happen. edge console.log
denz 501 Posted February 21, 2020 Author Posted February 21, 2020 (edited) It says To finish updating, restart Microsoft Edge. Version 80.0.361.56 (Official build) (64-bit) Restart This browser is made possible by the Chromium open source project and other open source software. That explains why no one has experienced this bug as probable no one has installed it yet. Edited February 21, 2020 by denz
denz 501 Posted February 21, 2020 Author Posted February 21, 2020 I will get in a habit to use Chrome and see does it happen there or could it be just early release glitch. It is hard to reproduce yesterday I couldn't reproduce it today I did but have no idea what I did.
