sandro_rocha_1982 1 Posted February 18, 2020 Author Posted February 18, 2020 Another question: I am testing both servers to choose the best one for me. Emby is lighter and faster, but the WebOS application does not play some video formats (rmvb for example). Plex is worse to handle and the WebOS application is just as bad, but there is XPlay, which solves compatibility problems. Would it be possible to make the Emby application for WebOS 3.5 run videos without a transcode? If XPlay runs it must be possible to make Emby run as well. There does not seem to be a TV limitation.
Luke 42237 Posted February 18, 2020 Posted February 18, 2020 Why doesn't it play rmvb? What happens when you try?
sandro_rocha_1982 1 Posted February 18, 2020 Author Posted February 18, 2020 (edited) Why doesn't it play rmvb? What happens when you try? He plays rmvb but transcode. XPlay plays directly. The native Plex app does not play, says the server is not powerful enough, which would be true if Emby refused to transcode too. Edited February 18, 2020 by sandro_rocha_1982
sandro_rocha_1982 1 Posted February 19, 2020 Author Posted February 19, 2020 He plays rmvb but transcode. XPlay plays directly. The native Plex app does not play, says the server is not powerful enough, which would be true if Emby refused to transcode too. Good Morning. I tried to play an rmvb file on the LG TV with WebOS and this time it didn't work. The message "There are no compatible streams. Please try later" or something. Before I was forced to reinstall Emby and recreate the library the Emby transcode the file. It stopped working. What could be happening?
Luke 42237 Posted February 19, 2020 Posted February 19, 2020 Good Morning. I tried to play an rmvb file on the LG TV with WebOS and this time it didn't work. The message "There are no compatible streams. Please try later" or something. Before I was forced to reinstall Emby and recreate the library the Emby transcode the file. It stopped working. What could be happening? Let's look at an example. Please see how to report a media playback issue. Thanks !
SamES 1084 Posted February 19, 2020 Posted February 19, 2020 Why doesn't it play rmvb? What happens when you try? @@Luke, I tested the sample rmvb file here https://users.wfu.edu/yipcw/atg/vid/ It can DirectPlay, I added something basic to test this in the profile. I'll raise PR to include it.
sandro_rocha_1982 1 Posted February 19, 2020 Author Posted February 19, 2020 Let's look at an example. Please see how to report a media playback issue. Thanks ! I restarted the server and the file played, with transcode. Less bad. But it would be nice if the file played in directplay.
Luke 42237 Posted February 19, 2020 Posted February 19, 2020 It will in the update after the next update to the LG app. Thanks.
sandro_rocha_1982 1 Posted February 19, 2020 Author Posted February 19, 2020 It will in the update after the next update to the LG app. Thanks.Thanks.
