ernstgot 17 Posted February 13, 2020 Posted February 13, 2020 i have shows recorded but they don't show up in recordings on emby after they are complete. I can watch them if I go to the folder and open the file directly.
denz 501 Posted February 13, 2020 Posted February 13, 2020 Have you checked the recordings library that in advance enable real time monitoring just in case it is enabled
denz 501 Posted February 13, 2020 Posted February 13, 2020 Are you using the web client or some other app if it is other start with the web client first. On your home screen do you have a line latest recordings and are the recordings there ?
ernstgot 17 Posted February 13, 2020 Author Posted February 13, 2020 I do have the line latest recordings but nothing is listed. Even reset the folder they are stored in making sure they match. But nothing showing up.
ernstgot 17 Posted February 13, 2020 Author Posted February 13, 2020 Where are you looking for it? Looking in "Live Tv" under my media, then under "recordings"
denz 501 Posted February 13, 2020 Posted February 13, 2020 (edited) Can you take screenshots of dvr settings in the server settings it is under live tv and the the library. Are you using a beta server or stable server ? Try also to record something and do you have active recording line ? Are you using some kind of plugin or HDHomeRun using built in pvr Maybe provide server log take personal info out. Edited February 13, 2020 by denz
Luke 42243 Posted February 13, 2020 Posted February 13, 2020 Yes that would be helpful info. I would also check your emby user permissions on the recordings library.
Solution ernstgot 17 Posted February 13, 2020 Author Solution Posted February 13, 2020 Yes that would be helpful info. I would also check your emby user permissions on the recordings library. This was it, I'm sorry I completely forgot I changed my user permissions with new accounts when reinstalling of the server. 1
cycochuck 0 Posted April 21, 2020 Posted April 21, 2020 I am having a similar issue since upgrading to 4.4.2.0. Before, everything was working fine where a show would record and immediately show up. But since the upgrade, it would take anywhere from six to twelve hours to show up on any client (web, android, or firetv). I can look in the recorded show's file directory and see a new show has been recorded. I've tried library scans and it still won't show the newly recorded show until it has been 6 to 12 hours. Again, absolutely nothing on the server has changed from 4.4.1.0 (where everything worked fine) to 4.4.2.0.
Luke 42243 Posted April 22, 2020 Posted April 22, 2020 I am having a similar issue since upgrading to 4.4.2.0. Before, everything was working fine where a show would record and immediately show up. But since the upgrade, it would take anywhere from six to twelve hours to show up on any client (web, android, or firetv). I can look in the recorded show's file directory and see a new show has been recorded. I've tried library scans and it still won't show the newly recorded show until it has been 6 to 12 hours. Again, absolutely nothing on the server has changed from 4.4.1.0 (where everything worked fine) to 4.4.2.0. Hi there, can we please look at an example? Thanks.
cycochuck 0 Posted April 22, 2020 Posted April 22, 2020 I apologize, I jumped the gun. Been working long hours and missed that somehow two massive libraries got switched to "Enable real time monitoring" which left the system in a never-ending update loop.
cycochuck 0 Posted April 28, 2020 Posted April 28, 2020 It was repetitively scanning the same library. The web client would show the same library being scanned, only to have the scan start again after the previous scan's completion.
ebr 16335 Posted April 28, 2020 Posted April 28, 2020 It was repetitively scanning the same library. The web client would show the same library being scanned, only to have the scan start again after the previous scan's completion. Do you have something external constantly modifying files within the scope of that library?
cycochuck 0 Posted April 30, 2020 Posted April 30, 2020 The library is for VOD from my tv service. I have a cron task that runs a script that creates scrm files at midnight everyday. This wasn't a problem before, but somehow during the time I did an upgrade the library setting was set to real time monitoring instead of just going with the regularly scheduled library scan. I'm guessing at this point that it was a user error on my part and that I accidentally click the check box as I was looking through the settings after running the upgrade.
Luke 42243 Posted May 5, 2020 Posted May 5, 2020 We'll look into why this might be happening for you. Thanks for reporting.
iiiJoe 62 Posted August 19, 2022 Posted August 19, 2022 Good morning to all! Been using Emby about three weeks now and I really like it. I am having a small problem with recordings. I have some recordings in the destination folder that are not showing in my library on my primary server which is a Windows 10 pc. I'm using an Nvidia Shield as a client and when I go to the recordings tab the screen is empty. I can find recordings in the "latest recordings" section, however. Real time monitoring is enabled. Any help would be greatly appreciated!
iiiJoe 62 Posted August 19, 2022 Posted August 19, 2022 Please disregard my question above. The filter on the recordings screen on the client was set to favorites and ofc I had no favorites, lol. So, I un-ticked it and all recordings show. I hope I didn't waste anyone's time. Thank you so much!!
