pmac 143 Posted February 13, 2020 Author Posted February 13, 2020 [ 0.007][v][cplayer] mpv 0.29.1 Copyright © 2000-2018 mpv/MPlayer/mplayer2 projects [ 0.007][v][cplayer] built on Tue Jan 8 02:05:57 NZDT 2019 [ 0.007][v][cplayer] ffmpeg library versions: [ 0.007][v][cplayer] libavutil 56.22.100 [ 0.007][v][cplayer] libavcodec 58.35.100 [ 0.007][v][cplayer] libavformat 58.20.100 [ 0.007][v][cplayer] libswscale 5.3.100 [ 0.007][v][cplayer] libavfilter 7.40.101 [ 0.007][v][cplayer] libswresample 3.3.100 [ 0.007][v][cplayer] ffmpeg version: n4.1 [ 0.007][v][cplayer] [ 0.007][v][cplayer] Configuration: /home/luke/github/mpv-winbuild-cmake/build64/packages/mpv-prefix/src/mpv/waf configure --enable-static-build --enable-pdf-build --disable-manpage-build --enable-libmpv-shared --enable-lua --enable-javascript --enable-libarchive --enable-libass --enable-libbluray --enable-dvdread --enable-dvdnav --enable-uchardet --enable-rubberband --enable-lcms2 --enable-openal --enable-vapoursynth --prefix=/home/luke/github/mpv-winbuild-cmake/build64/install/mingw [ 0.007][v][cplayer] List of enabled features: asm atomics build-date cplayer crossc cuda-hwaccel d3d-hwaccel d3d11 d3d9-hwaccel debug-build direct3d dos-paths drmprime dvdnav dvdread dvdread-common egl-angle egl-angle-win32 egl-helpers ffmpeg ffnvcodec gl gl-dxinterop gl-dxinterop-d3d9 gl-win32 glob glob-win32 gnuc gpl iconv javascript jpeg lcms2 libaf libarchive libass libass-osd libav-any libavcodec libavdevice libbluray libm libmpv-shared lua luajit mingw noexecstack openal optimize plain-gl posix-or-mingw rubberband shaderc shaderc-static static-build stdatomic uchardet vapoursynth vapoursynth-core vapoursynth-lazy vulkan wasapi win32-desktop win32-internal-pthreads win32-pipes zlib [ 0.007][d][ytdl_hook] Loading lua script @ytdl_hook.lua... [ 0.007][d][stats] Loading lua script @[member="Stats"].lua... [ 0.008][v][ipc] Starting IPC master [ 0.008][d][stats] loading mp.defaults [ 0.008][d][ytdl_hook] loading mp.defaults [ 0.008][v][ipc] Listening to IPC pipe. [ 0.009][v][ipc_0] Client connected [ 0.009][d][ytdl_hook] loading @ytdl_hook.lua [ 0.009][d][stats] loading @[member="Stats"].lua [ 0.009][d][ytdl_hook] reading options for ytdl_hook [ 0.009][d][refreshrate] Loading lua script C:/Users/Patrick/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/refreshrate.lua... [ 0.009][v][cplayer] Waiting for scripts... [ 0.009][v][ytdl_hook] script-opts/ytdl_hook.conf not found. [ 0.010][d][stats] reading options for stats [ 0.010][v][ytdl_hook] lua-settings/ytdl_hook.conf not found. [ 0.010][d][refreshrate] loading mp.defaults [ 0.010][v][stats] script-opts/stats.conf not found. [ 0.010][v][stats] lua-settings/stats.conf not found. [ 0.010][d][refreshrate] loading file C:/Users/Patrick/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/refreshrate.lua [ 0.011][d][cplayer] Run command: define-section, flags=0, args=[input_stats, i script-binding stats/display-stats [ 0.011][d][cplayer] , default] [ 0.011][d][cplayer] Run command: enable-section, flags=0, args=[input_stats, allow-hide-cursor+allow-vo-dragging] [ 0.011][d][cplayer] Run command: define-section, flags=0, args=[input_forced_stats, , force] [ 0.011][d][cplayer] Run command: enable-section, flags=0, args=[input_forced_stats, allow-hide-cursor+allow-vo-dragging] [ 0.011][d][cplayer] Run command: define-section, flags=0, args=[input_stats, I script-binding stats/display-stats-toggle [ 0.011][d][cplayer] i script-binding stats/display-stats [ 0.011][d][cplayer] , default] [ 0.011][d][cplayer] Run command: enable-section, flags=0, args=[input_stats, allow-hide-cursor+allow-vo-dragging] [ 0.011][d][cplayer] Run command: define-section, flags=0, args=[input_forced_stats, , force] [ 0.011][d][cplayer] Run command: enable-section, flags=0, args=[input_forced_stats, allow-hide-cursor+allow-vo-dragging] [ 0.011][d][cplayer] Run command: define-section, flags=0, args=[input_stats, i script-binding stats/display-stats [ 0.011][d][cplayer] I script-binding stats/display-stats-toggle [ 0.011][d][cplayer] , default] [ 0.011][d][cplayer] Run command: enable-section, flags=0, args=[input_stats, allow-hide-cursor+allow-vo-dragging] [ 0.011][d][cplayer] Run command: define-section, flags=0, args=[input_forced_stats, , force] [ 0.011][d][cplayer] Run command: enable-section, flags=0, args=[input_forced_stats, allow-hide-cursor+allow-vo-dragging] [ 0.011][d][cplayer] Run command: define-section, flags=0, args=[input_stats, i script-binding stats/display-stats [ 0.011][d][cplayer] I script-binding stats/display-stats-toggle [ 0.011][d][cplayer] , default] [ 0.011][d][cplayer] Run command: enable-section, flags=0, args=[input_stats, allow-hide-cursor+allow-vo-dragging] [ 0.011][d][cplayer] Run command: define-section, flags=0, args=[input_forced_stats, , force] [ 0.011][d][cplayer] Run command: enable-section, flags=0, args=[input_forced_stats, allow-hide-cursor+allow-vo-dragging] [ 0.011][v][cplayer] Done loading scripts. [ 0.014][v][cplayer] Set property: volume=100 -> 1 [ 0.014][d][cplayer] Run command: loadfile, flags=0, args=[\\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4, replace, ] [ 0.014][i][cplayer] Playing: \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4 [ 0.014][v][cplayer] Running hook: ytdl_hook/on_load [ 0.015][v][ytdl_hook] ytdl:// hook [ 0.015][v][ytdl_hook] not a ytdl:// url [ 0.015][v][ifo] Opening \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4 [ 0.015][v][ifo_dvdnav] Opening \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4 [ 0.016][v][bdmv/bluray] Opening \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4 [ 0.017][v][file] Opening \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4 [ 0.018][d][file] Stream opened successfully. [ 0.019][v][cache] Cache size set to 20000 KiB (10000 KiB backbuffer) [ 0.019][v][demux] Trying demuxers for level=normal. [ 0.019][d][demux] Trying demuxer: disc (force-level: normal) [ 0.019][d][demux] Trying demuxer: edl (force-level: normal) [ 0.019][d][demux] Trying demuxer: cue (force-level: normal) [ 0.019][d][demux] Trying demuxer: rawaudio (force-level: normal) [ 0.019][d][demux] Trying demuxer: rawvideo (force-level: normal) [ 0.020][d][demux] Trying demuxer: mkv (force-level: normal) [ 0.020][d][demux] Trying demuxer: libarchive (force-level: normal) [ 0.020][d][demux] Trying demuxer: rar (force-level: normal) [ 0.020][d][demux] Trying demuxer: lavf (force-level: normal) [ 0.021][v][lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [ 0.086][v][demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [ 0.086][v][cache] blocking for STREAM_CTRL 6 [ 0.086][v][cplayer] Opening done: \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4 [ 0.087][v][find_files] Loading external files in \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\ [ 0.089][v][cplayer] Running hook: ytdl_hook/on_preloaded [ 0.089][v][lavf] select track 0 [ 0.089][v][lavf] select track 1 [ 0.089][i][cplayer] (+) Video --vid=1 (*) (h264 1920x800 23.976fps) [ 0.089][i][cplayer] (+) Audio --aid=1 (*) (aac 6ch 48000Hz) [ 0.090][v][vo/gpu] Probing for best GPU context. [ 0.090][v][vo/gpu/d3d11] Initializing GPU context 'd3d11' [ 0.117][v][vo/gpu/d3d11] Using Direct3D 11 feature level 11_1 [ 0.117][v][vo/gpu/d3d11] Device Name: AMD Radeon R9 200 Series [ 0.117][v][vo/gpu/d3d11] Device ID: 1002:6810 (rev 00) [ 0.117][v][vo/gpu/d3d11] Subsystem ID: 1462:3030 [ 0.118][v][vo/gpu/d3d11] LUID: 000000000000cd73 [ 0.118][v][vo/gpu/d3d11] Initializing SPIR-V compiler 'shaderc' [ 0.118][v][vo/gpu/d3d11] Using Direct3D 11.1 runtime [ 0.118][v][vo/gpu/d3d11] Maximum Texture2D size: 16384x16384 [ 0.119][v][vo/gpu/d3d11] D3DCompiler version: 10.0.18362.1 [ 0.190][v][vo/gpu/win32] resize window: 1920:1080 [ 0.190][v][vo/gpu/win32] DPI detected from the new API: 96 [ 0.190][v][vo/gpu/win32] display-fps: 59.940060 [ 0.194][v][vo/gpu/win32] color-profile: C:\WINDOWS\system32\spool\drivers\color\sRGB Color Space Profile.icm [ 0.194][d][vo/gpu/win32] move window: 0:0 [ 0.207][v][vo/gpu/d3d11] Using DXGI 1.2+ [ 0.207][v][vo/gpu/d3d11] Using flip-model presentation [ 0.207][d][vo/gpu/d3d11] Texture formats: [ 0.207][d][vo/gpu/d3d11] NAME COMP*TYPE SIZE DEPTH PER COMP. [ 0.207][d][vo/gpu/d3d11] r8 1*unorm 1B LF CR {8} [ 0.207][d][vo/gpu/d3d11] rg8 2*unorm 2B LF CR {8 8} [ 0.207][d][vo/gpu/d3d11] rgba8 4*unorm 4B LF CR {8 8 8 8} [ 0.207][d][vo/gpu/d3d11] r16 1*unorm 2B LF CR {16} [ 0.207][d][vo/gpu/d3d11] rg16 2*unorm 4B LF CR {16 16} [ 0.207][d][vo/gpu/d3d11] rgba16 4*unorm 8B LF CR {16 16 16 16} [ 0.207][d][vo/gpu/d3d11] r32ui 1*uint 4B {32} [ 0.207][d][vo/gpu/d3d11] rg32ui 2*uint 8B {32 32} [ 0.207][d][vo/gpu/d3d11] rgb32ui 3*uint 12B {32 32 32} [ 0.207][d][vo/gpu/d3d11] rgba32ui 4*uint 16B {32 32 32 32} [ 0.207][d][vo/gpu/d3d11] r16hf 1*float 2B LF CR {16} [ 0.207][d][vo/gpu/d3d11] rg16hf 2*float 4B LF CR {16 16} [ 0.207][d][vo/gpu/d3d11] rgba16hf 4*float 8B LF CR {16 16 16 16} [ 0.207][d][vo/gpu/d3d11] r32f 1*float 4B LF CR {32} [ 0.207][d][vo/gpu/d3d11] rg32f 2*float 8B LF CR {32 32} [ 0.207][d][vo/gpu/d3d11] rgb32f 3*float 12B {32 32 32} [ 0.207][d][vo/gpu/d3d11] rgba32f 4*float 16B LF CR {32 32 32 32} [ 0.207][d][vo/gpu/d3d11] rgb10_a2 4*unorm 4B LF CR {10 10 10 2} [ 0.207][d][vo/gpu/d3d11] bgra8 4*unorm 4B LF CR {8 8 8 8} [ 0.207][d][vo/gpu/d3d11] bgrx8 3*unorm 4B LF CR {8 8 8} [ 0.207][d][vo/gpu/d3d11] LA = LUMINANCE_ALPHA hack format [ 0.207][d][vo/gpu/d3d11] LF = linear filterable [ 0.207][d][vo/gpu/d3d11] CR = can be used for render targets [ 0.208][d][vo/gpu/d3d11] Image formats: [ 0.208][d][vo/gpu/d3d11] yuv444p => 3 planes 1x1 8/0 [r8/r8/r8] (r/g/b) [ 0.208][d][vo/gpu/d3d11] yuv420p => 3 planes 2x2 8/0 [r8/r8/r8] (r/g/b) [ 0.208][d][vo/gpu/d3d11] gray => 1 planes 1x1 8/0 [r8] (r) [ 0.208][d][vo/gpu/d3d11] gray16 => 1 planes 1x1 16/0 [r16] (r) [ 0.208][d][vo/gpu/d3d11] uyvy422 [ 0.208][d][vo/gpu/d3d11] nv12 => 2 planes 2x2 8/0 [r8/rg8] (r/gb) [ 0.208][d][vo/gpu/d3d11] p010 => 2 planes 2x2 16/6 [r16/rg16] (r/gb) [ 0.208][d][vo/gpu/d3d11] argb => 1 planes 1x1 8/0 [rgba8] (argb) [ 0.208][d][vo/gpu/d3d11] bgra => 1 planes 1x1 8/0 [rgba8] (bgra) [ 0.208][d][vo/gpu/d3d11] abgr => 1 planes 1x1 8/0 [rgba8] (abgr) [ 0.208][d][vo/gpu/d3d11] rgba => 1 planes 1x1 8/0 [rgba8] (rgba) [ 0.208][d][vo/gpu/d3d11] bgr24 [ 0.208][d][vo/gpu/d3d11] rgb24 [ 0.208][d][vo/gpu/d3d11] 0rgb => 1 planes 1x1 8/0 [rgba8] (_rgb) [ 0.208][d][vo/gpu/d3d11] bgr0 => 1 planes 1x1 8/0 [rgba8] (bgr) [ 0.208][d][vo/gpu/d3d11] 0bgr => 1 planes 1x1 8/0 [rgba8] (_bgr) [ 0.208][d][vo/gpu/d3d11] rgb0 => 1 planes 1x1 8/0 [rgba8] (rgb) [ 0.208][d][vo/gpu/d3d11] rgba64 => 1 planes 1x1 16/0 [rgba16] (rgba) [ 0.208][d][vo/gpu/d3d11] rgb565 [ 0.208][d][vo/gpu/d3d11] vdpau [ 0.208][d][vo/gpu/d3d11] vdpau_output [ 0.208][d][vo/gpu/d3d11] vaapi [ 0.208][d][vo/gpu/d3d11] d3d11 [ 0.208][d][vo/gpu/d3d11] dxva2_vld [ 0.208][d][vo/gpu/d3d11] mmal [ 0.208][d][vo/gpu/d3d11] videotoolbox [ 0.208][d][vo/gpu/d3d11] drm_prime [ 0.208][d][vo/gpu/d3d11] cuda [ 0.208][d][vo/gpu/d3d11] yuyv422 [ 0.208][d][vo/gpu/d3d11] yuv422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b) [ 0.208][d][vo/gpu/d3d11] yuv410p => 3 planes 4x4 8/0 [r8/r8/r8] (r/g/b) [ 0.208][d][vo/gpu/d3d11] yuv411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b) [ 0.208][d][vo/gpu/d3d11] monow [ 0.208][d][vo/gpu/d3d11] monob [ 0.208][d][vo/gpu/d3d11] pal8 [ 0.208][d][vo/gpu/d3d11] yuvj422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b) [ 0.208][d][vo/gpu/d3d11] uyyvyy411 [ 0.208][d][vo/gpu/d3d11] bgr8 [ 0.208][d][vo/gpu/d3d11] bgr4 [ 0.208][d][vo/gpu/d3d11] bgr4_byte [ 0.208][d][vo/gpu/d3d11] rgb8 [ 0.208][d][vo/gpu/d3d11] rgb4 [ 0.208][d][vo/gpu/d3d11] rgb4_byte [ 0.208][d][vo/gpu/d3d11] nv21 => 2 planes 2x2 8/0 [r8/rg8] (r/bg) [ 0.208][d][vo/gpu/d3d11] gray16be [ 0.208][d][vo/gpu/d3d11] yuv440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b) [ 0.208][d][vo/gpu/d3d11] yuvj440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b) [ 0.208][d][vo/gpu/d3d11] yuva420p => 4 planes 2x2 8/0 [r8/r8/r8/r8] (r/g/b/a) [ 0.208][d][vo/gpu/d3d11] rgb48be [ 0.208][d][vo/gpu/d3d11] rgb48 [ 0.208][d][vo/gpu/d3d11] rgb565be [ 0.208][d][vo/gpu/d3d11] rgb555be [ 0.208][d][vo/gpu/d3d11] rgb555 [ 0.208][d][vo/gpu/d3d11] bgr565be [ 0.208][d][vo/gpu/d3d11] bgr565 [ 0.208][d][vo/gpu/d3d11] bgr555be [ 0.208][d][vo/gpu/d3d11] bgr555 [ 0.208][d][vo/gpu/d3d11] vaapi_moco [ 0.208][d][vo/gpu/d3d11] vaapi_idct [ 0.208][d][vo/gpu/d3d11] yuv420p16 => 3 planes 2x2 16/0 [r16/r16/r16] (r/g/b) [ 0.208][d][vo/gpu/d3d11] yuv420p16be [ 0.208][d][vo/gpu/d3d11] yuv422p16 => 3 planes 2x1 16/0 [r16/r16/r16] (r/g/b) [ 0.208][d][vo/gpu/d3d11] yuv422p16be [ 0.208][d][vo/gpu/d3d11] yuv444p16 => 3 planes 1x1 16/0 [r16/r16/r16] (r/g/b) [ 0.208][d][vo/gpu/d3d11] yuv444p16be [ 0.208][d][vo/gpu/d3d11] rgb444 [ 0.208][d][vo/gpu/d3d11] rgb444be [ 0.208][d][vo/gpu/d3d11] bgr444 [ 0.208][d][vo/gpu/d3d11] bgr444be [ 0.208][d][vo/gpu/d3d11] ya8 => 1 planes 1x1 8/0 [rg8] (ra) [ 0.208][d][vo/gpu/d3d11] bgr48be [ 0.208][d][vo/gpu/d3d11] bgr48 [ 0.208][d][vo/gpu/d3d11] yuv420p9be [ 0.208][d][vo/gpu/d3d11] yuv420p9 => 3 planes 2x2 16/-7 [r16/r16/r16] (r/g/b) [ 0.208][d][vo/gpu/d3d11] yuv420p10be [ 0.208][d][vo/gpu/d3d11] yuv420p10 => 3 planes 2x2 16/-6 [r16/r16/r16] (r/g/b) [ 0.208][d][vo/gpu/d3d11] yuv422p10be [ 0.208][d][vo/gpu/d3d11] yuv422p10 => 3 planes 2x1 16/-6 [r16/r16/r16] (r/g/b) [ 0.208][d][vo/gpu/d3d11] yuv444p9be [ 0.208][d][vo/gpu/d3d11] yuv444p9 => 3 planes 1x1 16/-7 [r16/r16/r16] (r/g/b) [ 0.208][d][vo/gpu/d3d11] yuv444p10be [ 0.208][d][vo/gpu/d3d11] yuv444p10 => 3 planes 1x1 16/-6 [r16/r16/r16] (r/g/b) [ 0.208][d][vo/gpu/d3d11] yuv422p9be [ 0.208][d][vo/gpu/d3d11] yuv422p9 => 3 planes 2x1 16/-7 [r16/r16/r16] (r/g/b) [ 0.208][d][vo/gpu/d3d11] gbrp => 3 planes 1x1 8/0 [r8/r8/r8] (g/b/r) [ 0.208][d][vo/gpu/d3d11] gbrp9be [ 0.208][d][vo/gpu/d3d11] gbrp9 => 3 planes 1x1 16/-7 [r16/r16/r16] (g/b/r) [ 0.208][d][vo/gpu/d3d11] gbrp10be [ 0.208][d][vo/gpu/d3d11] gbrp10 => 3 planes 1x1 16/-6 [r16/r16/r16] (g/b/r) [ 0.208][d][vo/gpu/d3d11] gbrp16be [ 0.208][d][vo/gpu/d3d11] gbrp16 => 3 planes 1x1 16/0 [r16/r16/r16] (g/b/r) [ 0.208][d][vo/gpu/d3d11] yuva422p => 4 planes 2x1 8/0 [r8/r8/r8/r8] (r/g/b/a) [ 0.208][d][vo/gpu/d3d11] yuva444p => 4 planes 1x1 8/0 [r8/r8/r8/r8] (r/g/b/a) [ 0.208][d][vo/gpu/d3d11] yuva420p9be [ 0.208][d][vo/gpu/d3d11] yuva420p9 => 4 planes 2x2 16/-7 [r16/r16/r16/r16] (r/g/b/a) [ 0.208][d][vo/gpu/d3d11] yuva422p9be [ 0.208][d][vo/gpu/d3d11] yuva422p9 => 4 planes 2x1 16/-7 [r16/r16/r16/r16] (r/g/b/a) [ 0.208][d][vo/gpu/d3d11] yuva444p9be [ 0.208][d][vo/gpu/d3d11] yuva444p9 => 4 planes 1x1 16/-7 [r16/r16/r16/r16] (r/g/b/a) [ 0.208][d][vo/gpu/d3d11] yuva420p10be [ 0.208][d][vo/gpu/d3d11] yuva420p10 => 4 planes 2x2 16/-6 [r16/r16/r16/r16] (r/g/b/a) [ 0.208][d][vo/gpu/d3d11] yuva422p10be [ 0.208][d][vo/gpu/d3d11] yuva422p10 => 4 planes 2x1 16/-6 [r16/r16/r16/r16] (r/g/b/a) [ 0.208][d][vo/gpu/d3d11] yuva444p10be [ 0.208][d][vo/gpu/d3d11] yuva444p10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (r/g/b/a) [ 0.208][d][vo/gpu/d3d11] yuva420p16be [ 0.208][d][vo/gpu/d3d11] yuva420p16 => 4 planes 2x2 16/0 [r16/r16/r16/r16] (r/g/b/a) [ 0.208][d][vo/gpu/d3d11] yuva422p16be [ 0.208][d][vo/gpu/d3d11] yuva422p16 => 4 planes 2x1 16/0 [r16/r16/r16/r16] (r/g/b/a) [ 0.208][d][vo/gpu/d3d11] yuva444p16be [ 0.208][d][vo/gpu/d3d11] yuva444p16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (r/g/b/a) [ 0.208][d][vo/gpu/d3d11] xyz12 [ 0.208][d][vo/gpu/d3d11] xyz12be [ 0.208][d][vo/gpu/d3d11] nv16 => 2 planes 2x1 8/0 [r8/rg8] (r/gb) [ 0.208][d][vo/gpu/d3d11] nv20 => 2 planes 2x1 16/-6 [r16/rg16] (r/gb) [ 0.209][d][vo/gpu/d3d11] nv20be [ 0.209][d][vo/gpu/d3d11] rgba64be [ 0.209][d][vo/gpu/d3d11] bgra64be [ 0.209][d][vo/gpu/d3d11] bgra64 => 1 planes 1x1 16/0 [rgba16] (bgra) [ 0.209][d][vo/gpu/d3d11] yvyu422 [ 0.209][d][vo/gpu/d3d11] ya16be [ 0.209][d][vo/gpu/d3d11] ya16 => 1 planes 1x1 16/0 [rg16] (ra) [ 0.209][d][vo/gpu/d3d11] gbrap => 4 planes 1x1 8/0 [r8/r8/r8/r8] (g/b/r/a) [ 0.209][d][vo/gpu/d3d11] gbrap16be [ 0.209][d][vo/gpu/d3d11] gbrap16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (g/b/r/a) [ 0.209][d][vo/gpu/d3d11] qsv [ 0.209][d][vo/gpu/d3d11] d3d11va_vld [ 0.209][d][vo/gpu/d3d11] yuv420p12be [ 0.209][d][vo/gpu/d3d11] yuv420p12 => 3 planes 2x2 16/-4 [r16/r16/r16] (r/g/b) [ 0.209][d][vo/gpu/d3d11] yuv420p14be [ 0.209][d][vo/gpu/d3d11] yuv420p14 => 3 planes 2x2 16/-2 [r16/r16/r16] (r/g/b) [ 0.209][d][vo/gpu/d3d11] yuv422p12be [ 0.209][d][vo/gpu/d3d11] yuv422p12 => 3 planes 2x1 16/-4 [r16/r16/r16] (r/g/b) [ 0.209][d][vo/gpu/d3d11] yuv422p14be [ 0.209][d][vo/gpu/d3d11] yuv422p14 => 3 planes 2x1 16/-2 [r16/r16/r16] (r/g/b) [ 0.209][d][vo/gpu/d3d11] yuv444p12be [ 0.209][d][vo/gpu/d3d11] yuv444p12 => 3 planes 1x1 16/-4 [r16/r16/r16] (r/g/b) [ 0.209][d][vo/gpu/d3d11] yuv444p14be [ 0.209][d][vo/gpu/d3d11] yuv444p14 => 3 planes 1x1 16/-2 [r16/r16/r16] (r/g/b) [ 0.209][d][vo/gpu/d3d11] gbrp12be [ 0.209][d][vo/gpu/d3d11] gbrp12 => 3 planes 1x1 16/-4 [r16/r16/r16] (g/b/r) [ 0.209][d][vo/gpu/d3d11] gbrp14be [ 0.209][d][vo/gpu/d3d11] gbrp14 => 3 planes 1x1 16/-2 [r16/r16/r16] (g/b/r) [ 0.209][d][vo/gpu/d3d11] yuvj411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b) [ 0.209][d][vo/gpu/d3d11] bayer_bggr8 [ 0.209][d][vo/gpu/d3d11] bayer_rggb8 [ 0.209][d][vo/gpu/d3d11] bayer_gbrg8 [ 0.209][d][vo/gpu/d3d11] bayer_grbg8 [ 0.209][d][vo/gpu/d3d11] bayer_bggr16 [ 0.209][d][vo/gpu/d3d11] bayer_bggr16be [ 0.209][d][vo/gpu/d3d11] bayer_rggb16 [ 0.209][d][vo/gpu/d3d11] bayer_rggb16be [ 0.209][d][vo/gpu/d3d11] bayer_gbrg16 [ 0.209][d][vo/gpu/d3d11] bayer_gbrg16be [ 0.209][d][vo/gpu/d3d11] bayer_grbg16 [ 0.209][d][vo/gpu/d3d11] bayer_grbg16be [ 0.209][d][vo/gpu/d3d11] xvmc [ 0.209][d][vo/gpu/d3d11] yuv440p10 => 3 planes 1x2 16/-6 [r16/r16/r16] (r/g/b) [ 0.209][d][vo/gpu/d3d11] yuv440p10be [ 0.209][d][vo/gpu/d3d11] yuv440p12 => 3 planes 1x2 16/-4 [r16/r16/r16] (r/g/b) [ 0.209][d][vo/gpu/d3d11] yuv440p12be [ 0.209][d][vo/gpu/d3d11] ayuv64 => 1 planes 1x1 16/0 [rgba16] (argb) [ 0.209][d][vo/gpu/d3d11] ayuv64be [ 0.209][d][vo/gpu/d3d11] videotoolbox_vl [ 0.209][d][vo/gpu/d3d11] p010be [ 0.209][d][vo/gpu/d3d11] gbrap12be [ 0.209][d][vo/gpu/d3d11] gbrap12 => 4 planes 1x1 16/-4 [r16/r16/r16/r16] (g/b/r/a) [ 0.209][d][vo/gpu/d3d11] gbrap10be [ 0.209][d][vo/gpu/d3d11] gbrap10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (g/b/r/a) [ 0.209][d][vo/gpu/d3d11] mediacodec [ 0.209][d][vo/gpu/d3d11] gray12be [ 0.209][d][vo/gpu/d3d11] gray12 => 1 planes 1x1 16/-4 [r16] (r) [ 0.209][d][vo/gpu/d3d11] gray10be [ 0.209][d][vo/gpu/d3d11] gray10 => 1 planes 1x1 16/-6 [r16] (r) [ 0.209][d][vo/gpu/d3d11] p016 => 2 planes 2x2 16/0 [r16/rg16] (r/gb) [ 0.209][d][vo/gpu/d3d11] p016be [ 0.209][d][vo/gpu/d3d11] gray9be [ 0.209][d][vo/gpu/d3d11] gray9 => 1 planes 1x1 16/-7 [r16] (r) [ 0.209][d][vo/gpu/d3d11] gbrpf32be [ 0.209][d][vo/gpu/d3d11] gbrpf32 => 3 planes 1x1 32/0 [r32f/r32f/r32f] (g/b/r) [ 0.209][d][vo/gpu/d3d11] gbrapf32be [ 0.209][d][vo/gpu/d3d11] gbrapf32 => 4 planes 1x1 32/0 [r32f/r32f/r32f/r32f] (g/b/r/a) [ 0.209][d][vo/gpu/d3d11] opencl [ 0.209][d][vo/gpu/d3d11] gray14be [ 0.209][d][vo/gpu/d3d11] gray14 => 1 planes 1x1 16/-2 [r16] (r) [ 0.209][d][vo/gpu/d3d11] grayf32be [ 0.209][d][vo/gpu/d3d11] grayf32 => 1 planes 1x1 32/0 [r32f] (r) [ 0.209][v][vo/gpu] Testing FBO format rgba16hf [ 0.209][d][vo/gpu] Resizing texture: 16x16 [ 0.209][v][vo/gpu] Using FBO format rgba16hf. [ 0.209][v][vo/gpu] No advanced processing required. Enabling dumb mode. [ 0.214][v][vo/gpu] Resize: 1920x1080 [ 0.214][v][vo/gpu] Reported display depth: 8 [ 0.214][v][vo/gpu] Assuming 59.940060 FPS for display sync. [ 0.214][v][vd] Container reported FPS: 23.976025 [ 0.214][v][vd] Codec list: [ 0.214][v][vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [ 0.214][v][vd] h264_qsv (h264) - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (Intel Quick Sync Video acceleration) [ 0.214][v][vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [ 0.214][v][vd] Opening decoder h264 [ 0.215][v][vd] Looking at hwdec h264-d3d11va... [ 0.215][v][vo/gpu] Loading hwdec driver 'd3d11-egl' [ 0.215][v][vo/gpu] Loading failed. [ 0.215][v][vo/gpu] Loading hwdec driver 'd3d11-egl-rgb' [ 0.215][v][vo/gpu] Loading failed. [ 0.215][v][vo/gpu] Loading hwdec driver 'dxva2-egl' [ 0.215][v][vo/gpu] Loading failed. [ 0.215][v][vo/gpu] Loading hwdec driver 'd3d11va' [ 0.225][v][vo/gpu] Loading hwdec driver 'dxva2-dxgi' [ 0.272][v][vo/gpu] Loading hwdec driver 'dxva2-dxinterop' [ 0.272][v][vo/gpu] Loading failed. [ 0.272][v][vo/gpu] Loading hwdec driver 'cuda-nvdec' [ 0.272][v][vo/gpu] Loading failed. [ 0.273][v][vd] Trying hardware decoding via h264-d3d11va. [ 0.273][v][vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [ 0.273][v][vf] User filter list: [ 0.273][v][vf] (empty) [ 0.273][v][ad] Codec list: [ 0.273][v][ad] aac - AAC (Advanced Audio Coding) [ 0.273][v][ad] aac_fixed (aac) - AAC (Advanced Audio Coding) [ 0.273][v][ad] Opening decoder aac [ 0.273][v][ad] Requesting 1 threads for decoding. [ 0.275][v][ad] Selected codec: aac (AAC (Advanced Audio Coding)) [ 0.275][d][user_filter_wrapper] Setting option 'tospdif' = 'yes' (flags = 0) [ 0.275][d][user_filter_wrapper] Setting option 'bitrate' = '384' (flags = 0) [ 0.275][d][user_filter_wrapper] Setting option 'minch' = '2' (flags = 0) [ 0.276][v][af] User filter list: [ 0.276][v][af] lavcac3enc (lavcac3enc.00) [ 0.276][v][cplayer] Starting playback... [ 0.276][v][af] [in] 48000Hz 5.1 6ch floatp [ 0.276][v][af] [lavcac3enc] 48000Hz 5.1 6ch floatp [ 0.277][v][af] [userspeed] 48000Hz stereo 2ch spdif-ac3 [ 0.277][v][af] [userspeed] (disabled) [ 0.277][v][af] [convert] 48000Hz stereo 2ch spdif-ac3 [ 0.277][v][vd] Pixel formats supported by decoder: cuda dxva2_vld d3d11va_vld d3d11 yuv420p [ 0.277][v][vd] Codec profile: High (0x64) [ 0.279][v][vd] Requesting pixfmt 'd3d11' from decoder. [ 0.279][d][ffmpeg/video] h264: Decoder GUIDs reported as supported: [ 0.279][d][ffmpeg/video] h264: {ee27417f-5e28-4e65-beea-1d26b508adc9} 103 106 [ 0.279][d][ffmpeg/video] h264: {bf22ad00-03ea-4690-8077-473346209b7e} 103 106 [ 0.279][d][ffmpeg/video] h264: {1b81be68-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.279][d][ffmpeg/video] h264: {4245f676-2bbc-4166-a0bb-54e7b849c380} 103 106 [ 0.279][d][ffmpeg/video] h264: {6719b6fb-5cad-4acb-b00a-f3bfdec38727} 103 106 [ 0.279][d][ffmpeg/video] h264: {9901ccd3-ca12-4b7e-867a-e2223d9255c3} 103 106 [ 0.279][d][ffmpeg/video] h264: {d79be8da-0cf1-4c81-b82a-69a4e236f43d} 103 106 [ 0.279][d][ffmpeg/video] h264: {f9aaccbb-c2b6-4cfc-8779-5707b1760552} 103 106 [ 0.279][d][ffmpeg/video] h264: {1b81bea3-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.280][d][ffmpeg/video] h264: {ca15d19a-2b48-43d6-979e-7a6e9c802ff8} 103 106 [ 0.280][d][ffmpeg/video] h264: {7c74adc6-e2ba-4ade-86de-30beabb40cc1} 103 106 [ 0.280][d][ffmpeg/video] h264: {ed418a9f-010d-4eda-9ae3-9a65358d8d2e} 103 106 [ 0.280][d][ffmpeg/video] h264: {1b81bea2-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.280][d][ffmpeg/video] h264: {1b81be94-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.280][d][ffmpeg/video] h264: {103473e4-10ea-11df-9a92-2ba055d89593} 103 106 [ 0.280][d][ffmpeg/video] h264: {84ad67f6-4c21-419a-9f0b-24f0578906c1} 103 106 [ 0.280][d][ffmpeg/video] h264: {725ad240-786c-471e-ad3c-38f739936517} 103 106 [ 0.280][d][ffmpeg/video] h264: {95664ff5-9e03-4c74-bb4f-9178d6035e58} 103 106 [ 0.280][d][ffmpeg/video] h264: {603a4756-a864-4f91-bb62-2c935b7a1391} 103 106 [ 0.332][d][ffmpeg/video] h264: Reinit context to 1920x800, pix_fmt: d3d11 [ 0.344][i][vd] Using hardware decoding (d3d11va). [ 0.344][v][vd] Decoder format: 1920x800 d3d11[nv12] auto/auto/auto/auto/auto CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000) [ 0.344][v][vd] Using container aspect ratio. [ 0.344][v][vf] [in] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [ 0.344][v][vf] [userdeint] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [ 0.344][v][vf] [userdeint] (disabled) [ 0.344][v][vf] [autorotate] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [ 0.344][v][vf] [autorotate] (disabled) [ 0.344][v][vf] [convert] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [ 0.344][v][vf] [convert] (disabled) [ 0.344][v][vf] [out] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [ 0.345][v][ao] Trying audio driver 'wasapi' [ 0.345][v][ao/wasapi] requested format: 48000 Hz, stereo channels, spdif-ac3 [ 0.345][d][ao/wasapi] Init wasapi [ 0.345][d][ao/wasapi] Find device '' [ 0.349][v][ao/wasapi] No device specified. Selecting default. [ 0.353][v][ao/wasapi] Selecting device '{bcad7374-3085-42e2-a741-ae21c5192b08}' (6 - SONY AVAMP (AMD High Definition Audio Device)) [ 0.353][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{bcad7374-3085-42e2-a741-ae21c5192b08} [ 0.359][d][ao/wasapi] Init wasapi thread [ 0.359][d][ao/wasapi] Activating pAudioClient interface [ 0.362][d][ao/wasapi] Probing formats [ 0.367][v][ao/wasapi] Trying stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) -> unsupported [ 0.367][d][ao/wasapi] Thread shutdown [ 0.367][d][ao/wasapi] Uninit wasapi [ 0.367][d][ao/wasapi] Thread uninit done [ 0.367][d][ao/wasapi] Thread return [ 0.368][d][ao/wasapi] Uninit wasapi done [ 0.368][v][ao] Trying audio driver 'openal' [ 0.368][v][ao/openal] requested format: 48000 Hz, stereo channels, spdif-ac3 [ 0.392][f][ao/openal] Can't find appropriate sample format. [ 0.395][e][ao] Failed to initialize audio driver 'openal' [ 0.395][v][cplayer] Falling back to PCM output. [ 0.396][v][ad] Codec list: [ 0.396][v][ad] aac - AAC (Advanced Audio Coding) [ 0.396][v][ad] aac_fixed (aac) - AAC (Advanced Audio Coding) [ 0.396][v][ad] Opening decoder aac [ 0.396][v][ad] Requesting 1 threads for decoding. [ 0.396][v][ad] Selected codec: aac (AAC (Advanced Audio Coding)) [ 0.396][i][cplayer] VO: [gpu] 1920x800 d3d11[nv12] [ 0.396][v][cplayer] VO: Description: Shader-based GPU Renderer [ 0.397][v][vo/gpu] reconfig to 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [ 0.397][d][vo/gpu] screen size: 1920x1080 [ 0.415][v][vo/gpu] Resize: 1920x1080 [ 0.415][v][vo/gpu] Window size: 1920x1080 [ 0.415][v][vo/gpu] Video source: 1920x800 (1:1) [ 0.415][v][vo/gpu] Video display: (0, 0) 1920x800 -> (0, 140) 1920x800 [ 0.415][v][vo/gpu] Video scale: 1.000000/1.000000 [ 0.415][v][vo/gpu] OSD borders: l=0 t=140 r=0 b=140 [ 0.415][v][vo/gpu] Video borders: l=0 t=140 r=0 b=140 [ 0.415][v][vo/gpu] Reported display depth: 8 [ 0.415][v][vo/gpu] Testing FBO format rgba16hf [ 0.415][d][vo/gpu] Resizing texture: 16x16 [ 0.415][v][vo/gpu] Using FBO format rgba16hf. [ 0.415][v][vo/gpu] No advanced processing required. Enabling dumb mode. [ 0.458][v][vo/gpu/d3d11] shaderc compile status 'success' (0 errors, 0 warnings) [ 0.459][v][vo/gpu/d3d11] Compiled a vertex shader in 44254us [ 0.459][v][vo/gpu/d3d11] shaderc: 42373us, SPIRV-Cross: 245us, D3DCompile: 1636us [ 0.460][d][vo/gpu/d3d11] GLSL source: [ 0.460][d][vo/gpu/d3d11] [ 1] #version 450 [ 0.460][d][vo/gpu/d3d11] [ 2] #define tex1D texture [ 0.460][d][vo/gpu/d3d11] [ 3] #define tex3D texture [ 0.460][d][vo/gpu/d3d11] [ 4] #define LUT_POS(x, lut_size) mix(0.5 / (lut_size), 1.0 - 0.5 / (lut_size), (x)) [ 0.460][d][vo/gpu/d3d11] [ 5] layout(location=0) in vec2 vertex_position; [ 0.460][d][vo/gpu/d3d11] [ 6] layout(location=1) in vec2 vertex_texcoord0; [ 0.460][d][vo/gpu/d3d11] [ 7] layout(location=1) out vec2 texcoord0; [ 0.460][d][vo/gpu/d3d11] [ 8] layout(location=2) in vec2 vertex_texcoord1; [ 0.460][d][vo/gpu/d3d11] [ 9] layout(location=2) out vec2 texcoord1; [ 0.460][d][vo/gpu/d3d11] [ 10] void main() { [ 0.460][d][vo/gpu/d3d11] [ 11] gl_Position = vec4(vertex_position, 1.0, 1.0); [ 0.460][d][vo/gpu/d3d11] [ 12] texcoord0 = vertex_texcoord0; [ 0.460][d][vo/gpu/d3d11] [ 13] texcoord1 = vertex_texcoord1; [ 0.460][d][vo/gpu/d3d11] [ 14] } [ 0.460][d][vo/gpu/d3d11] HLSL source: [ 0.460][d][vo/gpu/d3d11] [ 1] static float4 gl_Position; [ 0.460][d][vo/gpu/d3d11] [ 2] static float2 _18; [ 0.460][d][vo/gpu/d3d11] [ 3] static float2 _27; [ 0.460][d][vo/gpu/d3d11] [ 4] static float2 _28; [ 0.460][d][vo/gpu/d3d11] [ 5] static float2 _30; [ 0.460][d][vo/gpu/d3d11] [ 6] static float2 _31; [ 0.460][d][vo/gpu/d3d11] [ 7] [ 0.460][d][vo/gpu/d3d11] [ 8] struct SPIRV_Cross_Input [ 0.460][d][vo/gpu/d3d11] [ 9] { [ 0.460][d][vo/gpu/d3d11] [ 10] float2 _18 : TEXCOORD0; [ 0.460][d][vo/gpu/d3d11] [ 11] float2 _28 : TEXCOORD1; [ 0.460][d][vo/gpu/d3d11] [ 12] float2 _31 : TEXCOORD2; [ 0.460][d][vo/gpu/d3d11] [ 13] }; [ 0.460][d][vo/gpu/d3d11] [ 14] [ 0.460][d][vo/gpu/d3d11] [ 15] struct SPIRV_Cross_Output [ 0.460][d][vo/gpu/d3d11] [ 16] { [ 0.460][d][vo/gpu/d3d11] [ 17] float2 _27 : TEXCOORD1; [ 0.460][d][vo/gpu/d3d11] [ 18] float2 _30 : TEXCOORD2; [ 0.460][d][vo/gpu/d3d11] [ 19] float4 gl_Position : SV_Position; [ 0.460][d][vo/gpu/d3d11] [ 20] }; [ 0.460][d][vo/gpu/d3d11] [ 21] [ 0.460][d][vo/gpu/d3d11] [ 22] void vert_main() [ 0.460][d][vo/gpu/d3d11] [ 23] { [ 0.460][d][vo/gpu/d3d11] [ 24] gl_Position = float4(_18, 1.0f, 1.0f); [ 0.460][d][vo/gpu/d3d11] [ 25] _27 = _28; [ 0.460][d][vo/gpu/d3d11] [ 26] _30 = _31; [ 0.460][d][vo/gpu/d3d11] [ 27] gl_Position.y = -gl_Position.y; [ 0.460][d][vo/gpu/d3d11] [ 28] } [ 0.460][d][vo/gpu/d3d11] [ 29] [ 0.460][d][vo/gpu/d3d11] [ 30] SPIRV_Cross_Output main(SPIRV_Cross_Input stage_input) [ 0.460][d][vo/gpu/d3d11] [ 31] { [ 0.460][d][vo/gpu/d3d11] [ 32] _18 = stage_input._18; [ 0.460][d][vo/gpu/d3d11] [ 33] _28 = stage_input._28; [ 0.460][d][vo/gpu/d3d11] [ 34] _31 = stage_input._31; [ 0.460][d][vo/gpu/d3d11] [ 35] vert_main(); [ 0.460][d][vo/gpu/d3d11] [ 36] SPIRV_Cross_Output stage_output; [ 0.460][d][vo/gpu/d3d11] [ 37] stage_output.gl_Position = gl_Position; [ 0.460][d][vo/gpu/d3d11] [ 38] stage_output._27 = _27; [ 0.460][d][vo/gpu/d3d11] [ 39] stage_output._30 = _30; [ 0.460][d][vo/gpu/d3d11] [ 40] return stage_output; [ 0.460][d][vo/gpu/d3d11] [ 41] } [ 0.462][v][vo/gpu/d3d11] shaderc compile status 'success' (0 errors, 0 warnings) [ 0.467][v][vo/gpu/d3d11] Compiled a fragment shader in 6693us [ 0.467][v][vo/gpu/d3d11] shaderc: 2187us, SPIRV-Cross: 276us, D3DCompile: 4230us [ 0.467][d][vo/gpu/d3d11] GLSL source: [ 0.467][d][vo/gpu/d3d11] [ 1] #version 450 [ 0.467][d][vo/gpu/d3d11] [ 2] #define tex1D texture [ 0.467][d][vo/gpu/d3d11] [ 3] #define tex3D texture [ 0.467][d][vo/gpu/d3d11] [ 4] #define LUT_POS(x, lut_size) mix(0.5 / (lut_size), 1.0 - 0.5 / (lut_size), (x)) [ 0.467][d][vo/gpu/d3d11] [ 5] layout(location=0) out vec4 out_color; [ 0.467][d][vo/gpu/d3d11] [ 6] layout(location=1) in vec2 texcoord0; [ 0.467][d][vo/gpu/d3d11] [ 7] layout(location=2) in vec2 texcoord1; [ 0.467][d][vo/gpu/d3d11] [ 8] layout(std140, binding=0) uniform UBO { [ 0.467][d][vo/gpu/d3d11] [ 9] layout(offset=0) mat3 colormatrix; [ 0.467][d][vo/gpu/d3d11] [ 10] layout(offset=48) vec3 colormatrix_c; [ 0.467][d][vo/gpu/d3d11] [ 11] layout(offset=64) vec3 src_luma; [ 0.467][d][vo/gpu/d3d11] [ 12] layout(offset=80) vec3 dst_luma; [ 0.467][d][vo/gpu/d3d11] [ 13] layout(offset=96) vec2 texture_size0; [ 0.467][d][vo/gpu/d3d11] [ 14] layout(offset=112) mat2 texture_rot0; [ 0.467][d][vo/gpu/d3d11] [ 15] layout(offset=144) vec2 texture_off0; [ 0.467][d][vo/gpu/d3d11] [ 16] layout(offset=152) vec2 pixel_size0; [ 0.467][d][vo/gpu/d3d11] [ 17] layout(offset=160) vec2 texture_size1; [ 0.467][d][vo/gpu/d3d11] [ 18] layout(offset=176) mat2 texture_rot1; [ 0.467][d][vo/gpu/d3d11] [ 19] layout(offset=208) vec2 texture_off1; [ 0.467][d][vo/gpu/d3d11] [ 20] layout(offset=216) vec2 pixel_size1; [ 0.467][d][vo/gpu/d3d11] [ 21] }; [ 0.467][d][vo/gpu/d3d11] [ 22] layout(binding=0) uniform sampler2D texture0; [ 0.467][d][vo/gpu/d3d11] [ 23] layout(binding=1) uniform sampler2D texture1; [ 0.467][d][vo/gpu/d3d11] [ 24] void main() { [ 0.467][d][vo/gpu/d3d11] [ 25] vec4 color = vec4(0.0, 0.0, 0.0, 1.0); [ 0.467][d][vo/gpu/d3d11] [ 26] color.r = 1.000000 * vec4(texture(texture0, texcoord0)).r; [ 0.467][d][vo/gpu/d3d11] [ 27] color.gb = 1.000000 * vec4(texture(texture1, texcoord1)).rg; [ 0.467][d][vo/gpu/d3d11] [ 28] color = color.rgbr; [ 0.467][d][vo/gpu/d3d11] [ 29] color.rgb = mat3(colormatrix) * color.rgb + colormatrix_c; [ 0.467][d][vo/gpu/d3d11] [ 30] color.a = 1.0; [ 0.467][d][vo/gpu/d3d11] [ 31] // color mapping [ 0.467][d][vo/gpu/d3d11] [ 32] color.rgb *= vec3(1.000000); [ 0.467][d][vo/gpu/d3d11] [ 33] color.rgb *= vec3(1.000000); [ 0.467][d][vo/gpu/d3d11] [ 34] out_color = color; [ 0.467][d][vo/gpu/d3d11] [ 35] } [ 0.467][d][vo/gpu/d3d11] HLSL source: [ 0.467][d][vo/gpu/d3d11] [ 1] cbuffer _53_55 : register(b0) [ 0.467][d][vo/gpu/d3d11] [ 2] { [ 0.467][d][vo/gpu/d3d11] [ 3] row_major float3x3 _55_m0 : packoffset(c0); [ 0.467][d][vo/gpu/d3d11] [ 4] float3 _55_m1 : packoffset(c3); [ 0.467][d][vo/gpu/d3d11] [ 5] float3 _55_m2 : packoffset(c4); [ 0.467][d][vo/gpu/d3d11] [ 6] float3 _55_m3 : packoffset(c5); [ 0.467][d][vo/gpu/d3d11] [ 7] float2 _55_m4 : packoffset(c6); [ 0.467][d][vo/gpu/d3d11] [ 8] row_major float2x2 _55_m5 : packoffset(c7); [ 0.467][d][vo/gpu/d3d11] [ 9] float2 _55_m6 : packoffset(c9); [ 0.467][d][vo/gpu/d3d11] [ 10] float2 _55_m7 : packoffset(c9.z); [ 0.467][d][vo/gpu/d3d11] [ 11] float2 _55_m8 : packoffset(c10); [ 0.467][d][vo/gpu/d3d11] [ 12] row_major float2x2 _55_m9 : packoffset(c11); [ 0.467][d][vo/gpu/d3d11] [ 13] float2 _55_m10 : packoffset(c13); [ 0.467][d][vo/gpu/d3d11] [ 14] float2 _55_m11 : packoffset(c13.z); [ 0.467][d][vo/gpu/d3d11] [ 15] }; [ 0.467][d][vo/gpu/d3d11] [ 16] [ 0.467][d][vo/gpu/d3d11] [ 17] Texture2D<float4> _16 : register(t0); [ 0.467][d][vo/gpu/d3d11] [ 18] SamplerState __16_sampler : register(s0); [ 0.467][d][vo/gpu/d3d11] [ 19] Texture2D<float4> _34 : register(t1); [ 0.467][d][vo/gpu/d3d11] [ 20] SamplerState __34_sampler : register(s1); [ 0.467][d][vo/gpu/d3d11] [ 21] [ 0.467][d][vo/gpu/d3d11] [ 22] static float2 _20; [ 0.467][d][vo/gpu/d3d11] [ 23] static float2 _36; [ 0.467][d][vo/gpu/d3d11] [ 24] static float4 _89; [ 0.467][d][vo/gpu/d3d11] [ 25] [ 0.467][d][vo/gpu/d3d11] [ 26] struct SPIRV_Cross_Input [ 0.467][d][vo/gpu/d3d11] [ 27] { [ 0.467][d][vo/gpu/d3d11] [ 28] float2 _20 : TEXCOORD1; [ 0.467][d][vo/gpu/d3d11] [ 29] float2 _36 : TEXCOORD2; [ 0.468][d][vo/gpu/d3d11] [ 30] }; [ 0.468][d][vo/gpu/d3d11] [ 31] [ 0.468][d][vo/gpu/d3d11] [ 32] struct SPIRV_Cross_Output [ 0.468][d][vo/gpu/d3d11] [ 33] { [ 0.468][d][vo/gpu/d3d11] [ 34] float4 _89 : SV_Target0; [ 0.468][d][vo/gpu/d3d11] [ 35] }; [ 0.468][d][vo/gpu/d3d11] [ 36] [ 0.468][d][vo/gpu/d3d11] [ 37] void frag_main() [ 0.468][d][vo/gpu/d3d11] [ 38] { [ 0.468][d][vo/gpu/d3d11] [ 39] float4 _92 = float4(0.0f, 0.0f, 0.0f, 1.0f); [ 0.468][d][vo/gpu/d3d11] [ 40] _92.x = _16.Sample(__16_sampler, _20).x; [ 0.468][d][vo/gpu/d3d11] [ 41] float2 _45 = _34.Sample(__34_sampler, _36).xy * 1.0f; [ 0.468][d][vo/gpu/d3d11] [ 42] float4 _47 = float4(_92.x, _45.x, _45.y, _92.w); [ 0.468][d][vo/gpu/d3d11] [ 43] float3 _72 = mul(_47.xyz, _55_m0) + _55_m1; [ 0.468][d][vo/gpu/d3d11] [ 44] float4 _94 = float4(_72.x, _72.y, _72.z, _92.x); [ 0.468][d][vo/gpu/d3d11] [ 45] _94.w = 1.0f; [ 0.468][d][vo/gpu/d3d11] [ 46] _89 = float4(_94.x, _94.y, _94.z, _94.w); [ 0.468][d][vo/gpu/d3d11] [ 47] } [ 0.468][d][vo/gpu/d3d11] [ 48] [ 0.468][d][vo/gpu/d3d11] [ 49] SPIRV_Cross_Output main(SPIRV_Cross_Input stage_input) [ 0.468][d][vo/gpu/d3d11] [ 50] { [ 0.468][d][vo/gpu/d3d11] [ 51] _20 = stage_input._20; [ 0.468][d][vo/gpu/d3d11] [ 52] _36 = stage_input._36; [ 0.468][d][vo/gpu/d3d11] [ 53] frag_main(); [ 0.468][d][vo/gpu/d3d11] [ 54] SPIRV_Cross_Output stage_output; [ 0.468][d][vo/gpu/d3d11] [ 55] stage_output._89 = _89; [ 0.468][d][vo/gpu/d3d11] [ 56] return stage_output; [ 0.468][d][vo/gpu/d3d11] [ 57] } [ 0.476][v][cplayer] first video frame after restart shown [ 0.476][v][af] [in] 48000Hz 5.1 6ch floatp [ 0.476][v][af] [lavcac3enc] 48000Hz 5.1 6ch floatp [ 0.477][v][af] [userspeed] 48000Hz stereo 2ch spdif-ac3 [ 0.477][v][af] [convert] 48000Hz stereo 2ch spdif-ac3 [ 0.477][v][ao] Trying audio driver 'wasapi' [ 0.477][v][ao/wasapi] requested format: 48000 Hz, stereo channels, spdif-ac3 [ 0.477][d][ao/wasapi] Init wasapi [ 0.477][d][ao/wasapi] Find device '' [ 0.479][v][ao/wasapi] No device specified. Selecting default. [ 0.482][v][ao/wasapi] Selecting device '{bcad7374-3085-42e2-a741-ae21c5192b08}' (6 - SONY AVAMP (AMD High Definition Audio Device)) [ 0.482][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{bcad7374-3085-42e2-a741-ae21c5192b08} [ 0.488][d][ao/wasapi] Init wasapi thread [ 0.488][d][ao/wasapi] Activating pAudioClient interface [ 0.488][d][ao/wasapi] Probing formats [ 0.489][v][ao/wasapi] Trying stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) -> unsupported [ 0.489][d][ao/wasapi] Thread shutdown [ 0.489][d][ao/wasapi] Uninit wasapi [ 0.489][d][ao/wasapi] Thread uninit done [ 0.489][d][ao/wasapi] Thread return [ 0.489][d][ao/wasapi] Uninit wasapi done [ 0.489][v][ao] Trying audio driver 'openal' [ 0.490][v][ao/openal] requested format: 48000 Hz, stereo channels, spdif-ac3 [ 0.504][f][ao/openal] Can't find appropriate sample format. [ 0.515][e][ao] Failed to initialize audio driver 'openal' [ 0.515][e][cplayer] Could not open/initialize audio device -> no sound. [ 0.515][v][ad] Uninit decoder. [ 0.515][v][lavf] deselect track 1 [ 0.532][i][cplayer] Audio: no audio [ 0.532][v][cplayer] playback restart complete [ 0.534][v][lavf] select track 1 [ 0.572][v][lavf] refresh seek to -0.958292 [ 0.572][v][lavf] execute seek (to -0.958292 flags 32) [ 0.572][v][lavf] seek done [ 0.572][d][cache] request seek: 139518458 <= to=5253144 (cur=149758458) <= 159998458 [ 0.572][v][cache] Dropping cache at pos 5253144, cached range: 139518458-159998458. [ 0.572][v][cache] Seeking underlying stream: 159998458 -> 5253144 [ 0.572][v][ad] Codec list: [ 0.572][v][ad] aac - AAC (Advanced Audio Coding) [ 0.572][v][ad] aac_fixed (aac) - AAC (Advanced Audio Coding) [ 0.572][v][ad] Opening decoder aac [ 0.572][v][ad] Requesting 1 threads for decoding. [ 0.573][v][ad] Selected codec: aac (AAC (Advanced Audio Coding)) [ 0.573][d][user_filter_wrapper] Setting option 'tospdif' = 'yes' (flags = 0) [ 0.573][d][user_filter_wrapper] Setting option 'bitrate' = '384' (flags = 0) [ 0.573][d][user_filter_wrapper] Setting option 'minch' = '2' (flags = 0) [ 0.573][v][af] User filter list: [ 0.573][v][af] lavcac3enc (lavcac3enc.00) [ 0.573][i][cplayer] Track switched: [ 0.573][i][cplayer] (+) Video --vid=1 (*) (h264 1920x800 23.976fps) [ 0.573][i][cplayer] (+) Audio --aid=1 (*) (aac 6ch 48000Hz) [ 0.573][v][cplayer] Set property: aid=1 -> 1 [ 0.573][v][af] [in] 48000Hz 5.1 6ch floatp [ 0.573][v][af] [lavcac3enc] 48000Hz 5.1 6ch floatp [ 0.574][v][af] [userspeed] 48000Hz stereo 2ch spdif-ac3 [ 0.574][v][af] [userspeed] (disabled) [ 0.574][v][af] [convert] 48000Hz stereo 2ch spdif-ac3 [ 0.574][v][ao] Trying audio driver 'wasapi' [ 0.574][v][ao/wasapi] requested format: 48000 Hz, stereo channels, spdif-ac3 [ 0.574][d][ao/wasapi] Init wasapi [ 0.574][d][ao/wasapi] Find device '' [ 0.576][v][ao/wasapi] No device specified. Selecting default. [ 0.580][v][ao/wasapi] Selecting device '{bcad7374-3085-42e2-a741-ae21c5192b08}' (6 - SONY AVAMP (AMD High Definition Audio Device)) [ 0.580][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{bcad7374-3085-42e2-a741-ae21c5192b08} [ 0.585][d][ao/wasapi] Init wasapi thread [ 0.585][d][ao/wasapi] Activating pAudioClient interface [ 0.586][d][ao/wasapi] Probing formats [ 0.587][v][ao/wasapi] Trying stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) -> unsupported [ 0.587][d][ao/wasapi] Thread shutdown [ 0.587][d][ao/wasapi] Uninit wasapi [ 0.587][d][ao/wasapi] Thread uninit done [ 0.587][d][ao/wasapi] Thread return [ 0.587][d][ao/wasapi] Uninit wasapi done [ 0.587][v][ao] Trying audio driver 'openal' [ 0.587][v][ao/openal] requested format: 48000 Hz, stereo channels, spdif-ac3 [ 0.606][f][ao/openal] Can't find appropriate sample format. [ 0.616][e][ao] Failed to initialize audio driver 'openal' [ 0.616][v][cplayer] Falling back to PCM output. [ 0.616][v][ad] Codec list: [ 0.616][v][ad] aac - AAC (Advanced Audio Coding) [ 0.616][v][ad] aac_fixed (aac) - AAC (Advanced Audio Coding) [ 0.616][v][ad] Opening decoder aac [ 0.616][v][ad] Requesting 1 threads for decoding. [ 0.617][v][ad] Selected codec: aac (AAC (Advanced Audio Coding)) [ 0.617][i][cplayer] Track switched: [ 0.617][i][cplayer] (+) Video --vid=1 (*) (h264 1920x800 23.976fps) [ 0.617][i][cplayer] (+) Audio --aid=1 (*) (aac 6ch 48000Hz) [ 0.617][v][cplayer] Set property: sid="no" -> 1 [ 0.617][d][cplayer] Run command: seek, flags=0, args=[3521.000000, absolute, exact] [ 0.617][v][lavf] queuing seek to 3521.000000 [ 0.617][v][lavf] cached range 0: 9.384375 <-> 167.458958 (bof=0, eof=0) [ 0.617][v][lavf] execute seek (to 3521.000000 flags 32) [ 0.618][v][lavf] seek done [ 0.618][v][cplayer] hr-seek, skipping to 3521.000000 [ 0.618][d][cache] request seek: 36546584 <= to=1074546670 (cur=50047590) <= 56961048 [ 0.618][v][cache] Dropping cache at pos 1074546670, cached range: 36546584-57026584. [ 0.618][v][cache] Seeking underlying stream: 57026584 -> 1074546670 [ 0.618][v][af] [in] 48000Hz 5.1 6ch floatp [ 0.618][v][af] [lavcac3enc] 48000Hz 5.1 6ch floatp [ 0.619][v][af] [userspeed] 48000Hz stereo 2ch spdif-ac3 [ 0.619][v][af] [convert] 48000Hz stereo 2ch spdif-ac3 [ 0.619][v][ao] Trying audio driver 'wasapi' [ 0.619][v][ao/wasapi] requested format: 48000 Hz, stereo channels, spdif-ac3 [ 0.619][d][ao/wasapi] Init wasapi [ 0.619][d][ao/wasapi] Find device '' [ 0.621][v][ao/wasapi] No device specified. Selecting default. [ 0.624][v][ao/wasapi] Selecting device '{bcad7374-3085-42e2-a741-ae21c5192b08}' (6 - SONY AVAMP (AMD High Definition Audio Device)) [ 0.624][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{bcad7374-3085-42e2-a741-ae21c5192b08} [ 0.630][d][ao/wasapi] Init wasapi thread [ 0.630][d][ao/wasapi] Activating pAudioClient interface [ 0.631][d][ao/wasapi] Probing formats [ 0.631][v][ao/wasapi] Trying stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) -> unsupported [ 0.631][d][ao/wasapi] Thread shutdown [ 0.631][d][ao/wasapi] Uninit wasapi [ 0.632][d][ao/wasapi] Thread uninit done [ 0.632][d][ao/wasapi] Thread return [ 0.632][d][ao/wasapi] Uninit wasapi done [ 0.632][v][ao] Trying audio driver 'openal' [ 0.632][v][ao/openal] requested format: 48000 Hz, stereo channels, spdif-ac3 [ 0.650][f][ao/openal] Can't find appropriate sample format. [ 0.656][e][ao] Failed to initialize audio driver 'openal' [ 0.656][e][cplayer] Could not open/initialize audio device -> no sound. [ 0.656][v][ad] Uninit decoder. [ 0.656][v][lavf] deselect track 1 [ 0.665][i][cplayer] Audio: no audio [ 0.665][v][vd] Pixel formats supported by decoder: cuda dxva2_vld d3d11va_vld d3d11 yuv420p [ 0.665][v][vd] Codec profile: High (0x64) [ 0.666][v][vd] Requesting pixfmt 'd3d11' from decoder. [ 0.666][d][ffmpeg/video] h264: Decoder GUIDs reported as supported: [ 0.666][d][ffmpeg/video] h264: {ee27417f-5e28-4e65-beea-1d26b508adc9} 103 106 [ 0.666][d][ffmpeg/video] h264: {bf22ad00-03ea-4690-8077-473346209b7e} 103 106 [ 0.666][d][ffmpeg/video] h264: {1b81be68-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.666][d][ffmpeg/video] h264: {4245f676-2bbc-4166-a0bb-54e7b849c380} 103 106 [ 0.666][d][ffmpeg/video] h264: {6719b6fb-5cad-4acb-b00a-f3bfdec38727} 103 106 [ 0.666][d][ffmpeg/video] h264: {9901ccd3-ca12-4b7e-867a-e2223d9255c3} 103 106 [ 0.666][d][ffmpeg/video] h264: {d79be8da-0cf1-4c81-b82a-69a4e236f43d} 103 106 [ 0.666][d][ffmpeg/video] h264: {f9aaccbb-c2b6-4cfc-8779-5707b1760552} 103 106 [ 0.666][d][ffmpeg/video] h264: {1b81bea3-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.666][d][ffmpeg/video] h264: {ca15d19a-2b48-43d6-979e-7a6e9c802ff8} 103 106 [ 0.666][d][ffmpeg/video] h264: {7c74adc6-e2ba-4ade-86de-30beabb40cc1} 103 106 [ 0.666][d][ffmpeg/video] h264: {ed418a9f-010d-4eda-9ae3-9a65358d8d2e} 103 106 [ 0.666][d][ffmpeg/video] h264: {1b81bea2-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.666][d][ffmpeg/video] h264: {1b81be94-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.666][d][ffmpeg/video] h264: {103473e4-10ea-11df-9a92-2ba055d89593} 103 106 [ 0.666][d][ffmpeg/video] h264: {84ad67f6-4c21-419a-9f0b-24f0578906c1} 103 106 [ 0.666][d][ffmpeg/video] h264: {725ad240-786c-471e-ad3c-38f739936517} 103 106 [ 0.666][d][ffmpeg/video] h264: {95664ff5-9e03-4c74-bb4f-9178d6035e58} 103 106 [ 0.667][d][ffmpeg/video] h264: {603a4756-a864-4f91-bb62-2c935b7a1391} 103 106 [ 0.667][d][ffmpeg/video] h264: Reinit context to 1920x800, pix_fmt: d3d11 [ 0.675][v][vd] Decoder format: 1920x800 d3d11[nv12] auto/auto/auto/auto/auto CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000) [ 0.675][v][vd] Using container aspect ratio. [ 1.225][v][cplayer] first video frame after restart shown [ 1.225][v][cplayer] playback restart complete [ 11.239][d][cplayer] Run command: cycle, flags=0, args=[pause, (NULL)] [ 11.239][v][cplayer] Set property: pause -> 1 [ 12.761][d][cplayer] Run command: quit, flags=9, args=[0] [ 12.761][v][cplayer] EOF code: 5 [ 12.761][v][vd] Uninit decoder. [ 12.797][v][ipc_0] Client disconnected [ 12.797][v][ipc_0] Exiting... [ 12.829][v][cache] Terminating cache... [ 12.829][v][cache] Cache exiting... [ 12.831][v][cplayer] finished playback, success (reason 3) [ 12.832][i][cplayer] [ 12.832][i][cplayer] [ 12.832][i][cplayer] Exiting... (Quit) [ 12.832][v][refreshrate] Exiting... [ 12.832][v][ytdl_hook] Exiting... [ 12.832][v][stats] Exiting... [ 12.842][d][vo/gpu] flushing shader cache [ 12.842][v][vo/gpu/win32] uninit
pmac 143 Posted February 13, 2020 Author Posted February 13, 2020 There was no sound with that option.
Guest asrequested Posted February 13, 2020 Posted February 13, 2020 Try again, but change audio-exclusive to no
pmac 143 Posted February 13, 2020 Author Posted February 13, 2020 (edited) Try again, but change audio-exclusive to no It was already unchecked, so I checked it and then unchecked it just to be sure, and I still don't have sound. Edit: sorry, I misunderstood. But the result was the same Edited February 13, 2020 by pmac
pmac 143 Posted February 13, 2020 Author Posted February 13, 2020 My receiver is displaying LPCM 96 whenever Windows makes a noise, does that help at all?
Guest asrequested Posted February 13, 2020 Posted February 13, 2020 I think you may have changed the Windows audio settings. What do you have here?
Guest asrequested Posted February 13, 2020 Posted February 13, 2020 And how is your audio configured in your AMD driver/software?
pmac 143 Posted February 13, 2020 Author Posted February 13, 2020 Just noticed the screenshot I posted of my AMD software was just for "recording". I can't seem to find the general audio section of the software.
pmac 143 Posted February 13, 2020 Author Posted February 13, 2020 I figured it out! I've been scouring the manual for my receiver, and came across "DEC. PRIO" (Whatever that stands for); and it was set to PCM. I switched it to auto, and tried the first filter you gave me and it's working! Thanks for all your help @. I'll likely play with the different options you gave me tomorrow, and see which I like better (unless there's one you think would be the best to stick with).
pmac 143 Posted February 13, 2020 Author Posted February 13, 2020 (edited) Also, @, I'd like to post my log output to make sure this is working right, since the file I tested is AAC 5.1, yet my receiver is displaying "Dolby Digital" which I believe to be AC3, so it seems like even though I have passthrough enabled, it's still being converted because if I disable the filter my receiver displays "LPCM". This is the log output with the filter enabled: [ 0.007][v][cplayer] mpv 0.29.1 Copyright © 2000-2018 mpv/MPlayer/mplayer2 projects [ 0.007][v][cplayer] built on Tue Jan 8 02:05:57 NZDT 2019 [ 0.007][v][cplayer] ffmpeg library versions: [ 0.007][v][cplayer] libavutil 56.22.100 [ 0.007][v][cplayer] libavcodec 58.35.100 [ 0.007][v][cplayer] libavformat 58.20.100 [ 0.007][v][cplayer] libswscale 5.3.100 [ 0.007][v][cplayer] libavfilter 7.40.101 [ 0.007][v][cplayer] libswresample 3.3.100 [ 0.007][v][cplayer] ffmpeg version: n4.1 [ 0.007][v][cplayer] [ 0.007][v][cplayer] Configuration: /home/luke/github/mpv-winbuild-cmake/build64/packages/mpv-prefix/src/mpv/waf configure --enable-static-build --enable-pdf-build --disable-manpage-build --enable-libmpv-shared --enable-lua --enable-javascript --enable-libarchive --enable-libass --enable-libbluray --enable-dvdread --enable-dvdnav --enable-uchardet --enable-rubberband --enable-lcms2 --enable-openal --enable-vapoursynth --prefix=/home/luke/github/mpv-winbuild-cmake/build64/install/mingw [ 0.007][v][cplayer] List of enabled features: asm atomics build-date cplayer crossc cuda-hwaccel d3d-hwaccel d3d11 d3d9-hwaccel debug-build direct3d dos-paths drmprime dvdnav dvdread dvdread-common egl-angle egl-angle-win32 egl-helpers ffmpeg ffnvcodec gl gl-dxinterop gl-dxinterop-d3d9 gl-win32 glob glob-win32 gnuc gpl iconv javascript jpeg lcms2 libaf libarchive libass libass-osd libav-any libavcodec libavdevice libbluray libm libmpv-shared lua luajit mingw noexecstack openal optimize plain-gl posix-or-mingw rubberband shaderc shaderc-static static-build stdatomic uchardet vapoursynth vapoursynth-core vapoursynth-lazy vulkan wasapi win32-desktop win32-internal-pthreads win32-pipes zlib [ 0.007][d][ytdl_hook] Loading lua script @ytdl_hook.lua... [ 0.007][d][stats] Loading lua script @[member="Stats"].lua... [ 0.007][v][ipc] Starting IPC master [ 0.008][d][stats] loading mp.defaults [ 0.008][d][ytdl_hook] loading mp.defaults [ 0.008][d][stats] loading @[member="Stats"].lua [ 0.008][d][ytdl_hook] loading @ytdl_hook.lua [ 0.008][v][ipc] Listening to IPC pipe. [ 0.008][v][ipc_0] Client connected [ 0.009][d][ytdl_hook] reading options for ytdl_hook [ 0.009][d][stats] reading options for stats [ 0.009][d][refreshrate] Loading lua script C:/Users/Patrick/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/refreshrate.lua... [ 0.009][v][cplayer] Waiting for scripts... [ 0.009][v][ytdl_hook] script-opts/ytdl_hook.conf not found. [ 0.009][v][stats] script-opts/stats.conf not found. [ 0.009][v][ytdl_hook] lua-settings/ytdl_hook.conf not found. [ 0.009][d][refreshrate] loading mp.defaults [ 0.009][v][stats] lua-settings/stats.conf not found. [ 0.010][d][refreshrate] loading file C:/Users/Patrick/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/refreshrate.lua [ 0.010][d][cplayer] Run command: define-section, flags=0, args=[input_stats, i script-binding stats/display-stats [ 0.010][d][cplayer] , default] [ 0.010][d][cplayer] Run command: enable-section, flags=0, args=[input_stats, allow-hide-cursor+allow-vo-dragging] [ 0.010][d][cplayer] Run command: define-section, flags=0, args=[input_forced_stats, , force] [ 0.010][d][cplayer] Run command: enable-section, flags=0, args=[input_forced_stats, allow-hide-cursor+allow-vo-dragging] [ 0.010][d][cplayer] Run command: define-section, flags=0, args=[input_stats, I script-binding stats/display-stats-toggle [ 0.010][d][cplayer] i script-binding stats/display-stats [ 0.010][d][cplayer] , default] [ 0.010][d][cplayer] Run command: enable-section, flags=0, args=[input_stats, allow-hide-cursor+allow-vo-dragging] [ 0.010][d][cplayer] Run command: define-section, flags=0, args=[input_forced_stats, , force] [ 0.010][d][cplayer] Run command: enable-section, flags=0, args=[input_forced_stats, allow-hide-cursor+allow-vo-dragging] [ 0.010][d][cplayer] Run command: define-section, flags=0, args=[input_stats, i script-binding stats/display-stats [ 0.010][d][cplayer] I script-binding stats/display-stats-toggle [ 0.010][d][cplayer] , default] [ 0.010][d][cplayer] Run command: enable-section, flags=0, args=[input_stats, allow-hide-cursor+allow-vo-dragging] [ 0.010][d][cplayer] Run command: define-section, flags=0, args=[input_forced_stats, , force] [ 0.010][d][cplayer] Run command: enable-section, flags=0, args=[input_forced_stats, allow-hide-cursor+allow-vo-dragging] [ 0.010][d][cplayer] Run command: define-section, flags=0, args=[input_stats, i script-binding stats/display-stats [ 0.010][d][cplayer] I script-binding stats/display-stats-toggle [ 0.010][d][cplayer] , default] [ 0.010][d][cplayer] Run command: enable-section, flags=0, args=[input_stats, allow-hide-cursor+allow-vo-dragging] [ 0.010][d][cplayer] Run command: define-section, flags=0, args=[input_forced_stats, , force] [ 0.010][d][cplayer] Run command: enable-section, flags=0, args=[input_forced_stats, allow-hide-cursor+allow-vo-dragging] [ 0.010][v][cplayer] Done loading scripts. [ 0.012][v][cplayer] Set property: volume=100 -> 1 [ 0.012][d][cplayer] Run command: loadfile, flags=0, args=[\\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4, replace, ] [ 0.013][i][cplayer] Playing: \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4 [ 0.013][v][cplayer] Running hook: ytdl_hook/on_load [ 0.013][v][ytdl_hook] ytdl:// hook [ 0.013][v][ytdl_hook] not a ytdl:// url [ 0.013][v][ifo] Opening \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4 [ 0.013][v][ifo_dvdnav] Opening \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4 [ 0.014][v][bdmv/bluray] Opening \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4 [ 0.015][v][file] Opening \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4 [ 0.016][d][file] Stream opened successfully. [ 0.017][v][cache] Cache size set to 20000 KiB (10000 KiB backbuffer) [ 0.017][v][demux] Trying demuxers for level=normal. [ 0.017][d][demux] Trying demuxer: disc (force-level: normal) [ 0.017][d][demux] Trying demuxer: edl (force-level: normal) [ 0.017][d][demux] Trying demuxer: cue (force-level: normal) [ 0.017][d][demux] Trying demuxer: rawaudio (force-level: normal) [ 0.018][d][demux] Trying demuxer: rawvideo (force-level: normal) [ 0.018][d][demux] Trying demuxer: mkv (force-level: normal) [ 0.018][d][demux] Trying demuxer: libarchive (force-level: normal) [ 0.018][d][demux] Trying demuxer: rar (force-level: normal) [ 0.018][d][demux] Trying demuxer: lavf (force-level: normal) [ 0.019][v][lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [ 0.076][v][demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [ 0.076][v][cache] blocking for STREAM_CTRL 6 [ 0.076][v][cplayer] Opening done: \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\Godzilla.King.Of.The.Monsters.2019.1080p.WEBRip.x264-[YTS.LT].mp4 [ 0.077][v][find_files] Loading external files in \\HELLSPAWN\Media Browser\HD Movies\Godzilla King of the Monsters (2019)\ [ 0.079][v][cplayer] Running hook: ytdl_hook/on_preloaded [ 0.079][v][lavf] select track 0 [ 0.079][v][lavf] select track 1 [ 0.079][i][cplayer] (+) Video --vid=1 (*) (h264 1920x800 23.976fps) [ 0.079][i][cplayer] (+) Audio --aid=1 (*) (aac 6ch 48000Hz) [ 0.080][v][vo/gpu] Probing for best GPU context. [ 0.080][v][vo/gpu/d3d11] Initializing GPU context 'd3d11' [ 0.106][v][vo/gpu/d3d11] Using Direct3D 11 feature level 11_1 [ 0.106][v][vo/gpu/d3d11] Device Name: AMD Radeon R9 200 Series [ 0.106][v][vo/gpu/d3d11] Device ID: 1002:6810 (rev 00) [ 0.106][v][vo/gpu/d3d11] Subsystem ID: 1462:3030 [ 0.106][v][vo/gpu/d3d11] LUID: 000000000000c531 [ 0.106][v][vo/gpu/d3d11] Initializing SPIR-V compiler 'shaderc' [ 0.106][v][vo/gpu/d3d11] Using Direct3D 11.1 runtime [ 0.106][v][vo/gpu/d3d11] Maximum Texture2D size: 16384x16384 [ 0.107][v][vo/gpu/d3d11] D3DCompiler version: 10.0.18362.1 [ 0.179][v][vo/gpu/win32] resize window: 1920:1080 [ 0.179][v][vo/gpu/win32] DPI detected from the new API: 96 [ 0.179][v][vo/gpu/win32] display-fps: 59.940060 [ 0.183][v][vo/gpu/win32] color-profile: C:\WINDOWS\system32\spool\drivers\color\sRGB Color Space Profile.icm [ 0.183][d][vo/gpu/win32] move window: 0:0 [ 0.195][v][vo/gpu/d3d11] Using DXGI 1.2+ [ 0.195][v][vo/gpu/d3d11] Using flip-model presentation [ 0.196][d][vo/gpu/d3d11] Texture formats: [ 0.196][d][vo/gpu/d3d11] NAME COMP*TYPE SIZE DEPTH PER COMP. [ 0.196][d][vo/gpu/d3d11] r8 1*unorm 1B LF CR {8} [ 0.196][d][vo/gpu/d3d11] rg8 2*unorm 2B LF CR {8 8} [ 0.196][d][vo/gpu/d3d11] rgba8 4*unorm 4B LF CR {8 8 8 8} [ 0.196][d][vo/gpu/d3d11] r16 1*unorm 2B LF CR {16} [ 0.196][d][vo/gpu/d3d11] rg16 2*unorm 4B LF CR {16 16} [ 0.196][d][vo/gpu/d3d11] rgba16 4*unorm 8B LF CR {16 16 16 16} [ 0.196][d][vo/gpu/d3d11] r32ui 1*uint 4B {32} [ 0.196][d][vo/gpu/d3d11] rg32ui 2*uint 8B {32 32} [ 0.196][d][vo/gpu/d3d11] rgb32ui 3*uint 12B {32 32 32} [ 0.196][d][vo/gpu/d3d11] rgba32ui 4*uint 16B {32 32 32 32} [ 0.196][d][vo/gpu/d3d11] r16hf 1*float 2B LF CR {16} [ 0.196][d][vo/gpu/d3d11] rg16hf 2*float 4B LF CR {16 16} [ 0.196][d][vo/gpu/d3d11] rgba16hf 4*float 8B LF CR {16 16 16 16} [ 0.196][d][vo/gpu/d3d11] r32f 1*float 4B LF CR {32} [ 0.196][d][vo/gpu/d3d11] rg32f 2*float 8B LF CR {32 32} [ 0.196][d][vo/gpu/d3d11] rgb32f 3*float 12B {32 32 32} [ 0.196][d][vo/gpu/d3d11] rgba32f 4*float 16B LF CR {32 32 32 32} [ 0.196][d][vo/gpu/d3d11] rgb10_a2 4*unorm 4B LF CR {10 10 10 2} [ 0.196][d][vo/gpu/d3d11] bgra8 4*unorm 4B LF CR {8 8 8 8} [ 0.196][d][vo/gpu/d3d11] bgrx8 3*unorm 4B LF CR {8 8 8} [ 0.196][d][vo/gpu/d3d11] LA = LUMINANCE_ALPHA hack format [ 0.196][d][vo/gpu/d3d11] LF = linear filterable [ 0.196][d][vo/gpu/d3d11] CR = can be used for render targets [ 0.196][d][vo/gpu/d3d11] Image formats: [ 0.196][d][vo/gpu/d3d11] yuv444p => 3 planes 1x1 8/0 [r8/r8/r8] (r/g/b) [ 0.196][d][vo/gpu/d3d11] yuv420p => 3 planes 2x2 8/0 [r8/r8/r8] (r/g/b) [ 0.196][d][vo/gpu/d3d11] gray => 1 planes 1x1 8/0 [r8] (r) [ 0.196][d][vo/gpu/d3d11] gray16 => 1 planes 1x1 16/0 [r16] (r) [ 0.196][d][vo/gpu/d3d11] uyvy422 [ 0.196][d][vo/gpu/d3d11] nv12 => 2 planes 2x2 8/0 [r8/rg8] (r/gb) [ 0.196][d][vo/gpu/d3d11] p010 => 2 planes 2x2 16/6 [r16/rg16] (r/gb) [ 0.196][d][vo/gpu/d3d11] argb => 1 planes 1x1 8/0 [rgba8] (argb) [ 0.196][d][vo/gpu/d3d11] bgra => 1 planes 1x1 8/0 [rgba8] (bgra) [ 0.196][d][vo/gpu/d3d11] abgr => 1 planes 1x1 8/0 [rgba8] (abgr) [ 0.196][d][vo/gpu/d3d11] rgba => 1 planes 1x1 8/0 [rgba8] (rgba) [ 0.196][d][vo/gpu/d3d11] bgr24 [ 0.196][d][vo/gpu/d3d11] rgb24 [ 0.196][d][vo/gpu/d3d11] 0rgb => 1 planes 1x1 8/0 [rgba8] (_rgb) [ 0.196][d][vo/gpu/d3d11] bgr0 => 1 planes 1x1 8/0 [rgba8] (bgr) [ 0.196][d][vo/gpu/d3d11] 0bgr => 1 planes 1x1 8/0 [rgba8] (_bgr) [ 0.196][d][vo/gpu/d3d11] rgb0 => 1 planes 1x1 8/0 [rgba8] (rgb) [ 0.196][d][vo/gpu/d3d11] rgba64 => 1 planes 1x1 16/0 [rgba16] (rgba) [ 0.196][d][vo/gpu/d3d11] rgb565 [ 0.196][d][vo/gpu/d3d11] vdpau [ 0.196][d][vo/gpu/d3d11] vdpau_output [ 0.196][d][vo/gpu/d3d11] vaapi [ 0.196][d][vo/gpu/d3d11] d3d11 [ 0.196][d][vo/gpu/d3d11] dxva2_vld [ 0.196][d][vo/gpu/d3d11] mmal [ 0.196][d][vo/gpu/d3d11] videotoolbox [ 0.196][d][vo/gpu/d3d11] drm_prime [ 0.196][d][vo/gpu/d3d11] cuda [ 0.196][d][vo/gpu/d3d11] yuyv422 [ 0.196][d][vo/gpu/d3d11] yuv422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b) [ 0.196][d][vo/gpu/d3d11] yuv410p => 3 planes 4x4 8/0 [r8/r8/r8] (r/g/b) [ 0.196][d][vo/gpu/d3d11] yuv411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b) [ 0.196][d][vo/gpu/d3d11] monow [ 0.196][d][vo/gpu/d3d11] monob [ 0.196][d][vo/gpu/d3d11] pal8 [ 0.196][d][vo/gpu/d3d11] yuvj422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b) [ 0.196][d][vo/gpu/d3d11] uyyvyy411 [ 0.196][d][vo/gpu/d3d11] bgr8 [ 0.196][d][vo/gpu/d3d11] bgr4 [ 0.196][d][vo/gpu/d3d11] bgr4_byte [ 0.196][d][vo/gpu/d3d11] rgb8 [ 0.196][d][vo/gpu/d3d11] rgb4 [ 0.196][d][vo/gpu/d3d11] rgb4_byte [ 0.196][d][vo/gpu/d3d11] nv21 => 2 planes 2x2 8/0 [r8/rg8] (r/bg) [ 0.196][d][vo/gpu/d3d11] gray16be [ 0.196][d][vo/gpu/d3d11] yuv440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b) [ 0.196][d][vo/gpu/d3d11] yuvj440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b) [ 0.196][d][vo/gpu/d3d11] yuva420p => 4 planes 2x2 8/0 [r8/r8/r8/r8] (r/g/b/a) [ 0.196][d][vo/gpu/d3d11] rgb48be [ 0.196][d][vo/gpu/d3d11] rgb48 [ 0.196][d][vo/gpu/d3d11] rgb565be [ 0.196][d][vo/gpu/d3d11] rgb555be [ 0.196][d][vo/gpu/d3d11] rgb555 [ 0.196][d][vo/gpu/d3d11] bgr565be [ 0.196][d][vo/gpu/d3d11] bgr565 [ 0.196][d][vo/gpu/d3d11] bgr555be [ 0.196][d][vo/gpu/d3d11] bgr555 [ 0.196][d][vo/gpu/d3d11] vaapi_moco [ 0.196][d][vo/gpu/d3d11] vaapi_idct [ 0.196][d][vo/gpu/d3d11] yuv420p16 => 3 planes 2x2 16/0 [r16/r16/r16] (r/g/b) [ 0.196][d][vo/gpu/d3d11] yuv420p16be [ 0.196][d][vo/gpu/d3d11] yuv422p16 => 3 planes 2x1 16/0 [r16/r16/r16] (r/g/b) [ 0.196][d][vo/gpu/d3d11] yuv422p16be [ 0.196][d][vo/gpu/d3d11] yuv444p16 => 3 planes 1x1 16/0 [r16/r16/r16] (r/g/b) [ 0.196][d][vo/gpu/d3d11] yuv444p16be [ 0.196][d][vo/gpu/d3d11] rgb444 [ 0.196][d][vo/gpu/d3d11] rgb444be [ 0.196][d][vo/gpu/d3d11] bgr444 [ 0.196][d][vo/gpu/d3d11] bgr444be [ 0.196][d][vo/gpu/d3d11] ya8 => 1 planes 1x1 8/0 [rg8] (ra) [ 0.196][d][vo/gpu/d3d11] bgr48be [ 0.196][d][vo/gpu/d3d11] bgr48 [ 0.196][d][vo/gpu/d3d11] yuv420p9be [ 0.197][d][vo/gpu/d3d11] yuv420p9 => 3 planes 2x2 16/-7 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] yuv420p10be [ 0.197][d][vo/gpu/d3d11] yuv420p10 => 3 planes 2x2 16/-6 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] yuv422p10be [ 0.197][d][vo/gpu/d3d11] yuv422p10 => 3 planes 2x1 16/-6 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] yuv444p9be [ 0.197][d][vo/gpu/d3d11] yuv444p9 => 3 planes 1x1 16/-7 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] yuv444p10be [ 0.197][d][vo/gpu/d3d11] yuv444p10 => 3 planes 1x1 16/-6 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] yuv422p9be [ 0.197][d][vo/gpu/d3d11] yuv422p9 => 3 planes 2x1 16/-7 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] gbrp => 3 planes 1x1 8/0 [r8/r8/r8] (g/b/r) [ 0.197][d][vo/gpu/d3d11] gbrp9be [ 0.197][d][vo/gpu/d3d11] gbrp9 => 3 planes 1x1 16/-7 [r16/r16/r16] (g/b/r) [ 0.197][d][vo/gpu/d3d11] gbrp10be [ 0.197][d][vo/gpu/d3d11] gbrp10 => 3 planes 1x1 16/-6 [r16/r16/r16] (g/b/r) [ 0.197][d][vo/gpu/d3d11] gbrp16be [ 0.197][d][vo/gpu/d3d11] gbrp16 => 3 planes 1x1 16/0 [r16/r16/r16] (g/b/r) [ 0.197][d][vo/gpu/d3d11] yuva422p => 4 planes 2x1 8/0 [r8/r8/r8/r8] (r/g/b/a) [ 0.197][d][vo/gpu/d3d11] yuva444p => 4 planes 1x1 8/0 [r8/r8/r8/r8] (r/g/b/a) [ 0.197][d][vo/gpu/d3d11] yuva420p9be [ 0.197][d][vo/gpu/d3d11] yuva420p9 => 4 planes 2x2 16/-7 [r16/r16/r16/r16] (r/g/b/a) [ 0.197][d][vo/gpu/d3d11] yuva422p9be [ 0.197][d][vo/gpu/d3d11] yuva422p9 => 4 planes 2x1 16/-7 [r16/r16/r16/r16] (r/g/b/a) [ 0.197][d][vo/gpu/d3d11] yuva444p9be [ 0.197][d][vo/gpu/d3d11] yuva444p9 => 4 planes 1x1 16/-7 [r16/r16/r16/r16] (r/g/b/a) [ 0.197][d][vo/gpu/d3d11] yuva420p10be [ 0.197][d][vo/gpu/d3d11] yuva420p10 => 4 planes 2x2 16/-6 [r16/r16/r16/r16] (r/g/b/a) [ 0.197][d][vo/gpu/d3d11] yuva422p10be [ 0.197][d][vo/gpu/d3d11] yuva422p10 => 4 planes 2x1 16/-6 [r16/r16/r16/r16] (r/g/b/a) [ 0.197][d][vo/gpu/d3d11] yuva444p10be [ 0.197][d][vo/gpu/d3d11] yuva444p10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (r/g/b/a) [ 0.197][d][vo/gpu/d3d11] yuva420p16be [ 0.197][d][vo/gpu/d3d11] yuva420p16 => 4 planes 2x2 16/0 [r16/r16/r16/r16] (r/g/b/a) [ 0.197][d][vo/gpu/d3d11] yuva422p16be [ 0.197][d][vo/gpu/d3d11] yuva422p16 => 4 planes 2x1 16/0 [r16/r16/r16/r16] (r/g/b/a) [ 0.197][d][vo/gpu/d3d11] yuva444p16be [ 0.197][d][vo/gpu/d3d11] yuva444p16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (r/g/b/a) [ 0.197][d][vo/gpu/d3d11] xyz12 [ 0.197][d][vo/gpu/d3d11] xyz12be [ 0.197][d][vo/gpu/d3d11] nv16 => 2 planes 2x1 8/0 [r8/rg8] (r/gb) [ 0.197][d][vo/gpu/d3d11] nv20 => 2 planes 2x1 16/-6 [r16/rg16] (r/gb) [ 0.197][d][vo/gpu/d3d11] nv20be [ 0.197][d][vo/gpu/d3d11] rgba64be [ 0.197][d][vo/gpu/d3d11] bgra64be [ 0.197][d][vo/gpu/d3d11] bgra64 => 1 planes 1x1 16/0 [rgba16] (bgra) [ 0.197][d][vo/gpu/d3d11] yvyu422 [ 0.197][d][vo/gpu/d3d11] ya16be [ 0.197][d][vo/gpu/d3d11] ya16 => 1 planes 1x1 16/0 [rg16] (ra) [ 0.197][d][vo/gpu/d3d11] gbrap => 4 planes 1x1 8/0 [r8/r8/r8/r8] (g/b/r/a) [ 0.197][d][vo/gpu/d3d11] gbrap16be [ 0.197][d][vo/gpu/d3d11] gbrap16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (g/b/r/a) [ 0.197][d][vo/gpu/d3d11] qsv [ 0.197][d][vo/gpu/d3d11] d3d11va_vld [ 0.197][d][vo/gpu/d3d11] yuv420p12be [ 0.197][d][vo/gpu/d3d11] yuv420p12 => 3 planes 2x2 16/-4 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] yuv420p14be [ 0.197][d][vo/gpu/d3d11] yuv420p14 => 3 planes 2x2 16/-2 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] yuv422p12be [ 0.197][d][vo/gpu/d3d11] yuv422p12 => 3 planes 2x1 16/-4 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] yuv422p14be [ 0.197][d][vo/gpu/d3d11] yuv422p14 => 3 planes 2x1 16/-2 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] yuv444p12be [ 0.197][d][vo/gpu/d3d11] yuv444p12 => 3 planes 1x1 16/-4 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] yuv444p14be [ 0.197][d][vo/gpu/d3d11] yuv444p14 => 3 planes 1x1 16/-2 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] gbrp12be [ 0.197][d][vo/gpu/d3d11] gbrp12 => 3 planes 1x1 16/-4 [r16/r16/r16] (g/b/r) [ 0.197][d][vo/gpu/d3d11] gbrp14be [ 0.197][d][vo/gpu/d3d11] gbrp14 => 3 planes 1x1 16/-2 [r16/r16/r16] (g/b/r) [ 0.197][d][vo/gpu/d3d11] yuvj411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b) [ 0.197][d][vo/gpu/d3d11] bayer_bggr8 [ 0.197][d][vo/gpu/d3d11] bayer_rggb8 [ 0.197][d][vo/gpu/d3d11] bayer_gbrg8 [ 0.197][d][vo/gpu/d3d11] bayer_grbg8 [ 0.197][d][vo/gpu/d3d11] bayer_bggr16 [ 0.197][d][vo/gpu/d3d11] bayer_bggr16be [ 0.197][d][vo/gpu/d3d11] bayer_rggb16 [ 0.197][d][vo/gpu/d3d11] bayer_rggb16be [ 0.197][d][vo/gpu/d3d11] bayer_gbrg16 [ 0.197][d][vo/gpu/d3d11] bayer_gbrg16be [ 0.197][d][vo/gpu/d3d11] bayer_grbg16 [ 0.197][d][vo/gpu/d3d11] bayer_grbg16be [ 0.197][d][vo/gpu/d3d11] xvmc [ 0.197][d][vo/gpu/d3d11] yuv440p10 => 3 planes 1x2 16/-6 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] yuv440p10be [ 0.197][d][vo/gpu/d3d11] yuv440p12 => 3 planes 1x2 16/-4 [r16/r16/r16] (r/g/b) [ 0.197][d][vo/gpu/d3d11] yuv440p12be [ 0.197][d][vo/gpu/d3d11] ayuv64 => 1 planes 1x1 16/0 [rgba16] (argb) [ 0.197][d][vo/gpu/d3d11] ayuv64be [ 0.197][d][vo/gpu/d3d11] videotoolbox_vl [ 0.197][d][vo/gpu/d3d11] p010be [ 0.197][d][vo/gpu/d3d11] gbrap12be [ 0.197][d][vo/gpu/d3d11] gbrap12 => 4 planes 1x1 16/-4 [r16/r16/r16/r16] (g/b/r/a) [ 0.197][d][vo/gpu/d3d11] gbrap10be [ 0.197][d][vo/gpu/d3d11] gbrap10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (g/b/r/a) [ 0.197][d][vo/gpu/d3d11] mediacodec [ 0.197][d][vo/gpu/d3d11] gray12be [ 0.197][d][vo/gpu/d3d11] gray12 => 1 planes 1x1 16/-4 [r16] (r) [ 0.197][d][vo/gpu/d3d11] gray10be [ 0.197][d][vo/gpu/d3d11] gray10 => 1 planes 1x1 16/-6 [r16] (r) [ 0.197][d][vo/gpu/d3d11] p016 => 2 planes 2x2 16/0 [r16/rg16] (r/gb) [ 0.197][d][vo/gpu/d3d11] p016be [ 0.197][d][vo/gpu/d3d11] gray9be [ 0.197][d][vo/gpu/d3d11] gray9 => 1 planes 1x1 16/-7 [r16] (r) [ 0.197][d][vo/gpu/d3d11] gbrpf32be [ 0.197][d][vo/gpu/d3d11] gbrpf32 => 3 planes 1x1 32/0 [r32f/r32f/r32f] (g/b/r) [ 0.197][d][vo/gpu/d3d11] gbrapf32be [ 0.197][d][vo/gpu/d3d11] gbrapf32 => 4 planes 1x1 32/0 [r32f/r32f/r32f/r32f] (g/b/r/a) [ 0.197][d][vo/gpu/d3d11] opencl [ 0.197][d][vo/gpu/d3d11] gray14be [ 0.197][d][vo/gpu/d3d11] gray14 => 1 planes 1x1 16/-2 [r16] (r) [ 0.198][d][vo/gpu/d3d11] grayf32be [ 0.198][d][vo/gpu/d3d11] grayf32 => 1 planes 1x1 32/0 [r32f] (r) [ 0.198][v][vo/gpu] Testing FBO format rgba16hf [ 0.198][d][vo/gpu] Resizing texture: 16x16 [ 0.198][v][vo/gpu] Using FBO format rgba16hf. [ 0.198][v][vo/gpu] No advanced processing required. Enabling dumb mode. [ 0.210][v][vo/gpu] Resize: 1920x1080 [ 0.210][v][vo/gpu] Reported display depth: 8 [ 0.210][v][vo/gpu] Assuming 59.940060 FPS for display sync. [ 0.211][v][vd] Container reported FPS: 23.976025 [ 0.211][v][vd] Codec list: [ 0.211][v][vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [ 0.211][v][vd] h264_qsv (h264) - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (Intel Quick Sync Video acceleration) [ 0.211][v][vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [ 0.211][v][vd] Opening decoder h264 [ 0.211][v][vd] Looking at hwdec h264-d3d11va... [ 0.211][v][vo/gpu] Loading hwdec driver 'd3d11-egl' [ 0.211][v][vo/gpu] Loading failed. [ 0.211][v][vo/gpu] Loading hwdec driver 'd3d11-egl-rgb' [ 0.211][v][vo/gpu] Loading failed. [ 0.211][v][vo/gpu] Loading hwdec driver 'dxva2-egl' [ 0.211][v][vo/gpu] Loading failed. [ 0.211][v][vo/gpu] Loading hwdec driver 'd3d11va' [ 0.222][v][vo/gpu] Loading hwdec driver 'dxva2-dxgi' [ 0.263][v][vo/gpu] Loading hwdec driver 'dxva2-dxinterop' [ 0.263][v][vo/gpu] Loading failed. [ 0.263][v][vo/gpu] Loading hwdec driver 'cuda-nvdec' [ 0.263][v][vo/gpu] Loading failed. [ 0.263][v][vd] Trying hardware decoding via h264-d3d11va. [ 0.263][v][vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [ 0.263][v][vf] User filter list: [ 0.263][v][vf] (empty) [ 0.264][v][ad] Codec list: [ 0.264][v][ad] aac - AAC (Advanced Audio Coding) [ 0.264][v][ad] aac_fixed (aac) - AAC (Advanced Audio Coding) [ 0.264][v][ad] Opening decoder aac [ 0.264][v][ad] Requesting 1 threads for decoding. [ 0.266][v][ad] Selected codec: aac (AAC (Advanced Audio Coding)) [ 0.266][d][user_filter_wrapper] Setting option 'tospdif' = 'yes' (flags = 0) [ 0.266][d][user_filter_wrapper] Setting option 'bitrate' = '640' (flags = 0) [ 0.266][d][user_filter_wrapper] Setting option 'minch' = '2' (flags = 0) [ 0.266][v][af] User filter list: [ 0.266][v][af] lavcac3enc (lavcac3enc.00) [ 0.266][v][cplayer] Starting playback... [ 0.266][v][af] [in] 48000Hz 5.1 6ch floatp [ 0.266][v][af] [lavcac3enc] 48000Hz 5.1 6ch floatp [ 0.267][v][af] [userspeed] 48000Hz stereo 2ch spdif-ac3 [ 0.267][v][af] [userspeed] (disabled) [ 0.267][v][af] [convert] 48000Hz stereo 2ch spdif-ac3 [ 0.267][v][vd] Pixel formats supported by decoder: cuda dxva2_vld d3d11va_vld d3d11 yuv420p [ 0.267][v][vd] Codec profile: High (0x64) [ 0.269][v][vd] Requesting pixfmt 'd3d11' from decoder. [ 0.269][d][ffmpeg/video] h264: Decoder GUIDs reported as supported: [ 0.269][d][ffmpeg/video] h264: {ee27417f-5e28-4e65-beea-1d26b508adc9} 103 106 [ 0.269][d][ffmpeg/video] h264: {bf22ad00-03ea-4690-8077-473346209b7e} 103 106 [ 0.269][d][ffmpeg/video] h264: {1b81be68-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.269][d][ffmpeg/video] h264: {4245f676-2bbc-4166-a0bb-54e7b849c380} 103 106 [ 0.269][d][ffmpeg/video] h264: {6719b6fb-5cad-4acb-b00a-f3bfdec38727} 103 106 [ 0.269][d][ffmpeg/video] h264: {9901ccd3-ca12-4b7e-867a-e2223d9255c3} 103 106 [ 0.269][d][ffmpeg/video] h264: {d79be8da-0cf1-4c81-b82a-69a4e236f43d} 103 106 [ 0.269][d][ffmpeg/video] h264: {f9aaccbb-c2b6-4cfc-8779-5707b1760552} 103 106 [ 0.269][d][ffmpeg/video] h264: {1b81bea3-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.269][d][ffmpeg/video] h264: {ca15d19a-2b48-43d6-979e-7a6e9c802ff8} 103 106 [ 0.269][d][ffmpeg/video] h264: {7c74adc6-e2ba-4ade-86de-30beabb40cc1} 103 106 [ 0.269][d][ffmpeg/video] h264: {ed418a9f-010d-4eda-9ae3-9a65358d8d2e} 103 106 [ 0.269][d][ffmpeg/video] h264: {1b81bea2-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.269][d][ffmpeg/video] h264: {1b81be94-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.269][d][ffmpeg/video] h264: {103473e4-10ea-11df-9a92-2ba055d89593} 103 106 [ 0.270][d][ffmpeg/video] h264: {84ad67f6-4c21-419a-9f0b-24f0578906c1} 103 106 [ 0.270][d][ffmpeg/video] h264: {725ad240-786c-471e-ad3c-38f739936517} 103 106 [ 0.270][d][ffmpeg/video] h264: {95664ff5-9e03-4c74-bb4f-9178d6035e58} 103 106 [ 0.270][d][ffmpeg/video] h264: {603a4756-a864-4f91-bb62-2c935b7a1391} 103 106 [ 0.311][d][ffmpeg/video] h264: Reinit context to 1920x800, pix_fmt: d3d11 [ 0.323][i][vd] Using hardware decoding (d3d11va). [ 0.323][v][vd] Decoder format: 1920x800 d3d11[nv12] auto/auto/auto/auto/auto CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000) [ 0.323][v][vd] Using container aspect ratio. [ 0.323][v][vf] [in] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [ 0.323][v][vf] [userdeint] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [ 0.323][v][vf] [userdeint] (disabled) [ 0.323][v][vf] [autorotate] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [ 0.323][v][vf] [autorotate] (disabled) [ 0.323][v][vf] [convert] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [ 0.323][v][vf] [convert] (disabled) [ 0.323][v][vf] [out] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [ 0.323][v][ao] Trying audio driver 'wasapi' [ 0.323][v][ao/wasapi] requested format: 48000 Hz, stereo channels, spdif-ac3 [ 0.323][d][ao/wasapi] Init wasapi [ 0.323][d][ao/wasapi] Find device '' [ 0.328][v][ao/wasapi] No device specified. Selecting default. [ 0.332][v][ao/wasapi] Selecting device '{44651d82-b793-4932-a0c7-c230b4f3b7b5}' (6 - SONY AVAMP (AMD High Definition Audio Device)) [ 0.332][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{44651d82-b793-4932-a0c7-c230b4f3b7b5} [ 0.335][d][ao/wasapi] Init wasapi thread [ 0.335][d][ao/wasapi] Activating pAudioClient interface [ 0.338][d][ao/wasapi] Probing formats [ 0.344][v][ao/wasapi] Trying stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) -> ok [ 0.344][v][ao/wasapi] Accepted as stereo spdif-ac3 @ 48000hz -> stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) [ 0.344][d][ao/wasapi] Fixing format [ 0.344][d][ao/wasapi] IAudioClient::GetDevicePeriod [ 0.344][v][ao/wasapi] Device period: 10 ms [ 0.344][d][ao/wasapi] IAudioClient::Initialize [ 0.355][d][ao/wasapi] IAudioClient::Initialize pRenderClient [ 0.355][d][ao/wasapi] IAudioClient::Initialize IAudioClient_SetEventHandle [ 0.355][d][ao/wasapi] IAudioClient::Initialize IAudioClient_GetBufferSize [ 0.355][v][ao/wasapi] Buffer frame count: 480 (10 ms) [ 0.355][v][ao/wasapi] IAudioClock::GetFrequency gave a frequency of 48000. [ 0.359][d][ao/wasapi] Activating pEndpointVolume interface [ 0.360][d][ao/wasapi] IAudioEndpointVolume::QueryHardwareSupport [ 0.360][d][ao/wasapi] Entering dispatch loop [ 0.360][d][ao/wasapi] Init wasapi done [ 0.360][v][ao/wasapi] device buffer: 480 samples. [ 0.360][v][ao/wasapi] using soft-buffer of 10752 samples. [ 0.360][i][cplayer] AO: [wasapi] 48000Hz stereo 2ch spdif-ac3 [ 0.360][v][cplayer] AO: Description: Windows WASAPI audio output (event mode) [ 0.360][i][cplayer] VO: [gpu] 1920x800 d3d11[nv12] [ 0.360][v][cplayer] VO: Description: Shader-based GPU Renderer [ 0.360][v][vo/gpu] reconfig to 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [ 0.360][d][vo/gpu] screen size: 1920x1080 [ 0.410][v][vo/gpu] Resize: 1920x1080 [ 0.410][v][vo/gpu] Window size: 1920x1080 [ 0.410][v][vo/gpu] Video source: 1920x800 (1:1) [ 0.410][v][vo/gpu] Video display: (0, 0) 1920x800 -> (0, 140) 1920x800 [ 0.410][v][vo/gpu] Video scale: 1.000000/1.000000 [ 0.410][v][vo/gpu] OSD borders: l=0 t=140 r=0 b=140 [ 0.410][v][vo/gpu] Video borders: l=0 t=140 r=0 b=140 [ 0.410][v][vo/gpu] Reported display depth: 8 [ 0.411][v][vo/gpu] Testing FBO format rgba16hf [ 0.411][d][vo/gpu] Resizing texture: 16x16 [ 0.411][v][vo/gpu] Using FBO format rgba16hf. [ 0.411][v][vo/gpu] No advanced processing required. Enabling dumb mode. [ 0.455][v][vo/gpu/d3d11] shaderc compile status 'success' (0 errors, 0 warnings) [ 0.456][v][vo/gpu/d3d11] Compiled a vertex shader in 45586us [ 0.456][v][vo/gpu/d3d11] shaderc: 43666us, SPIRV-Cross: 242us, D3DCompile: 1678us [ 0.457][d][vo/gpu/d3d11] GLSL source: [ 0.457][d][vo/gpu/d3d11] [ 1] #version 450 [ 0.457][d][vo/gpu/d3d11] [ 2] #define tex1D texture [ 0.457][d][vo/gpu/d3d11] [ 3] #define tex3D texture [ 0.457][d][vo/gpu/d3d11] [ 4] #define LUT_POS(x, lut_size) mix(0.5 / (lut_size), 1.0 - 0.5 / (lut_size), (x)) [ 0.457][d][vo/gpu/d3d11] [ 5] layout(location=0) in vec2 vertex_position; [ 0.457][d][vo/gpu/d3d11] [ 6] layout(location=1) in vec2 vertex_texcoord0; [ 0.457][d][vo/gpu/d3d11] [ 7] layout(location=1) out vec2 texcoord0; [ 0.457][d][vo/gpu/d3d11] [ 8] layout(location=2) in vec2 vertex_texcoord1; [ 0.457][d][vo/gpu/d3d11] [ 9] layout(location=2) out vec2 texcoord1; [ 0.457][d][vo/gpu/d3d11] [ 10] void main() { [ 0.457][d][vo/gpu/d3d11] [ 11] gl_Position = vec4(vertex_position, 1.0, 1.0); [ 0.457][d][vo/gpu/d3d11] [ 12] texcoord0 = vertex_texcoord0; [ 0.457][d][vo/gpu/d3d11] [ 13] texcoord1 = vertex_texcoord1; [ 0.457][d][vo/gpu/d3d11] [ 14] } [ 0.457][d][vo/gpu/d3d11] HLSL source: [ 0.457][d][vo/gpu/d3d11] [ 1] static float4 gl_Position; [ 0.457][d][vo/gpu/d3d11] [ 2] static float2 _18; [ 0.457][d][vo/gpu/d3d11] [ 3] static float2 _27; [ 0.457][d][vo/gpu/d3d11] [ 4] static float2 _28; [ 0.457][d][vo/gpu/d3d11] [ 5] static float2 _30; [ 0.457][d][vo/gpu/d3d11] [ 6] static float2 _31; [ 0.457][d][vo/gpu/d3d11] [ 7] [ 0.457][d][vo/gpu/d3d11] [ 8] struct SPIRV_Cross_Input [ 0.457][d][vo/gpu/d3d11] [ 9] { [ 0.457][d][vo/gpu/d3d11] [ 10] float2 _18 : TEXCOORD0; [ 0.457][d][vo/gpu/d3d11] [ 11] float2 _28 : TEXCOORD1; [ 0.457][d][vo/gpu/d3d11] [ 12] float2 _31 : TEXCOORD2; [ 0.457][d][vo/gpu/d3d11] [ 13] }; [ 0.457][d][vo/gpu/d3d11] [ 14] [ 0.457][d][vo/gpu/d3d11] [ 15] struct SPIRV_Cross_Output [ 0.457][d][vo/gpu/d3d11] [ 16] { [ 0.457][d][vo/gpu/d3d11] [ 17] float2 _27 : TEXCOORD1; [ 0.457][d][vo/gpu/d3d11] [ 18] float2 _30 : TEXCOORD2; [ 0.457][d][vo/gpu/d3d11] [ 19] float4 gl_Position : SV_Position; [ 0.457][d][vo/gpu/d3d11] [ 20] }; [ 0.457][d][vo/gpu/d3d11] [ 21] [ 0.457][d][vo/gpu/d3d11] [ 22] void vert_main() [ 0.457][d][vo/gpu/d3d11] [ 23] { [ 0.457][d][vo/gpu/d3d11] [ 24] gl_Position = float4(_18, 1.0f, 1.0f); [ 0.457][d][vo/gpu/d3d11] [ 25] _27 = _28; [ 0.457][d][vo/gpu/d3d11] [ 26] _30 = _31; [ 0.457][d][vo/gpu/d3d11] [ 27] gl_Position.y = -gl_Position.y; [ 0.457][d][vo/gpu/d3d11] [ 28] } [ 0.457][d][vo/gpu/d3d11] [ 29] [ 0.457][d][vo/gpu/d3d11] [ 30] SPIRV_Cross_Output main(SPIRV_Cross_Input stage_input) [ 0.457][d][vo/gpu/d3d11] [ 31] { [ 0.457][d][vo/gpu/d3d11] [ 32] _18 = stage_input._18; [ 0.457][d][vo/gpu/d3d11] [ 33] _28 = stage_input._28; [ 0.457][d][vo/gpu/d3d11] [ 34] _31 = stage_input._31; [ 0.457][d][vo/gpu/d3d11] [ 35] vert_main(); [ 0.457][d][vo/gpu/d3d11] [ 36] SPIRV_Cross_Output stage_output; [ 0.457][d][vo/gpu/d3d11] [ 37] stage_output.gl_Position = gl_Position; [ 0.457][d][vo/gpu/d3d11] [ 38] stage_output._27 = _27; [ 0.457][d][vo/gpu/d3d11] [ 39] stage_output._30 = _30; [ 0.457][d][vo/gpu/d3d11] [ 40] return stage_output; [ 0.457][d][vo/gpu/d3d11] [ 41] } [ 0.459][v][vo/gpu/d3d11] shaderc compile status 'success' (0 errors, 0 warnings) [ 0.463][v][vo/gpu/d3d11] Compiled a fragment shader in 6215us [ 0.463][v][vo/gpu/d3d11] shaderc: 2230us, SPIRV-Cross: 278us, D3DCompile: 3707us [ 0.464][d][vo/gpu/d3d11] GLSL source: [ 0.464][d][vo/gpu/d3d11] [ 1] #version 450 [ 0.464][d][vo/gpu/d3d11] [ 2] #define tex1D texture [ 0.464][d][vo/gpu/d3d11] [ 3] #define tex3D texture [ 0.464][d][vo/gpu/d3d11] [ 4] #define LUT_POS(x, lut_size) mix(0.5 / (lut_size), 1.0 - 0.5 / (lut_size), (x)) [ 0.464][d][vo/gpu/d3d11] [ 5] layout(location=0) out vec4 out_color; [ 0.464][d][vo/gpu/d3d11] [ 6] layout(location=1) in vec2 texcoord0; [ 0.464][d][vo/gpu/d3d11] [ 7] layout(location=2) in vec2 texcoord1; [ 0.464][d][vo/gpu/d3d11] [ 8] layout(std140, binding=0) uniform UBO { [ 0.464][d][vo/gpu/d3d11] [ 9] layout(offset=0) mat3 colormatrix; [ 0.464][d][vo/gpu/d3d11] [ 10] layout(offset=48) vec3 colormatrix_c; [ 0.464][d][vo/gpu/d3d11] [ 11] layout(offset=64) vec3 src_luma; [ 0.464][d][vo/gpu/d3d11] [ 12] layout(offset=80) vec3 dst_luma; [ 0.464][d][vo/gpu/d3d11] [ 13] layout(offset=96) vec2 texture_size0; [ 0.464][d][vo/gpu/d3d11] [ 14] layout(offset=112) mat2 texture_rot0; [ 0.464][d][vo/gpu/d3d11] [ 15] layout(offset=144) vec2 texture_off0; [ 0.464][d][vo/gpu/d3d11] [ 16] layout(offset=152) vec2 pixel_size0; [ 0.464][d][vo/gpu/d3d11] [ 17] layout(offset=160) vec2 texture_size1; [ 0.464][d][vo/gpu/d3d11] [ 18] layout(offset=176) mat2 texture_rot1; [ 0.464][d][vo/gpu/d3d11] [ 19] layout(offset=208) vec2 texture_off1; [ 0.464][d][vo/gpu/d3d11] [ 20] layout(offset=216) vec2 pixel_size1; [ 0.464][d][vo/gpu/d3d11] [ 21] }; [ 0.464][d][vo/gpu/d3d11] [ 22] layout(binding=0) uniform sampler2D texture0; [ 0.464][d][vo/gpu/d3d11] [ 23] layout(binding=1) uniform sampler2D texture1; [ 0.464][d][vo/gpu/d3d11] [ 24] void main() { [ 0.464][d][vo/gpu/d3d11] [ 25] vec4 color = vec4(0.0, 0.0, 0.0, 1.0); [ 0.464][d][vo/gpu/d3d11] [ 26] color.r = 1.000000 * vec4(texture(texture0, texcoord0)).r; [ 0.464][d][vo/gpu/d3d11] [ 27] color.gb = 1.000000 * vec4(texture(texture1, texcoord1)).rg; [ 0.464][d][vo/gpu/d3d11] [ 28] color = color.rgbr; [ 0.464][d][vo/gpu/d3d11] [ 29] color.rgb = mat3(colormatrix) * color.rgb + colormatrix_c; [ 0.464][d][vo/gpu/d3d11] [ 30] color.a = 1.0; [ 0.464][d][vo/gpu/d3d11] [ 31] // color mapping [ 0.464][d][vo/gpu/d3d11] [ 32] color.rgb *= vec3(1.000000); [ 0.464][d][vo/gpu/d3d11] [ 33] color.rgb *= vec3(1.000000); [ 0.464][d][vo/gpu/d3d11] [ 34] out_color = color; [ 0.464][d][vo/gpu/d3d11] [ 35] } [ 0.464][d][vo/gpu/d3d11] HLSL source: [ 0.464][d][vo/gpu/d3d11] [ 1] cbuffer _53_55 : register(b0) [ 0.464][d][vo/gpu/d3d11] [ 2] { [ 0.464][d][vo/gpu/d3d11] [ 3] row_major float3x3 _55_m0 : packoffset(c0); [ 0.464][d][vo/gpu/d3d11] [ 4] float3 _55_m1 : packoffset(c3); [ 0.464][d][vo/gpu/d3d11] [ 5] float3 _55_m2 : packoffset(c4); [ 0.464][d][vo/gpu/d3d11] [ 6] float3 _55_m3 : packoffset(c5); [ 0.464][d][vo/gpu/d3d11] [ 7] float2 _55_m4 : packoffset(c6); [ 0.464][d][vo/gpu/d3d11] [ 8] row_major float2x2 _55_m5 : packoffset(c7); [ 0.464][d][vo/gpu/d3d11] [ 9] float2 _55_m6 : packoffset(c9); [ 0.464][d][vo/gpu/d3d11] [ 10] float2 _55_m7 : packoffset(c9.z); [ 0.464][d][vo/gpu/d3d11] [ 11] float2 _55_m8 : packoffset(c10); [ 0.464][d][vo/gpu/d3d11] [ 12] row_major float2x2 _55_m9 : packoffset(c11); [ 0.464][d][vo/gpu/d3d11] [ 13] float2 _55_m10 : packoffset(c13); [ 0.464][d][vo/gpu/d3d11] [ 14] float2 _55_m11 : packoffset(c13.z); [ 0.464][d][vo/gpu/d3d11] [ 15] }; [ 0.464][d][vo/gpu/d3d11] [ 16] [ 0.464][d][vo/gpu/d3d11] [ 17] Texture2D<float4> _16 : register(t0); [ 0.464][d][vo/gpu/d3d11] [ 18] SamplerState __16_sampler : register(s0); [ 0.464][d][vo/gpu/d3d11] [ 19] Texture2D<float4> _34 : register(t1); [ 0.464][d][vo/gpu/d3d11] [ 20] SamplerState __34_sampler : register(s1); [ 0.464][d][vo/gpu/d3d11] [ 21] [ 0.464][d][vo/gpu/d3d11] [ 22] static float2 _20; [ 0.464][d][vo/gpu/d3d11] [ 23] static float2 _36; [ 0.464][d][vo/gpu/d3d11] [ 24] static float4 _89; [ 0.464][d][vo/gpu/d3d11] [ 25] [ 0.464][d][vo/gpu/d3d11] [ 26] struct SPIRV_Cross_Input [ 0.464][d][vo/gpu/d3d11] [ 27] { [ 0.464][d][vo/gpu/d3d11] [ 28] float2 _20 : TEXCOORD1; [ 0.464][d][vo/gpu/d3d11] [ 29] float2 _36 : TEXCOORD2; [ 0.464][d][vo/gpu/d3d11] [ 30] }; [ 0.464][d][vo/gpu/d3d11] [ 31] [ 0.464][d][vo/gpu/d3d11] [ 32] struct SPIRV_Cross_Output [ 0.464][d][vo/gpu/d3d11] [ 33] { [ 0.464][d][vo/gpu/d3d11] [ 34] float4 _89 : SV_Target0; [ 0.464][d][vo/gpu/d3d11] [ 35] }; [ 0.464][d][vo/gpu/d3d11] [ 36] [ 0.464][d][vo/gpu/d3d11] [ 37] void frag_main() [ 0.464][d][vo/gpu/d3d11] [ 38] { [ 0.464][d][vo/gpu/d3d11] [ 39] float4 _92 = float4(0.0f, 0.0f, 0.0f, 1.0f); [ 0.464][d][vo/gpu/d3d11] [ 40] _92.x = _16.Sample(__16_sampler, _20).x; [ 0.464][d][vo/gpu/d3d11] [ 41] float2 _45 = _34.Sample(__34_sampler, _36).xy * 1.0f; [ 0.464][d][vo/gpu/d3d11] [ 42] float4 _47 = float4(_92.x, _45.x, _45.y, _92.w); [ 0.464][d][vo/gpu/d3d11] [ 43] float3 _72 = mul(_47.xyz, _55_m0) + _55_m1; [ 0.464][d][vo/gpu/d3d11] [ 44] float4 _94 = float4(_72.x, _72.y, _72.z, _92.x); [ 0.464][d][vo/gpu/d3d11] [ 45] _94.w = 1.0f; [ 0.464][d][vo/gpu/d3d11] [ 46] _89 = float4(_94.x, _94.y, _94.z, _94.w); [ 0.464][d][vo/gpu/d3d11] [ 47] } [ 0.464][d][vo/gpu/d3d11] [ 48] [ 0.464][d][vo/gpu/d3d11] [ 49] SPIRV_Cross_Output main(SPIRV_Cross_Input stage_input) [ 0.464][d][vo/gpu/d3d11] [ 50] { [ 0.464][d][vo/gpu/d3d11] [ 51] _20 = stage_input._20; [ 0.464][d][vo/gpu/d3d11] [ 52] _36 = stage_input._36; [ 0.464][d][vo/gpu/d3d11] [ 53] frag_main(); [ 0.464][d][vo/gpu/d3d11] [ 54] SPIRV_Cross_Output stage_output; [ 0.464][d][vo/gpu/d3d11] [ 55] stage_output._89 = _89; [ 0.464][d][vo/gpu/d3d11] [ 56] return stage_output; [ 0.464][d][vo/gpu/d3d11] [ 57] } [ 0.472][v][cplayer] first video frame after restart shown [ 0.472][v][af] [convert] (disabled) [ 0.472][v][af] [out] 48000Hz stereo 2ch spdif-ac3 [ 0.474][v][cplayer] starting audio playback [ 0.474][d][ao/wasapi] Thread Resume [ 0.474][d][ao/wasapi] Thread Reset [ 0.474][v][cplayer] playback restart complete [ 0.474][i][cplayer] Track switched: [ 0.474][i][cplayer] (+) Video --vid=1 (*) (h264 1920x800 23.976fps) [ 0.474][i][cplayer] (+) Audio --aid=1 (*) (aac 6ch 48000Hz) [ 0.474][v][cplayer] Set property: aid=1 -> 1 [ 0.475][i][cplayer] Track switched: [ 0.475][i][cplayer] (+) Video --vid=1 (*) (h264 1920x800 23.976fps) [ 0.475][i][cplayer] (+) Audio --aid=1 (*) (aac 6ch 48000Hz) [ 0.475][v][cplayer] Set property: sid="no" -> 1 [ 0.476][d][cplayer] Run command: seek, flags=0, args=[3631.000000, absolute, exact] [ 0.476][v][lavf] queuing seek to 3631.000000 [ 0.476][v][lavf] cached range 0: 0.000000 <-> 402.735667 (bof=1, eof=0) [ 0.476][d][ao/wasapi] Thread Reset [ 0.477][v][cplayer] hr-seek, skipping to 3631.000000 [ 1.181][v][lavf] execute seek (to 3631.000000 flags 32) [ 1.182][v][lavf] seek done [ 1.182][d][cache] request seek: 96782258 <= to=1120800736 (cur=117098418) <= 117196722 [ 1.182][v][cache] Dropping cache at pos 1120800736, cached range: 96782258-117262258. [ 1.182][v][cache] Seeking underlying stream: 117262258 -> 1120800736 [ 1.200][v][vd] Pixel formats supported by decoder: cuda dxva2_vld d3d11va_vld d3d11 yuv420p [ 1.200][v][vd] Codec profile: High (0x64) [ 1.200][v][vd] Requesting pixfmt 'd3d11' from decoder. [ 1.200][d][ffmpeg/video] h264: Decoder GUIDs reported as supported: [ 1.200][d][ffmpeg/video] h264: {ee27417f-5e28-4e65-beea-1d26b508adc9} 103 106 [ 1.200][d][ffmpeg/video] h264: {bf22ad00-03ea-4690-8077-473346209b7e} 103 106 [ 1.200][d][ffmpeg/video] h264: {1b81be68-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 1.200][d][ffmpeg/video] h264: {4245f676-2bbc-4166-a0bb-54e7b849c380} 103 106 [ 1.200][d][ffmpeg/video] h264: {6719b6fb-5cad-4acb-b00a-f3bfdec38727} 103 106 [ 1.201][d][ffmpeg/video] h264: {9901ccd3-ca12-4b7e-867a-e2223d9255c3} 103 106 [ 1.201][d][ffmpeg/video] h264: {d79be8da-0cf1-4c81-b82a-69a4e236f43d} 103 106 [ 1.201][d][ffmpeg/video] h264: {f9aaccbb-c2b6-4cfc-8779-5707b1760552} 103 106 [ 1.201][d][ffmpeg/video] h264: {1b81bea3-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 1.201][d][ffmpeg/video] h264: {ca15d19a-2b48-43d6-979e-7a6e9c802ff8} 103 106 [ 1.201][d][ffmpeg/video] h264: {7c74adc6-e2ba-4ade-86de-30beabb40cc1} 103 106 [ 1.201][d][ffmpeg/video] h264: {ed418a9f-010d-4eda-9ae3-9a65358d8d2e} 103 106 [ 1.201][d][ffmpeg/video] h264: {1b81bea2-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 1.201][d][ffmpeg/video] h264: {1b81be94-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 1.201][d][ffmpeg/video] h264: {103473e4-10ea-11df-9a92-2ba055d89593} 103 106 [ 1.201][d][ffmpeg/video] h264: {84ad67f6-4c21-419a-9f0b-24f0578906c1} 103 106 [ 1.201][d][ffmpeg/video] h264: {725ad240-786c-471e-ad3c-38f739936517} 103 106 [ 1.201][d][ffmpeg/video] h264: {95664ff5-9e03-4c74-bb4f-9178d6035e58} 103 106 [ 1.201][d][ffmpeg/video] h264: {603a4756-a864-4f91-bb62-2c935b7a1391} 103 106 [ 1.202][d][ffmpeg/video] h264: Reinit context to 1920x800, pix_fmt: d3d11 [ 1.208][v][vd] Decoder format: 1920x800 d3d11[nv12] auto/auto/auto/auto/auto CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000) [ 1.208][v][vd] Using container aspect ratio. [ 1.431][v][cplayer] first video frame after restart shown [ 1.440][v][cplayer] starting audio playback [ 1.440][d][ao/wasapi] Thread Resume [ 1.441][d][ao/wasapi] Thread Reset [ 1.441][v][cplayer] playback restart complete [ 36.094][v][vo/gpu/win32] resize window: 160:28 [ 36.126][v][vo/gpu] Resize: 160x28 [ 36.126][v][vo/gpu] Window size: 160x28 [ 36.126][v][vo/gpu] Video source: 1920x800 (1:1) [ 36.126][v][vo/gpu] Video display: (0, 0) 1920x800 -> (46, 0) 67x28 [ 36.126][v][vo/gpu] Video scale: 0.034896/0.035000 [ 36.126][v][vo/gpu] OSD borders: l=46 t=0 r=47 b=0 [ 36.126][v][vo/gpu] Video borders: l=46 t=0 r=47 b=0 [ 36.126][v][vo/gpu] Reported display depth: 8 [ 127.134][v][vo/gpu/win32] resize window: 1920:1080 [ 127.172][v][vo/gpu] Resize: 1920x1080 [ 127.172][v][vo/gpu] Window size: 1920x1080 [ 127.172][v][vo/gpu] Video source: 1920x800 (1:1) [ 127.172][v][vo/gpu] Video display: (0, 0) 1920x800 -> (0, 140) 1920x800 [ 127.172][v][vo/gpu] Video scale: 1.000000/1.000000 [ 127.172][v][vo/gpu] OSD borders: l=0 t=140 r=0 b=140 [ 127.172][v][vo/gpu] Video borders: l=0 t=140 r=0 b=140 [ 127.172][v][vo/gpu] Reported display depth: 8 [ 127.784][d][cplayer] Run command: cycle, flags=0, args=[pause, (NULL)] [ 127.784][d][ao/wasapi] Thread Reset [ 127.784][v][cplayer] Set property: pause -> 1 [ 128.993][v][vo/gpu/win32] resize window: 160:28 [ 129.026][v][vo/gpu] Resize: 160x28 [ 129.026][v][vo/gpu] Window size: 160x28 [ 129.026][v][vo/gpu] Video source: 1920x800 (1:1) [ 129.026][v][vo/gpu] Video display: (0, 0) 1920x800 -> (46, 0) 67x28 [ 129.026][v][vo/gpu] Video scale: 0.034896/0.035000 [ 129.026][v][vo/gpu] OSD borders: l=46 t=0 r=47 b=0 [ 129.026][v][vo/gpu] Video borders: l=46 t=0 r=47 b=0 [ 129.026][v][vo/gpu] Reported display depth: 8 Edited February 13, 2020 by pmac
Guest asrequested Posted February 13, 2020 Posted February 13, 2020 The AC3 encoder just resamples the audio. It doesn't alter the channels, unless you have 7.1 AAC. AC3 only supports 5.1. There isn't a way to differentiate the channel count. I would suggest you use that and not the upmix option.
Guest asrequested Posted February 14, 2020 Posted February 14, 2020 (edited) Disregard Edited February 14, 2020 by Doofus
Guest asrequested Posted February 14, 2020 Posted February 14, 2020 (edited) I'm actually going to switch up my profile for this. I'm preferring the sound quality of the surround upmix, compared to the AC3 encoder. af=surround:chl_out=7.1 If you only have 5.1, you can just use: af=surround Edited February 14, 2020 by Doofus
pmac 143 Posted February 16, 2020 Author Posted February 16, 2020 I'm actually going to switch up my profile for this. I'm preferring the sound quality of the surround upmix, compared to the AC3 encoder. af=surround:chl_out=7.1 If you only have 5.1, you can just use: af=surround That's a very tough call. I'm having a hard time deciding between af=lavcac3enc=yes:640:2 and af=surround now... I've noticed that using the latter, some of my dolby digital files show up on my receiver as "LPCM 192" and some of my AAC files show up as "Dolby Digital" for some reason... Also, anything that comes up as LPCM doesn't allow me to choose which "sound field" I want to use, which is fine since those just alter the way they were originally mixed, but I thought that was an interesting side effect. LPCM seems to be quieter than AC3, I can't tell yet which has the better sound though...
Guest asrequested Posted February 16, 2020 Posted February 16, 2020 That sounds like your receiver is doing something with the audio. But you can boost the output. There are options for that. I like the surround option, because I get more LFE.
pmac 143 Posted February 16, 2020 Author Posted February 16, 2020 Actually, af That sounds like your receiver is doing something with the audio. But you can boost the output. There are options for that. I like the surround option, because I get more LFE. I just finished calibrating my system to DVE specs yesterday (75dB on all channels). I've noticed that certain titles I get a lot more LFE data on my little 150W Sony sub compared to my two custom 400W subs being powered by a separate Peavey IPR1600. I guess the Peavey crossover is set lower or something... For some reason it seems I've had the opposite experience that you're having (in my very brief testing just now). Anything that comes though as LPCM sounds kind of thin compared to the ones using Dolby Digital; does that sound right? I've got my receiver dialed in pretty good right now, I spent a lot of time on it the past couple of days. It's kind of tough I guess because I have so many different media types using different encoders, and it takes a little while to close Emby, switch between mpv profiles, and start playing the movie again; making it tough to compare. I wish I could just hit a button to switch profiles until I found one I liked best lol.
pmac 143 Posted February 16, 2020 Author Posted February 16, 2020 (edited) What's a good movie that you use for testing surround effect and LFE? I've been using the intro for Infinity War for subtle LFE during the Marvel logo, and clear dialogue when the alien guy is talking, the space ship scene at the start of Venom and the part in Godzilla where Rodan is chasing the fighter jets, but I'm sure there are better options out there. Those are just three titles I have that have a true 5.1 audio track. For testing a stereo to 5.1 upmix or re-encode I've been using a stereo AAC copy of "300" starting at around the 4 minute mark. When playing the opening scene of Infinity War, AC3 seems to be an average of 6dB louder than LPCM for some reason, that could account for the "thin" sound I noticed. Edited February 16, 2020 by pmac
Guest asrequested Posted February 16, 2020 Posted February 16, 2020 If you're using 5.1 the LFE is already specified. That will remain unchanged, unless you deliberately set a lower frequency when using surround upmixing. The AC3 encoder will just use the channel that's already there. But when using surround for stereo upmixing, it pulls out as much of the LFE as is present in the file. I find it's much more than using the AC3 encoder.
pmac 143 Posted February 16, 2020 Author Posted February 16, 2020 I just did some more testing on a few different titles, this time I filtered by audio codec in Emby. It seems like passthrough is working just fine on my system, which is good to know. The only codec I've found so far that mpv is affecting is AAC, which makes it much easier for me to test, but I'm surprised thats the only codec that's being affected. Using "af=lavcac3enc=yes:640:2" my AAC files all get converted to Dolby Digital, even if they are AAC 5.1 or 7.1, is this normal? Using "af=surround" they all get converted to LPCM, is this correct? It's late here and my wife has gone to sleep, so I can't have the volume too loud, but from what I'm hearing, Dolby Digital seems much louder than LPCM, which makes it seem like there's more LFE, but it's hard to tell for sure without increasing the level to match the volume on AC3 somehow.
Guest asrequested Posted February 16, 2020 Posted February 16, 2020 I just did some more testing on a few different titles, this time I filtered by audio codec in Emby. It seems like passthrough is working just fine on my system, which is good to know. The only codec I've found so far that mpv is affecting is AAC, which makes it much easier for me to test, but I'm surprised thats the only codec that's being affected. Using "af=lavcac3enc=yes:640:2" my AAC files all get converted to Dolby Digital, even if they are AAC 5.1 or 7.1, is this normal? Using "af=surround" they all get converted to LPCM, is this correct? It's late here and my wife has gone to sleep, so I can't have the volume too loud, but from what I'm hearing, Dolby Digital seems much louder than LPCM, which makes it seem like there's more LFE, but it's hard to tell for sure without increasing the level to match the volume on AC3 somehow. The AC3 encoder will convert all audio that isn't being bitstreamed. PCM is the decoded output. It's the decompressed audio, same thing your receiver does when you bitstream the audio to the receiver. But instead of your receiver decoding the audio, the software is doing it. The volume output is a little higher because mpv first decodes the AAC audio, in doing so, the volume is boosted a little, then the AC3 encoder is used to re-encode the audio. The surround filter doesn't alter the volume by default. It comes down to taste. Which you like better
pmac 143 Posted February 16, 2020 Author Posted February 16, 2020 (edited) Thanks @, that helps me understand a lot better One more question (kind of off topic, I know) I have for you if you don't mind: I'm tinkering with the lower frequencies on my system, and as I said before, I have three subs I use (one small powered sub for regular viewing, and two large cabinets with external amp for when I want to shake the house, lol). I noticed that my small sub seemed top pick up a lot more on the LFE so I got the manual out and found that it's effective range is 35Hz-160Hz. My Peavey amp (powering my large subs) has 3 settings per channel: High Range, Full Range, and Subwoofer. Since I've owned it I've had it set to "Subwoofer", which is a built in crossover set to 100Hz; obviously this is why I'm not hearing as much from it as my other sub, since I'm missing from 101-160Hz with that setting. My question is, should I set my sub amp to full-range? I can't seem to find an adjustment in my receiver settings for a subwoofer crossover setting like I can with the front, center and surround channels. Or will my sub only get what's on the LFE channel by default (which I think for Dolby standards is anything below 120Hz)? I just feel that by having my amp set to 100Hz crossover, I'm missing out on a lot of LFE, but I also don't want to end up with a lot of muddiness if it's getting sent higher frequencies than it should be by having the crossover disabled. Edited February 16, 2020 by pmac
Guest asrequested Posted February 16, 2020 Posted February 16, 2020 Thanks @, that helps me understand a lot better One more question (kind of off topic, I know) I have for you if you don't mind: I'm tinkering with the lower frequencies on my system, and as I said before, I have three subs I use (one small powered sub for regular viewing, and two large cabinets with external amp for when I want to shake the house, lol). I noticed that my small sub seemed top pick up a lot more on the LFE so I got the manual out and found that it's effective range is 35Hz-160Hz. My Peavey amp (powering my large subs) has 3 settings per channel: High Range, Full Range, and Subwoofer. Since I've owned it I've had it set to "Subwoofer", which is a built in crossover set to 100Hz; obviously this is why I'm not hearing as much from it as my other sub, since I'm missing from 101-160Hz with that setting. The opposite is true. The lower the frequency, the more rumble you get I would have thought that setting subwoofer would be the best option, but they just may not go as low as the other sub. I know a guy that had a 12Hz sub. That thing shakes the walls, when you play audio that has that range.
pmac 143 Posted February 16, 2020 Author Posted February 16, 2020 The opposite is true. The lower the frequency, the more rumble you get I would have thought that setting subwoofer would be the best option, but they just may not go as low as the other sub. I know a guy that had a 12Hz sub. That thing shakes the walls, when you play audio that has that range. Sorry, I may not have been all that clear. I know the lower the frequency, the more rumble. I just mean that my small sub has more sound coming from it, not lower frequencies. This I believe is because even though 100-160Hz isn't a very low rumble, it's still a fairly low frequency and still a sound that my larger subs are totally ignoring while filtered to 100Hz and lower. Also, my large subs go down to 18Hz (small one only goes down to 35Hz) and they definitely knock pictures off the walls lol. A friend of mine said he thought a plane was crashing into the house when I showed him a low frequency sweep with the volume cranked up haha I'm just not sure if turning the sub amp's crossover off will muddy the sound too much, or if my receiver automatically filters everything that's connected to the sub channel. I guess I'll have to do some testing tomorrow when I can turn up the volume louder. I know some receivers have a separate setting for LFE filter, but mine only has configurable crossovers for the main channels.
pmac 143 Posted February 16, 2020 Author Posted February 16, 2020 @ here's an old video I took when I first installed my subs. It's hard to hear with the crappy cell phone recording, but you can definitely see the effect of the subs on my house lolhttps://www.youtube.com/watch?v=fBSGBVf5v-8
