How to automatically upmix stereo (and anything less than 5.1) to 5.1?
I've tried fiddling with the settings and currently have speaker layout set to 5.1 and passthrough enabled for all options, and my receiver only utilizes the rear speakers for videos that have a 5.1 track; everything else only uses the front channels.
In the past I had my receiver's (Sony STR610) HDMI mode to "TV/AMP" which forced Windows to output everything as stereo and then my receiver would upmix to however many channels I had set up, but it wasn't "true" 5.1, so I've since switched the HDMI mode to "AMP" which allows Windows to see that it's connected to a 5.1 device, and the titles in my collection that have a 5.1 channel track sound much better; unfortunately a lot of my collection only has a stereo track, so I'm only getting sound up front for those titles.
I'd like to know if there's a way to upmix everything that isn't already 5.1 to utilize all of my speakers through Emby, or some other software.
Any tips would be appreciated, thanks.
Guest asrequested
Give me an example of an audio track that you want to do with this.
One that I tried earlier was AAC Stereo in an mkv container, if that's what you mean.
I think the issue I'm having (compared to how I was utilizing all of the speakers with my previous setup) is because windows is outputting 5.1 to my receiver, but the rear channels don't contain any audio (since it's just a stereo track); with this happening, my receiver can't upmix the audio since it thinks it's already 5.1, and I can't use any of the built in decoders (PLIIX, Neo6, etc) with my receiver in this mode. I'd rather not have to switch HDMI modes on a case by case basis while watching movies in ET.
In my old setup I was outputting a stereo source, and my receiver was (to the best of its ability) faking 5.1 audio with its internal decoder (which I was able to select while the HDMI mode was set to "TV/AMP".
So I'm guessing I'd need some sort of Windows based decoder software to convert my stereo audio tracks to "fake" 5.1 on the fly, if that's at all possible. I obviously don't know a whole lot on the subject though...
Guest asrequested
Ok, I can make this happen, but I need specifics on what you want the exact output to be. Do you know how to use an mpv.conf?
  • Like 1
I just set it up earlier today after following one of your posts while trying to figure this out on my own. I'm not really sure what to look for in the log though, since there's an awful lot of information in there.
And as far as output, I'm not really sure to be honest. Ideally I guess I'd like something similar to the way my receiver would up mix stereo content to simulate 5.1 surround sound, but at this point I'd probably settle for just duplicating the front channels on the back speakers if I had to... I'd rather have a simulated surround effect though, if at all possible.
Guest asrequested
Well, things like Pro Logic are total crap. Are you wanting to only upmix audio that isn't being bitstreamed? 5.1 PCM output? 5.1 AC3 output? Only certain audio codecs? I need to write a config line that'll give you what you want. This will also be applied to all of your media. Music, music videos...... so I need you to be specific on your desired outcome.
Guest asrequested
Can you post what you've already tried in your mpv.conf?
Guest asrequested
So you don't want an actual upmix, just a re-encode to AC3?
Honestly, I don't really know anything about the different codecs, etc. I'd just like to have stereo audio tracks sound like they're 5.1 surround sound. I'm not sure about different codecs, and decoders, sorry. I'd like anything that already has 5.1 channels stay the way it is, and everything else to be upmixed/re-encoded or whatever makes more sense; I don't really know the difference to be honest...
As far as mpv.conf; I've just created the file itself and told it where to log to as explained in your tutorial. I haven't added anything else to it (nor would I know how to).
Edited by pmac
Also, I don't have any music/music videos; just TV and Movies, so if everything ends up as 5.1, that's fine. And from what I understand AC3 with a high enough bitrate is very similar to PCM, but at a lower file size, so I'd assume that would be fine, I'm not an audiophile by any means.
Edited by pmac
Guest asrequested
Ok, try adding this line to your mpv.conf, and see how you like it.
af=lavcac3enc=yes:640:2
I'm not getting any sound now.
Still no. Do I need to reset/refresh anything first?
[ 0.007][v][cplayer] mpv 0.29.1 Copyright © 2000-2018 mpv/MPlayer/mplayer2 projects
[ 0.007][v][cplayer] built on Tue Jan 8 02:05:57 NZDT 2019
[ 0.007][v][cplayer] ffmpeg library versions:
[ 0.007][v][cplayer] libavutil 56.22.100
[ 0.007][v][cplayer] libavcodec 58.35.100
[ 0.007][v][cplayer] libavformat 58.20.100
[ 0.007][v][cplayer] libswscale 5.3.100
[ 0.007][v][cplayer] libavfilter 7.40.101
[ 0.007][v][cplayer] libswresample 3.3.100
[ 0.007][v][cplayer] ffmpeg version: n4.1
[ 0.007][v][cplayer] Configuration: /home/luke/github/mpv-winbuild-cmake/build64/packages/mpv-prefix/src/mpv/waf configure --enable-static-build --enable-pdf-build --disable-manpage-build --enable-libmpv-shared --enable-lua --enable-javascript --enable-libarchive --enable-libass --enable-libbluray --enable-dvdread --enable-dvdnav --enable-uchardet --enable-rubberband --enable-lcms2 --enable-openal --enable-vapoursynth --prefix=/home/luke/github/mpv-winbuild-cmake/build64/install/mingw
[ 0.007][v][cplayer] List of enabled features: asm atomics build-date cplayer crossc cuda-hwaccel d3d-hwaccel d3d11 d3d9-hwaccel debug-build direct3d dos-paths drmprime dvdnav dvdread dvdread-common egl-angle egl-angle-win32 egl-helpers ffmpeg ffnvcodec gl gl-dxinterop gl-dxinterop-d3d9 gl-win32 glob glob-win32 gnuc gpl iconv javascript jpeg lcms2 libaf libarchive libass libass-osd libav-any libavcodec libavdevice libbluray libm libmpv-shared lua luajit mingw noexecstack openal optimize plain-gl posix-or-mingw rubberband shaderc shaderc-static static-build stdatomic uchardet vapoursynth vapoursynth-core vapoursynth-lazy vulkan wasapi win32-desktop win32-internal-pthreads win32-pipes zlib
[ 0.007][d][ytdl_hook] Loading lua script @ytdl_hook.lua...
[ 0.007][d][stats] Loading lua script @[member="Stats"].lua...
[ 0.007][v][ipc] Starting IPC master
[ 0.008][d][stats] loading mp.defaults
[ 0.008][d][ytdl_hook] loading mp.defaults
[ 0.008][v][ipc] Listening to IPC pipe.
[ 0.008][v][ipc_0] Client connected
[ 0.008][d][stats] loading @[member="Stats"].lua
[ 0.008][d][ytdl_hook] loading @ytdl_hook.lua
[ 0.009][d][refreshrate] Loading lua script C:/Users/Patrick/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/refreshrate.lua...
[ 0.009][v][cplayer] Waiting for scripts...
[ 0.009][d][stats] reading options for stats
[ 0.009][d][ytdl_hook] reading options for ytdl_hook
[ 0.009][v][stats] script-opts/stats.conf not found.
[ 0.009][d][refreshrate] loading mp.defaults
[ 0.009][v][ytdl_hook] script-opts/ytdl_hook.conf not found.
[ 0.009][v][stats] lua-settings/stats.conf not found.
[ 0.010][d][refreshrate] loading file C:/Users/Patrick/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/refreshrate.lua
[ 0.010][v][ytdl_hook] lua-settings/ytdl_hook.conf not found.
[ 0.011][d][cplayer] Run command: define-section, flags=0, args=[input_stats, i script-binding stats/display-stats
[ 0.011][d][cplayer] , default]
[ 0.011][d][cplayer] Run command: enable-section, flags=0, args=[input_stats, allow-hide-cursor+allow-vo-dragging]
[ 0.011][d][cplayer] Run command: define-section, flags=0, args=[input_forced_stats, , force]
[ 0.011][d][cplayer] Run command: enable-section, flags=0, args=[input_forced_stats, allow-hide-cursor+allow-vo-dragging]
[ 0.011][d][cplayer] Run command: define-section, flags=0, args=[input_stats, I script-binding stats/display-stats-toggle
[ 0.011][d][cplayer] i script-binding stats/display-stats
[ 0.011][d][cplayer] I script-binding stats/display-stats-toggle
[ 0.011][v][cplayer] Done loading scripts.
[ 0.012][v][cplayer] Set property: volume=100 -> 1
[ 0.012][d][cplayer] Run command: loadfile, flags=0, args=[\\HELLSPAWN\Media Browser\HD Movies\300 Rise of an Empire\300.Rise.of.an.Empire.2014.1080p.BluRay.x264.YIFY.mp4, replace, ]
[ 0.013][i][cplayer] Playing: \\HELLSPAWN\Media Browser\HD Movies\300 Rise of an Empire\300.Rise.of.an.Empire.2014.1080p.BluRay.x264.YIFY.mp4
[ 0.013][v][cplayer] Running hook: ytdl_hook/on_load
[ 0.013][v][ytdl_hook] ytdl:// hook
[ 0.013][v][ytdl_hook] not a ytdl:// url
[ 0.013][v][ifo] Opening \\HELLSPAWN\Media Browser\HD Movies\300 Rise of an Empire\300.Rise.of.an.Empire.2014.1080p.BluRay.x264.YIFY.mp4
[ 0.013][v][ifo_dvdnav] Opening \\HELLSPAWN\Media Browser\HD Movies\300 Rise of an Empire\300.Rise.of.an.Empire.2014.1080p.BluRay.x264.YIFY.mp4
[ 0.014][v][bdmv/bluray] Opening \\HELLSPAWN\Media Browser\HD Movies\300 Rise of an Empire\300.Rise.of.an.Empire.2014.1080p.BluRay.x264.YIFY.mp4
[ 0.015][v][file] Opening \\HELLSPAWN\Media Browser\HD Movies\300 Rise of an Empire\300.Rise.of.an.Empire.2014.1080p.BluRay.x264.YIFY.mp4
[ 0.016][d][file] Stream opened successfully.
[ 0.017][v][cache] Cache size set to 20000 KiB (10000 KiB backbuffer)
[ 0.017][v][demux] Trying demuxers for level=normal.
[ 0.017][d][demux] Trying demuxer: disc (force-level: normal)
[ 0.017][d][demux] Trying demuxer: edl (force-level: normal)
[ 0.017][d][demux] Trying demuxer: cue (force-level: normal)
[ 0.017][d][demux] Trying demuxer: rawaudio (force-level: normal)
[ 0.017][d][demux] Trying demuxer: rawvideo (force-level: normal)
[ 0.018][d][demux] Trying demuxer: mkv (force-level: normal)
[ 0.018][d][demux] Trying demuxer: libarchive (force-level: normal)
[ 0.018][d][demux] Trying demuxer: rar (force-level: normal)
[ 0.018][d][demux] Trying demuxer: lavf (force-level: normal)
[ 0.019][v][lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048.
[ 0.063][d][cache] request seek: 0 <= to=1761974934 (cur=3186865) <= 13426865
[ 0.063][v][cache] Dropping cache at pos 1761974934, cached range: 0-13426865.
[ 0.063][v][cache] Seeking underlying stream: 13426865 -> 1761974934
[ 0.063][v][demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat)
[ 0.063][v][cache] blocking for STREAM_CTRL 6
[ 0.063][v][cache] EOF reached.
[ 0.063][v][cplayer] Opening done: \\HELLSPAWN\Media Browser\HD Movies\300 Rise of an Empire\300.Rise.of.an.Empire.2014.1080p.BluRay.x264.YIFY.mp4
[ 0.064][v][find_files] Loading external files in \\HELLSPAWN\Media Browser\HD Movies\300 Rise of an Empire\
[ 0.066][v][cplayer] Running hook: ytdl_hook/on_preloaded
[ 0.067][v][lavf] select track 0
[ 0.067][v][lavf] select track 1
[ 0.067][i][cplayer] (+) Video --vid=1 (*) (h264 1920x800 23.976fps)
[ 0.067][i][cplayer] (+) Audio --aid=1 --alang=eng (*) (aac 2ch 48000Hz)
[ 0.068][v][vo/gpu] Probing for best GPU context.
[ 0.068][v][vo/gpu/d3d11] Initializing GPU context 'd3d11'
[ 0.095][v][vo/gpu/d3d11] Using Direct3D 11 feature level 11_1
[ 0.095][v][vo/gpu/d3d11] Device Name: AMD Radeon R9 200 Series
[ 0.095][v][vo/gpu/d3d11] Device ID: 1002:6810 (rev 00)
[ 0.095][v][vo/gpu/d3d11] Subsystem ID: 1462:3030
[ 0.095][v][vo/gpu/d3d11] LUID: 000000000000cd73
[ 0.095][v][vo/gpu/d3d11] Initializing SPIR-V compiler 'shaderc'
[ 0.095][v][vo/gpu/d3d11] Using Direct3D 11.1 runtime
[ 0.095][v][vo/gpu/d3d11] Maximum Texture2D size: 16384x16384
[ 0.096][v][vo/gpu/d3d11] D3DCompiler version: 10.0.18362.1
[ 0.167][v][vo/gpu/win32] resize window: 1920:1080
[ 0.167][v][vo/gpu/win32] DPI detected from the new API: 96
[ 0.167][v][vo/gpu/win32] display-fps: 59.940060
[ 0.171][v][vo/gpu/win32] color-profile: C:\WINDOWS\system32\spool\drivers\color\sRGB Color Space Profile.icm
[ 0.171][d][vo/gpu/win32] move window: 0:0
[ 0.184][v][vo/gpu/d3d11] Using DXGI 1.2+
[ 0.184][v][vo/gpu/d3d11] Using flip-model presentation
[ 0.184][d][vo/gpu/d3d11] Texture formats:
[ 0.184][d][vo/gpu/d3d11] NAME COMP*TYPE SIZE DEPTH PER COMP.
[ 0.184][d][vo/gpu/d3d11] r8 1*unorm 1B LF CR {8}
[ 0.185][d][vo/gpu/d3d11] rg8 2*unorm 2B LF CR {8 8}
[ 0.185][d][vo/gpu/d3d11] rgba8 4*unorm 4B LF CR {8 8 8 8}
[ 0.185][d][vo/gpu/d3d11] r16 1*unorm 2B LF CR {16}
[ 0.185][d][vo/gpu/d3d11] rg16 2*unorm 4B LF CR {16 16}
[ 0.185][d][vo/gpu/d3d11] rgba16 4*unorm 8B LF CR {16 16 16 16}
[ 0.185][d][vo/gpu/d3d11] r32ui 1*uint 4B {32}
[ 0.185][d][vo/gpu/d3d11] rg32ui 2*uint 8B {32 32}
[ 0.185][d][vo/gpu/d3d11] rgb32ui 3*uint 12B {32 32 32}
[ 0.185][d][vo/gpu/d3d11] rgba32ui 4*uint 16B {32 32 32 32}
[ 0.185][d][vo/gpu/d3d11] r16hf 1*float 2B LF CR {16}
[ 0.185][d][vo/gpu/d3d11] rg16hf 2*float 4B LF CR {16 16}
[ 0.185][d][vo/gpu/d3d11] rgba16hf 4*float 8B LF CR {16 16 16 16}
[ 0.185][d][vo/gpu/d3d11] r32f 1*float 4B LF CR {32}
[ 0.185][d][vo/gpu/d3d11] rg32f 2*float 8B LF CR {32 32}
[ 0.185][d][vo/gpu/d3d11] rgb32f 3*float 12B {32 32 32}
[ 0.185][d][vo/gpu/d3d11] rgba32f 4*float 16B LF CR {32 32 32 32}
[ 0.185][d][vo/gpu/d3d11] rgb10_a2 4*unorm 4B LF CR {10 10 10 2}
[ 0.185][d][vo/gpu/d3d11] bgra8 4*unorm 4B LF CR {8 8 8 8}
[ 0.185][d][vo/gpu/d3d11] bgrx8 3*unorm 4B LF CR {8 8 8}
[ 0.185][d][vo/gpu/d3d11] LA = LUMINANCE_ALPHA hack format
[ 0.185][d][vo/gpu/d3d11] LF = linear filterable
[ 0.185][d][vo/gpu/d3d11] CR = can be used for render targets
[ 0.185][d][vo/gpu/d3d11] Image formats:
[ 0.185][d][vo/gpu/d3d11] yuv444p => 3 planes 1x1 8/0 [r8/r8/r8] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] yuv420p => 3 planes 2x2 8/0 [r8/r8/r8] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] gray => 1 planes 1x1 8/0 [r8] (r)
[ 0.185][d][vo/gpu/d3d11] gray16 => 1 planes 1x1 16/0 [r16] (r)
[ 0.185][d][vo/gpu/d3d11] uyvy422
[ 0.185][d][vo/gpu/d3d11] nv12 => 2 planes 2x2 8/0 [r8/rg8] (r/gb)
[ 0.185][d][vo/gpu/d3d11] p010 => 2 planes 2x2 16/6 [r16/rg16] (r/gb)
[ 0.185][d][vo/gpu/d3d11] argb => 1 planes 1x1 8/0 [rgba8] (argb)
[ 0.185][d][vo/gpu/d3d11] bgra => 1 planes 1x1 8/0 [rgba8] (bgra)
[ 0.185][d][vo/gpu/d3d11] abgr => 1 planes 1x1 8/0 [rgba8] (abgr)
[ 0.185][d][vo/gpu/d3d11] rgba => 1 planes 1x1 8/0 [rgba8] (rgba)
[ 0.185][d][vo/gpu/d3d11] bgr24
[ 0.185][d][vo/gpu/d3d11] rgb24
[ 0.185][d][vo/gpu/d3d11] 0rgb => 1 planes 1x1 8/0 [rgba8] (_rgb)
[ 0.185][d][vo/gpu/d3d11] bgr0 => 1 planes 1x1 8/0 [rgba8] (bgr)
[ 0.185][d][vo/gpu/d3d11] 0bgr => 1 planes 1x1 8/0 [rgba8] (_bgr)
[ 0.185][d][vo/gpu/d3d11] rgb0 => 1 planes 1x1 8/0 [rgba8] (rgb)
[ 0.185][d][vo/gpu/d3d11] rgba64 => 1 planes 1x1 16/0 [rgba16] (rgba)
[ 0.185][d][vo/gpu/d3d11] rgb565
[ 0.185][d][vo/gpu/d3d11] vdpau
[ 0.185][d][vo/gpu/d3d11] vdpau_output
[ 0.185][d][vo/gpu/d3d11] vaapi
[ 0.185][d][vo/gpu/d3d11] d3d11
[ 0.185][d][vo/gpu/d3d11] dxva2_vld
[ 0.185][d][vo/gpu/d3d11] mmal
[ 0.185][d][vo/gpu/d3d11] videotoolbox
[ 0.185][d][vo/gpu/d3d11] drm_prime
[ 0.185][d][vo/gpu/d3d11] cuda
[ 0.185][d][vo/gpu/d3d11] yuyv422
[ 0.185][d][vo/gpu/d3d11] yuv422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] yuv410p => 3 planes 4x4 8/0 [r8/r8/r8] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] yuv411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] monow
[ 0.185][d][vo/gpu/d3d11] monob
[ 0.185][d][vo/gpu/d3d11] pal8
[ 0.185][d][vo/gpu/d3d11] yuvj422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] uyyvyy411
[ 0.185][d][vo/gpu/d3d11] bgr8
[ 0.185][d][vo/gpu/d3d11] bgr4
[ 0.185][d][vo/gpu/d3d11] bgr4_byte
[ 0.185][d][vo/gpu/d3d11] rgb8
[ 0.185][d][vo/gpu/d3d11] rgb4
[ 0.185][d][vo/gpu/d3d11] rgb4_byte
[ 0.185][d][vo/gpu/d3d11] nv21 => 2 planes 2x2 8/0 [r8/rg8] (r/bg)
[ 0.185][d][vo/gpu/d3d11] gray16be
[ 0.185][d][vo/gpu/d3d11] yuv440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] yuvj440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] yuva420p => 4 planes 2x2 8/0 [r8/r8/r8/r8] (r/g/b/a)
[ 0.185][d][vo/gpu/d3d11] rgb48be
[ 0.185][d][vo/gpu/d3d11] rgb565be
[ 0.185][d][vo/gpu/d3d11] rgb555be
[ 0.185][d][vo/gpu/d3d11] bgr565be
[ 0.185][d][vo/gpu/d3d11] bgr555be
[ 0.185][d][vo/gpu/d3d11] vaapi_moco
[ 0.185][d][vo/gpu/d3d11] vaapi_idct
[ 0.185][d][vo/gpu/d3d11] yuv420p16 => 3 planes 2x2 16/0 [r16/r16/r16] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] yuv420p16be
[ 0.185][d][vo/gpu/d3d11] yuv422p16 => 3 planes 2x1 16/0 [r16/r16/r16] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] yuv422p16be
[ 0.185][d][vo/gpu/d3d11] yuv444p16 => 3 planes 1x1 16/0 [r16/r16/r16] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] yuv444p16be
[ 0.185][d][vo/gpu/d3d11] rgb444
[ 0.185][d][vo/gpu/d3d11] rgb444be
[ 0.185][d][vo/gpu/d3d11] bgr444
[ 0.185][d][vo/gpu/d3d11] bgr444be
[ 0.185][d][vo/gpu/d3d11] ya8 => 1 planes 1x1 8/0 [rg8] (ra)
[ 0.185][d][vo/gpu/d3d11] bgr48be
[ 0.185][d][vo/gpu/d3d11] yuv420p9be
[ 0.185][d][vo/gpu/d3d11] yuv420p9 => 3 planes 2x2 16/-7 [r16/r16/r16] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] yuv420p10be
[ 0.185][d][vo/gpu/d3d11] yuv420p10 => 3 planes 2x2 16/-6 [r16/r16/r16] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] yuv422p10be
[ 0.185][d][vo/gpu/d3d11] yuv422p10 => 3 planes 2x1 16/-6 [r16/r16/r16] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] yuv444p9be
[ 0.185][d][vo/gpu/d3d11] yuv444p9 => 3 planes 1x1 16/-7 [r16/r16/r16] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] yuv444p10be
[ 0.185][d][vo/gpu/d3d11] yuv444p10 => 3 planes 1x1 16/-6 [r16/r16/r16] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] yuv422p9be
[ 0.185][d][vo/gpu/d3d11] yuv422p9 => 3 planes 2x1 16/-7 [r16/r16/r16] (r/g/b)
[ 0.185][d][vo/gpu/d3d11] gbrp => 3 planes 1x1 8/0 [r8/r8/r8] (g/b/r)
[ 0.185][d][vo/gpu/d3d11] gbrp9be
[ 0.185][d][vo/gpu/d3d11] gbrp9 => 3 planes 1x1 16/-7 [r16/r16/r16] (g/b/r)
[ 0.185][d][vo/gpu/d3d11] gbrp10be
[ 0.185][d][vo/gpu/d3d11] gbrp10 => 3 planes 1x1 16/-6 [r16/r16/r16] (g/b/r)
[ 0.185][d][vo/gpu/d3d11] gbrp16be
[ 0.185][d][vo/gpu/d3d11] gbrp16 => 3 planes 1x1 16/0 [r16/r16/r16] (g/b/r)
[ 0.185][d][vo/gpu/d3d11] yuva422p => 4 planes 2x1 8/0 [r8/r8/r8/r8] (r/g/b/a)
[ 0.185][d][vo/gpu/d3d11] yuva444p => 4 planes 1x1 8/0 [r8/r8/r8/r8] (r/g/b/a)
[ 0.185][d][vo/gpu/d3d11] yuva420p9be
[ 0.185][d][vo/gpu/d3d11] yuva420p9 => 4 planes 2x2 16/-7 [r16/r16/r16/r16] (r/g/b/a)
[ 0.185][d][vo/gpu/d3d11] yuva422p9be
[ 0.185][d][vo/gpu/d3d11] yuva422p9 => 4 planes 2x1 16/-7 [r16/r16/r16/r16] (r/g/b/a)
[ 0.185][d][vo/gpu/d3d11] yuva444p9be
[ 0.185][d][vo/gpu/d3d11] yuva444p9 => 4 planes 1x1 16/-7 [r16/r16/r16/r16] (r/g/b/a)
[ 0.185][d][vo/gpu/d3d11] yuva420p10be
[ 0.185][d][vo/gpu/d3d11] yuva420p10 => 4 planes 2x2 16/-6 [r16/r16/r16/r16] (r/g/b/a)
[ 0.185][d][vo/gpu/d3d11] yuva422p10be
[ 0.186][d][vo/gpu/d3d11] yuva422p10 => 4 planes 2x1 16/-6 [r16/r16/r16/r16] (r/g/b/a)
[ 0.186][d][vo/gpu/d3d11] yuva444p10be
[ 0.186][d][vo/gpu/d3d11] yuva444p10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (r/g/b/a)
[ 0.186][d][vo/gpu/d3d11] yuva420p16be
[ 0.186][d][vo/gpu/d3d11] yuva420p16 => 4 planes 2x2 16/0 [r16/r16/r16/r16] (r/g/b/a)
[ 0.186][d][vo/gpu/d3d11] yuva422p16be
[ 0.186][d][vo/gpu/d3d11] yuva422p16 => 4 planes 2x1 16/0 [r16/r16/r16/r16] (r/g/b/a)
[ 0.186][d][vo/gpu/d3d11] yuva444p16be
[ 0.186][d][vo/gpu/d3d11] yuva444p16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (r/g/b/a)
[ 0.186][d][vo/gpu/d3d11] xyz12
[ 0.186][d][vo/gpu/d3d11] xyz12be
[ 0.186][d][vo/gpu/d3d11] nv16 => 2 planes 2x1 8/0 [r8/rg8] (r/gb)
[ 0.186][d][vo/gpu/d3d11] nv20 => 2 planes 2x1 16/-6 [r16/rg16] (r/gb)
[ 0.186][d][vo/gpu/d3d11] nv20be
[ 0.186][d][vo/gpu/d3d11] rgba64be
[ 0.186][d][vo/gpu/d3d11] bgra64be
[ 0.186][d][vo/gpu/d3d11] bgra64 => 1 planes 1x1 16/0 [rgba16] (bgra)
[ 0.186][d][vo/gpu/d3d11] yvyu422
[ 0.186][d][vo/gpu/d3d11] ya16be
[ 0.186][d][vo/gpu/d3d11] ya16 => 1 planes 1x1 16/0 [rg16] (ra)
[ 0.186][d][vo/gpu/d3d11] gbrap => 4 planes 1x1 8/0 [r8/r8/r8/r8] (g/b/r/a)
[ 0.186][d][vo/gpu/d3d11] gbrap16be
[ 0.186][d][vo/gpu/d3d11] gbrap16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (g/b/r/a)
[ 0.186][d][vo/gpu/d3d11] qsv
[ 0.186][d][vo/gpu/d3d11] d3d11va_vld
[ 0.186][d][vo/gpu/d3d11] yuv420p12be
[ 0.186][d][vo/gpu/d3d11] yuv420p12 => 3 planes 2x2 16/-4 [r16/r16/r16] (r/g/b)
[ 0.186][d][vo/gpu/d3d11] yuv420p14be
[ 0.186][d][vo/gpu/d3d11] yuv420p14 => 3 planes 2x2 16/-2 [r16/r16/r16] (r/g/b)
[ 0.186][d][vo/gpu/d3d11] yuv422p12be
[ 0.186][d][vo/gpu/d3d11] yuv422p12 => 3 planes 2x1 16/-4 [r16/r16/r16] (r/g/b)
[ 0.186][d][vo/gpu/d3d11] yuv422p14be
[ 0.186][d][vo/gpu/d3d11] yuv422p14 => 3 planes 2x1 16/-2 [r16/r16/r16] (r/g/b)
[ 0.186][d][vo/gpu/d3d11] yuv444p12be
[ 0.186][d][vo/gpu/d3d11] yuv444p12 => 3 planes 1x1 16/-4 [r16/r16/r16] (r/g/b)
[ 0.186][d][vo/gpu/d3d11] yuv444p14be
[ 0.186][d][vo/gpu/d3d11] yuv444p14 => 3 planes 1x1 16/-2 [r16/r16/r16] (r/g/b)
[ 0.186][d][vo/gpu/d3d11] gbrp12be
[ 0.186][d][vo/gpu/d3d11] gbrp12 => 3 planes 1x1 16/-4 [r16/r16/r16] (g/b/r)
[ 0.186][d][vo/gpu/d3d11] gbrp14be
[ 0.186][d][vo/gpu/d3d11] gbrp14 => 3 planes 1x1 16/-2 [r16/r16/r16] (g/b/r)
[ 0.186][d][vo/gpu/d3d11] yuvj411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b)
[ 0.186][d][vo/gpu/d3d11] bayer_bggr8
[ 0.186][d][vo/gpu/d3d11] bayer_rggb8
[ 0.186][d][vo/gpu/d3d11] bayer_gbrg8
[ 0.186][d][vo/gpu/d3d11] bayer_grbg8
[ 0.186][d][vo/gpu/d3d11] bayer_bggr16
[ 0.186][d][vo/gpu/d3d11] bayer_bggr16be
[ 0.186][d][vo/gpu/d3d11] bayer_rggb16
[ 0.186][d][vo/gpu/d3d11] bayer_rggb16be
[ 0.186][d][vo/gpu/d3d11] bayer_gbrg16
[ 0.186][d][vo/gpu/d3d11] bayer_gbrg16be
[ 0.186][d][vo/gpu/d3d11] bayer_grbg16
[ 0.186][d][vo/gpu/d3d11] bayer_grbg16be
[ 0.186][d][vo/gpu/d3d11] xvmc
[ 0.186][d][vo/gpu/d3d11] yuv440p10 => 3 planes 1x2 16/-6 [r16/r16/r16] (r/g/b)
[ 0.186][d][vo/gpu/d3d11] yuv440p10be
[ 0.186][d][vo/gpu/d3d11] yuv440p12 => 3 planes 1x2 16/-4 [r16/r16/r16] (r/g/b)
[ 0.186][d][vo/gpu/d3d11] yuv440p12be
[ 0.186][d][vo/gpu/d3d11] ayuv64 => 1 planes 1x1 16/0 [rgba16] (argb)
[ 0.186][d][vo/gpu/d3d11] ayuv64be
[ 0.186][d][vo/gpu/d3d11] videotoolbox_vl
[ 0.186][d][vo/gpu/d3d11] p010be
[ 0.186][d][vo/gpu/d3d11] gbrap12be
[ 0.186][d][vo/gpu/d3d11] gbrap12 => 4 planes 1x1 16/-4 [r16/r16/r16/r16] (g/b/r/a)
[ 0.186][d][vo/gpu/d3d11] gbrap10be
[ 0.186][d][vo/gpu/d3d11] gbrap10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (g/b/r/a)
[ 0.186][d][vo/gpu/d3d11] mediacodec
[ 0.186][d][vo/gpu/d3d11] gray12be
[ 0.186][d][vo/gpu/d3d11] gray12 => 1 planes 1x1 16/-4 [r16] (r)
[ 0.186][d][vo/gpu/d3d11] gray10be
[ 0.186][d][vo/gpu/d3d11] gray10 => 1 planes 1x1 16/-6 [r16] (r)
[ 0.186][d][vo/gpu/d3d11] p016 => 2 planes 2x2 16/0 [r16/rg16] (r/gb)
[ 0.186][d][vo/gpu/d3d11] p016be
[ 0.186][d][vo/gpu/d3d11] gray9be
[ 0.186][d][vo/gpu/d3d11] gray9 => 1 planes 1x1 16/-7 [r16] (r)
[ 0.186][d][vo/gpu/d3d11] gbrpf32be
[ 0.186][d][vo/gpu/d3d11] gbrpf32 => 3 planes 1x1 32/0 [r32f/r32f/r32f] (g/b/r)
[ 0.186][d][vo/gpu/d3d11] gbrapf32be
[ 0.186][d][vo/gpu/d3d11] gbrapf32 => 4 planes 1x1 32/0 [r32f/r32f/r32f/r32f] (g/b/r/a)
[ 0.186][d][vo/gpu/d3d11] opencl
[ 0.186][d][vo/gpu/d3d11] gray14be
[ 0.186][d][vo/gpu/d3d11] gray14 => 1 planes 1x1 16/-2 [r16] (r)
[ 0.186][d][vo/gpu/d3d11] grayf32be
[ 0.186][d][vo/gpu/d3d11] grayf32 => 1 planes 1x1 32/0 [r32f] (r)
[ 0.186][v][vo/gpu] Testing FBO format rgba16hf
[ 0.186][d][vo/gpu] Resizing texture: 16x16
[ 0.186][v][vo/gpu] Using FBO format rgba16hf.
[ 0.186][v][vo/gpu] No advanced processing required. Enabling dumb mode.
[ 0.198][v][vo/gpu] Resize: 1920x1080
[ 0.198][v][vo/gpu] Reported display depth: 8
[ 0.198][v][vo/gpu] Assuming 59.940060 FPS for display sync.
[ 0.199][v][vd] Container reported FPS: 23.976025
[ 0.199][v][vd] Codec list:
[ 0.199][v][vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
[ 0.199][v][vd] h264_qsv (h264) - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (Intel Quick Sync Video acceleration)
[ 0.199][v][vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder
[ 0.199][v][vd] Opening decoder h264
[ 0.199][v][vd] Looking at hwdec h264-d3d11va...
[ 0.199][v][vo/gpu] Loading hwdec driver 'd3d11-egl'
[ 0.199][v][vo/gpu] Loading failed.
[ 0.199][v][vo/gpu] Loading hwdec driver 'd3d11-egl-rgb'
[ 0.199][v][vo/gpu] Loading hwdec driver 'dxva2-egl'
[ 0.199][v][vo/gpu] Loading hwdec driver 'd3d11va'
[ 0.210][v][vo/gpu] Loading hwdec driver 'dxva2-dxgi'
[ 0.256][v][vo/gpu] Loading hwdec driver 'dxva2-dxinterop'
[ 0.256][v][vo/gpu] Loading failed.
[ 0.256][v][vo/gpu] Loading hwdec driver 'cuda-nvdec'
[ 0.256][v][vd] Trying hardware decoding via h264-d3d11va.
[ 0.257][v][vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10)
[ 0.257][v][vf] User filter list:
[ 0.257][v][vf] (empty)
[ 0.257][v][ad] Codec list:
[ 0.257][v][ad] aac - AAC (Advanced Audio Coding)
[ 0.257][v][ad] aac_fixed (aac) - AAC (Advanced Audio Coding)
[ 0.257][v][ad] Opening decoder aac
[ 0.257][v][ad] Requesting 1 threads for decoding.
[ 0.259][v][ad] Selected codec: aac (AAC (Advanced Audio Coding))
[ 0.259][d][user_filter_wrapper] Setting option 'tospdif' = 'yes' (flags = 0)
[ 0.259][d][user_filter_wrapper] Setting option 'bitrate' = '384' (flags = 0)
[ 0.259][d][user_filter_wrapper] Setting option 'minch' = '2' (flags = 0)
[ 0.259][v][af] User filter list:
[ 0.259][v][af] lavcac3enc (lavcac3enc.00)
[ 0.259][v][cplayer] Starting playback...
[ 0.259][d][cache] request seek: 1761974934 <= to=3175033 (cur=1761974989) <= 1761974989
[ 0.259][v][cache] Dropping cache at pos 3175033, cached range: 1761974934-1761974989.
[ 0.259][v][cache] Seeking underlying stream: 1761974989 -> 3175033
[ 0.259][v][af] [in] 48000Hz stereo 2ch floatp
[ 0.259][v][af] [lavcac3enc] 48000Hz stereo 2ch floatp
[ 0.260][v][af] [userspeed] 48000Hz stereo 2ch spdif-ac3
[ 0.260][v][af] [userspeed] (disabled)
[ 0.260][v][af] [convert] 48000Hz stereo 2ch spdif-ac3
[ 0.260][v][vd] Pixel formats supported by decoder: cuda dxva2_vld d3d11va_vld d3d11 yuv420p
[ 0.260][v][vd] Codec profile: High (0x64)
[ 0.261][v][vd] Requesting pixfmt 'd3d11' from decoder.
[ 0.261][d][ffmpeg/video] h264: Decoder GUIDs reported as supported:
[ 0.261][d][ffmpeg/video] h264: {ee27417f-5e28-4e65-beea-1d26b508adc9} 103 106
[ 0.261][d][ffmpeg/video] h264: {bf22ad00-03ea-4690-8077-473346209b7e} 103 106
[ 0.261][d][ffmpeg/video] h264: {1b81be68-a0c7-11d3-b984-00c04f2e73c5} 103 106
[ 0.261][d][ffmpeg/video] h264: {4245f676-2bbc-4166-a0bb-54e7b849c380} 103 106
[ 0.261][d][ffmpeg/video] h264: {6719b6fb-5cad-4acb-b00a-f3bfdec38727} 103 106
[ 0.261][d][ffmpeg/video] h264: {9901ccd3-ca12-4b7e-867a-e2223d9255c3} 103 106
[ 0.262][d][ffmpeg/video] h264: {d79be8da-0cf1-4c81-b82a-69a4e236f43d} 103 106
[ 0.262][d][ffmpeg/video] h264: {f9aaccbb-c2b6-4cfc-8779-5707b1760552} 103 106
[ 0.262][d][ffmpeg/video] h264: {1b81bea3-a0c7-11d3-b984-00c04f2e73c5} 103 106
[ 0.262][d][ffmpeg/video] h264: {ca15d19a-2b48-43d6-979e-7a6e9c802ff8} 103 106
[ 0.262][d][ffmpeg/video] h264: {7c74adc6-e2ba-4ade-86de-30beabb40cc1} 103 106
[ 0.262][d][ffmpeg/video] h264: {ed418a9f-010d-4eda-9ae3-9a65358d8d2e} 103 106
[ 0.262][d][ffmpeg/video] h264: {1b81bea2-a0c7-11d3-b984-00c04f2e73c5} 103 106
[ 0.262][d][ffmpeg/video] h264: {1b81be94-a0c7-11d3-b984-00c04f2e73c5} 103 106
[ 0.262][d][ffmpeg/video] h264: {103473e4-10ea-11df-9a92-2ba055d89593} 103 106
[ 0.262][d][ffmpeg/video] h264: {84ad67f6-4c21-419a-9f0b-24f0578906c1} 103 106
[ 0.262][d][ffmpeg/video] h264: {725ad240-786c-471e-ad3c-38f739936517} 103 106
[ 0.262][d][ffmpeg/video] h264: {95664ff5-9e03-4c74-bb4f-9178d6035e58} 103 106
[ 0.262][d][ffmpeg/video] h264: {603a4756-a864-4f91-bb62-2c935b7a1391} 103 106
[ 0.264][d][ffmpeg/video] h264: Reinit context to 1920x800, pix_fmt: d3d11
[ 0.274][i][vd] Using hardware decoding (d3d11va).
[ 0.274][v][vd] Decoder format: 1920x800 [0:1] d3d11[nv12] bt.709/bt.709/auto/limited/auto CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000)
[ 0.274][v][vf] [in] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[ 0.275][v][vf] [userdeint] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[ 0.275][v][vf] [userdeint] (disabled)
[ 0.275][v][vf] [autorotate] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[ 0.275][v][vf] [autorotate] (disabled)
[ 0.275][v][vf] [convert] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[ 0.275][v][vf] [convert] (disabled)
[ 0.275][v][vf] [out] 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[ 0.275][v][ao] Trying audio driver 'wasapi'
[ 0.275][v][ao/wasapi] requested format: 48000 Hz, stereo channels, spdif-ac3
[ 0.275][d][ao/wasapi] Init wasapi
[ 0.275][d][ao/wasapi] Find device ''
[ 0.280][v][ao/wasapi] No device specified. Selecting default.
[ 0.285][v][ao/wasapi] Selecting device '{bcad7374-3085-42e2-a741-ae21c5192b08}' (6 - SONY AVAMP (AMD High Definition Audio Device))
[ 0.285][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{bcad7374-3085-42e2-a741-ae21c5192b08}
[ 0.291][d][ao/wasapi] Init wasapi thread
[ 0.291][d][ao/wasapi] Activating pAudioClient interface
[ 0.294][d][ao/wasapi] Probing formats
[ 0.295][v][ao/wasapi] Trying stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) -> unsupported
[ 0.295][d][ao/wasapi] Thread shutdown
[ 0.295][d][ao/wasapi] Uninit wasapi
[ 0.296][d][ao/wasapi] Thread uninit done
[ 0.296][d][ao/wasapi] Thread return
[ 0.296][d][ao/wasapi] Uninit wasapi done
[ 0.296][v][ao] Trying audio driver 'openal'
[ 0.296][v][ao/openal] requested format: 48000 Hz, stereo channels, spdif-ac3
[ 0.317][f][ao/openal] Can't find appropriate sample format.
[ 0.326][e][ao] Failed to initialize audio driver 'openal'
[ 0.326][v][cplayer] Falling back to PCM output.
[ 0.326][v][ad] Codec list:
[ 0.326][v][ad] aac - AAC (Advanced Audio Coding)
[ 0.326][v][ad] aac_fixed (aac) - AAC (Advanced Audio Coding)
[ 0.326][v][ad] Opening decoder aac
[ 0.326][v][ad] Requesting 1 threads for decoding.
[ 0.326][v][ad] Selected codec: aac (AAC (Advanced Audio Coding))
[ 0.326][i][cplayer] VO: [gpu] 1920x800 d3d11[nv12]
[ 0.326][v][cplayer] VO: Description: Shader-based GPU Renderer
[ 0.327][v][vo/gpu] reconfig to 1920x800 d3d11[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[ 0.327][d][vo/gpu] screen size: 1920x1080
[ 0.350][v][vo/gpu] Resize: 1920x1080
[ 0.350][v][vo/gpu] Window size: 1920x1080
[ 0.350][v][vo/gpu] Video source: 1920x800 (1:1)
[ 0.350][v][vo/gpu] Video display: (0, 0) 1920x800 -> (0, 140) 1920x800
[ 0.350][v][vo/gpu] Video scale: 1.000000/1.000000
[ 0.350][v][vo/gpu] OSD borders: l=0 t=140 r=0 b=140
[ 0.350][v][vo/gpu] Video borders: l=0 t=140 r=0 b=140
[ 0.350][v][vo/gpu] Reported display depth: 8
[ 0.350][v][vo/gpu] Testing FBO format rgba16hf
[ 0.350][d][vo/gpu] Resizing texture: 16x16
[ 0.350][v][vo/gpu] Using FBO format rgba16hf.
[ 0.350][v][vo/gpu] No advanced processing required. Enabling dumb mode.
[ 0.414][v][vo/gpu/d3d11] shaderc compile status 'success' (0 errors, 0 warnings)
[ 0.416][v][vo/gpu/d3d11] Compiled a vertex shader in 65585us
[ 0.416][v][vo/gpu/d3d11] shaderc: 63647us, SPIRV-Cross: 302us, D3DCompile: 1636us
[ 0.416][d][vo/gpu/d3d11] GLSL source:
[ 0.416][d][vo/gpu/d3d11] [ 1] #version 450
[ 0.416][d][vo/gpu/d3d11] [ 2] #define tex1D texture
[ 0.416][d][vo/gpu/d3d11] [ 3] #define tex3D texture
[ 0.416][d][vo/gpu/d3d11] [ 4] #define LUT_POS(x, lut_size) mix(0.5 / (lut_size), 1.0 - 0.5 / (lut_size), (x))
[ 0.416][d][vo/gpu/d3d11] [ 5] layout(location=0) in vec2 vertex_position;
[ 0.416][d][vo/gpu/d3d11] [ 6] layout(location=1) in vec2 vertex_texcoord0;
[ 0.416][d][vo/gpu/d3d11] [ 7] layout(location=1) out vec2 texcoord0;
[ 0.416][d][vo/gpu/d3d11] [ 8] layout(location=2) in vec2 vertex_texcoord1;
[ 0.416][d][vo/gpu/d3d11] [ 9] layout(location=2) out vec2 texcoord1;
[ 0.416][d][vo/gpu/d3d11] [ 10] void main() {
[ 0.416][d][vo/gpu/d3d11] [ 11] gl_Position = vec4(vertex_position, 1.0, 1.0);
[ 0.416][d][vo/gpu/d3d11] [ 12] texcoord0 = vertex_texcoord0;
[ 0.416][d][vo/gpu/d3d11] [ 13] texcoord1 = vertex_texcoord1;
[ 0.416][d][vo/gpu/d3d11] [ 14] }
[ 0.416][d][vo/gpu/d3d11] HLSL source:
[ 0.416][d][vo/gpu/d3d11] [ 1] static float4 gl_Position;
[ 0.416][d][vo/gpu/d3d11] [ 2] static float2 _18;
[ 0.416][d][vo/gpu/d3d11] [ 3] static float2 _27;
[ 0.416][d][vo/gpu/d3d11] [ 4] static float2 _28;
[ 0.416][d][vo/gpu/d3d11] [ 5] static float2 _30;
[ 0.416][d][vo/gpu/d3d11] [ 6] static float2 _31;
[ 0.416][d][vo/gpu/d3d11] [ 8] struct SPIRV_Cross_Input
[ 0.416][d][vo/gpu/d3d11] [ 9] {
[ 0.416][d][vo/gpu/d3d11] [ 10] float2 _18 : TEXCOORD0;
[ 0.416][d][vo/gpu/d3d11] [ 11] float2 _28 : TEXCOORD1;
[ 0.416][d][vo/gpu/d3d11] [ 12] float2 _31 : TEXCOORD2;
[ 0.416][d][vo/gpu/d3d11] [ 13] };
[ 0.416][d][vo/gpu/d3d11] [ 15] struct SPIRV_Cross_Output
[ 0.416][d][vo/gpu/d3d11] [ 16] {
[ 0.416][d][vo/gpu/d3d11] [ 17] float2 _27 : TEXCOORD1;
[ 0.416][d][vo/gpu/d3d11] [ 18] float2 _30 : TEXCOORD2;
[ 0.416][d][vo/gpu/d3d11] [ 19] float4 gl_Position : SV_Position;
[ 0.416][d][vo/gpu/d3d11] [ 20] };
[ 0.416][d][vo/gpu/d3d11] [ 21]
[ 0.416][d][vo/gpu/d3d11] [ 22] void vert_main()
[ 0.416][d][vo/gpu/d3d11] [ 23] {
[ 0.416][d][vo/gpu/d3d11] [ 24] gl_Position = float4(_18, 1.0f, 1.0f);
[ 0.416][d][vo/gpu/d3d11] [ 25] _27 = _28;
[ 0.416][d][vo/gpu/d3d11] [ 26] _30 = _31;
[ 0.416][d][vo/gpu/d3d11] [ 27] gl_Position.y = -gl_Position.y;
[ 0.416][d][vo/gpu/d3d11] [ 28] }
[ 0.416][d][vo/gpu/d3d11] [ 29]
[ 0.416][d][vo/gpu/d3d11] [ 30] SPIRV_Cross_Output main(SPIRV_Cross_Input stage_input)
[ 0.416][d][vo/gpu/d3d11] [ 31] {
[ 0.416][d][vo/gpu/d3d11] [ 32] _18 = stage_input._18;
[ 0.416][d][vo/gpu/d3d11] [ 33] _28 = stage_input._28;
[ 0.416][d][vo/gpu/d3d11] [ 34] _31 = stage_input._31;
[ 0.416][d][vo/gpu/d3d11] [ 35] vert_main();
[ 0.416][d][vo/gpu/d3d11] [ 36] SPIRV_Cross_Output stage_output;
[ 0.416][d][vo/gpu/d3d11] [ 37] stage_output.gl_Position = gl_Position;
[ 0.416][d][vo/gpu/d3d11] [ 38] stage_output._27 = _27;
[ 0.416][d][vo/gpu/d3d11] [ 39] stage_output._30 = _30;
[ 0.416][d][vo/gpu/d3d11] [ 40] return stage_output;
[ 0.416][d][vo/gpu/d3d11] [ 41] }
[ 0.419][v][vo/gpu/d3d11] shaderc compile status 'success' (0 errors, 0 warnings)
[ 0.423][v][vo/gpu/d3d11] Compiled a fragment shader in 6588us
[ 0.423][v][vo/gpu/d3d11] shaderc: 2202us, SPIRV-Cross: 278us, D3DCompile: 4108us
[ 0.423][d][vo/gpu/d3d11] GLSL source:
[ 0.423][d][vo/gpu/d3d11] [ 1] #version 450
[ 0.423][d][vo/gpu/d3d11] [ 2] #define tex1D texture
[ 0.423][d][vo/gpu/d3d11] [ 3] #define tex3D texture
[ 0.423][d][vo/gpu/d3d11] [ 4] #define LUT_POS(x, lut_size) mix(0.5 / (lut_size), 1.0 - 0.5 / (lut_size), (x))
[ 0.424][d][vo/gpu/d3d11] [ 5] layout(location=0) out vec4 out_color;
[ 0.424][d][vo/gpu/d3d11] [ 6] layout(location=1) in vec2 texcoord0;
[ 0.424][d][vo/gpu/d3d11] [ 7] layout(location=2) in vec2 texcoord1;
[ 0.424][d][vo/gpu/d3d11] [ 8] layout(std140, binding=0) uniform UBO {
[ 0.424][d][vo/gpu/d3d11] [ 9] layout(offset=0) mat3 colormatrix;
[ 0.424][d][vo/gpu/d3d11] [ 10] layout(offset=48) vec3 colormatrix_c;
[ 0.424][d][vo/gpu/d3d11] [ 11] layout(offset=64) vec3 src_luma;
[ 0.424][d][vo/gpu/d3d11] [ 12] layout(offset=80) vec3 dst_luma;
[ 0.424][d][vo/gpu/d3d11] [ 13] layout(offset=96) vec2 texture_size0;
[ 0.424][d][vo/gpu/d3d11] [ 14] layout(offset=112) mat2 texture_rot0;
[ 0.424][d][vo/gpu/d3d11] [ 15] layout(offset=144) vec2 texture_off0;
[ 0.424][d][vo/gpu/d3d11] [ 16] layout(offset=152) vec2 pixel_size0;
[ 0.424][d][vo/gpu/d3d11] [ 17] layout(offset=160) vec2 texture_size1;
[ 0.424][d][vo/gpu/d3d11] [ 18] layout(offset=176) mat2 texture_rot1;
[ 0.424][d][vo/gpu/d3d11] [ 19] layout(offset=208) vec2 texture_off1;
[ 0.424][d][vo/gpu/d3d11] [ 20] layout(offset=216) vec2 pixel_size1;
[ 0.424][d][vo/gpu/d3d11] [ 21] };
[ 0.424][d][vo/gpu/d3d11] [ 22] layout(binding=0) uniform sampler2D texture0;
[ 0.424][d][vo/gpu/d3d11] [ 23] layout(binding=1) uniform sampler2D texture1;
[ 0.424][d][vo/gpu/d3d11] [ 24] void main() {
[ 0.424][d][vo/gpu/d3d11] [ 25] vec4 color = vec4(0.0, 0.0, 0.0, 1.0);
[ 0.424][d][vo/gpu/d3d11] [ 26] color.r = 1.000000 * vec4(texture(texture0, texcoord0)).r;
[ 0.424][d][vo/gpu/d3d11] [ 27] color.gb = 1.000000 * vec4(texture(texture1, texcoord1)).rg;
[ 0.424][d][vo/gpu/d3d11] [ 28] color = color.rgbr;
[ 0.424][d][vo/gpu/d3d11] [ 29] color.rgb = mat3(colormatrix) * color.rgb + colormatrix_c;
[ 0.424][d][vo/gpu/d3d11] [ 30] color.a = 1.0;
[ 0.424][d][vo/gpu/d3d11] [ 31] // color mapping
[ 0.424][d][vo/gpu/d3d11] [ 32] color.rgb *= vec3(1.000000);
[ 0.424][d][vo/gpu/d3d11] [ 33] color.rgb *= vec3(1.000000);
[ 0.424][d][vo/gpu/d3d11] [ 34] out_color = color;
[ 0.424][d][vo/gpu/d3d11] [ 35] }
[ 0.424][d][vo/gpu/d3d11] HLSL source:
[ 0.424][d][vo/gpu/d3d11] [ 1] cbuffer _53_55 : register(b0)
[ 0.424][d][vo/gpu/d3d11] [ 2] {
[ 0.424][d][vo/gpu/d3d11] [ 3] row_major float3x3 _55_m0 : packoffset(c0);
[ 0.424][d][vo/gpu/d3d11] [ 4] float3 _55_m1 : packoffset(c3);
[ 0.424][d][vo/gpu/d3d11] [ 5] float3 _55_m2 : packoffset(c4);
[ 0.424][d][vo/gpu/d3d11] [ 6] float3 _55_m3 : packoffset(c5);
[ 0.424][d][vo/gpu/d3d11] [ 7] float2 _55_m4 : packoffset(c6);
[ 0.424][d][vo/gpu/d3d11] [ 8] row_major float2x2 _55_m5 : packoffset(c7);
[ 0.424][d][vo/gpu/d3d11] [ 9] float2 _55_m6 : packoffset(c9);
[ 0.424][d][vo/gpu/d3d11] [ 10] float2 _55_m7 : packoffset(c9.z);
[ 0.424][d][vo/gpu/d3d11] [ 11] float2 _55_m8 : packoffset(c10);
[ 0.424][d][vo/gpu/d3d11] [ 12] row_major float2x2 _55_m9 : packoffset(c11);
[ 0.424][d][vo/gpu/d3d11] [ 13] float2 _55_m10 : packoffset(c13);
[ 0.424][d][vo/gpu/d3d11] [ 14] float2 _55_m11 : packoffset(c13.z);
[ 0.424][d][vo/gpu/d3d11] [ 15] };
[ 0.424][d][vo/gpu/d3d11] [ 17] Texture2D<float4> _16 : register(t0);
[ 0.424][d][vo/gpu/d3d11] [ 18] SamplerState __16_sampler : register(s0);
[ 0.424][d][vo/gpu/d3d11] [ 19] Texture2D<float4> _34 : register(t1);
[ 0.424][d][vo/gpu/d3d11] [ 20] SamplerState __34_sampler : register(s1);
[ 0.424][d][vo/gpu/d3d11] [ 22] static float2 _20;
[ 0.424][d][vo/gpu/d3d11] [ 23] static float2 _36;
[ 0.424][d][vo/gpu/d3d11] [ 24] static float4 _89;
[ 0.424][d][vo/gpu/d3d11] [ 26] struct SPIRV_Cross_Input
[ 0.424][d][vo/gpu/d3d11] [ 27] {
[ 0.424][d][vo/gpu/d3d11] [ 28] float2 _20 : TEXCOORD1;
[ 0.424][d][vo/gpu/d3d11] [ 29] float2 _36 : TEXCOORD2;
[ 0.424][d][vo/gpu/d3d11] [ 30] };
[ 0.424][d][vo/gpu/d3d11] [ 32] struct SPIRV_Cross_Output
[ 0.424][d][vo/gpu/d3d11] [ 33] {
[ 0.424][d][vo/gpu/d3d11] [ 34] float4 _89 : SV_Target0;
[ 0.424][d][vo/gpu/d3d11] [ 35] };
[ 0.424][d][vo/gpu/d3d11] [ 36]
[ 0.424][d][vo/gpu/d3d11] [ 37] void frag_main()
[ 0.424][d][vo/gpu/d3d11] [ 38] {
[ 0.424][d][vo/gpu/d3d11] [ 39] float4 _92 = float4(0.0f, 0.0f, 0.0f, 1.0f);
[ 0.424][d][vo/gpu/d3d11] [ 40] _92.x = _16.Sample(__16_sampler, _20).x;
[ 0.424][d][vo/gpu/d3d11] [ 41] float2 _45 = _34.Sample(__34_sampler, _36).xy * 1.0f;
[ 0.424][d][vo/gpu/d3d11] [ 42] float4 _47 = float4(_92.x, _45.x, _45.y, _92.w);
[ 0.424][d][vo/gpu/d3d11] [ 43] float3 _72 = mul(_47.xyz, _55_m0) + _55_m1;
[ 0.424][d][vo/gpu/d3d11] [ 44] float4 _94 = float4(_72.x, _72.y, _72.z, _92.x);
[ 0.424][d][vo/gpu/d3d11] [ 45] _94.w = 1.0f;
[ 0.424][d][vo/gpu/d3d11] [ 46] _89 = float4(_94.x, _94.y, _94.z, _94.w);
[ 0.424][d][vo/gpu/d3d11] [ 47] }
[ 0.424][d][vo/gpu/d3d11] [ 48]
[ 0.424][d][vo/gpu/d3d11] [ 49] SPIRV_Cross_Output main(SPIRV_Cross_Input stage_input)
[ 0.424][d][vo/gpu/d3d11] [ 50] {
[ 0.424][d][vo/gpu/d3d11] [ 51] _20 = stage_input._20;
[ 0.424][d][vo/gpu/d3d11] [ 52] _36 = stage_input._36;
[ 0.424][d][vo/gpu/d3d11] [ 53] frag_main();
[ 0.424][d][vo/gpu/d3d11] [ 54] SPIRV_Cross_Output stage_output;
[ 0.424][d][vo/gpu/d3d11] [ 55] stage_output._89 = _89;
[ 0.424][d][vo/gpu/d3d11] [ 56] return stage_output;
[ 0.424][d][vo/gpu/d3d11] [ 57] }
[ 0.433][v][cplayer] first video frame after restart shown
[ 0.433][v][af] [in] 48000Hz stereo 2ch floatp
[ 0.433][v][af] [lavcac3enc] 48000Hz stereo 2ch floatp
[ 0.433][v][af] [userspeed] 48000Hz stereo 2ch spdif-ac3
[ 0.433][v][af] [convert] 48000Hz stereo 2ch spdif-ac3
[ 0.433][v][ao] Trying audio driver 'wasapi'
[ 0.433][v][ao/wasapi] requested format: 48000 Hz, stereo channels, spdif-ac3
[ 0.433][d][ao/wasapi] Init wasapi
[ 0.433][d][ao/wasapi] Find device ''
[ 0.435][v][ao/wasapi] No device specified. Selecting default.
[ 0.439][v][ao/wasapi] Selecting device '{bcad7374-3085-42e2-a741-ae21c5192b08}' (6 - SONY AVAMP (AMD High Definition Audio Device))
[ 0.439][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{bcad7374-3085-42e2-a741-ae21c5192b08}
[ 0.444][d][ao/wasapi] Init wasapi thread
[ 0.444][d][ao/wasapi] Activating pAudioClient interface
[ 0.445][d][ao/wasapi] Probing formats
[ 0.445][v][ao/wasapi] Trying stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) -> unsupported
[ 0.445][d][ao/wasapi] Thread shutdown
[ 0.445][d][ao/wasapi] Uninit wasapi
[ 0.445][d][ao/wasapi] Thread uninit done
[ 0.445][d][ao/wasapi] Thread return
[ 0.446][d][ao/wasapi] Uninit wasapi done
[ 0.446][v][ao] Trying audio driver 'openal'
[ 0.446][v][ao/openal] requested format: 48000 Hz, stereo channels, spdif-ac3
[ 0.461][f][ao/openal] Can't find appropriate sample format.
[ 0.465][e][ao] Failed to initialize audio driver 'openal'
[ 0.465][e][cplayer] Could not open/initialize audio device -> no sound.
[ 0.465][v][ad] Uninit decoder.
[ 0.465][v][lavf] deselect track 1
[ 0.475][i][cplayer] Audio: no audio
[ 0.475][v][cplayer] playback restart complete
[ 0.476][v][lavf] select track 1
[ 0.511][v][lavf] refresh seek to -0.916583
[ 0.511][v][lavf] execute seek (to -0.916583 flags 32)
[ 0.511][v][lavf] seek done
[ 0.511][d][cache] request seek: 139179440 <= to=3175033 (cur=149419440) <= 159659440
[ 0.511][v][cache] Dropping cache at pos 3175033, cached range: 139179440-159659440.
[ 0.511][v][cache] Seeking underlying stream: 159659440 -> 3175033
[ 0.512][v][ad] Codec list:
[ 0.512][v][ad] aac - AAC (Advanced Audio Coding)
[ 0.512][v][ad] aac_fixed (aac) - AAC (Advanced Audio Coding)
[ 0.512][v][ad] Opening decoder aac
[ 0.512][v][ad] Requesting 1 threads for decoding.
[ 0.512][v][ad] Selected codec: aac (AAC (Advanced Audio Coding))
[ 0.512][d][user_filter_wrapper] Setting option 'tospdif' = 'yes' (flags = 0)
[ 0.512][d][user_filter_wrapper] Setting option 'bitrate' = '384' (flags = 0)
[ 0.512][d][user_filter_wrapper] Setting option 'minch' = '2' (flags = 0)
[ 0.512][v][af] User filter list:
[ 0.512][v][af] lavcac3enc (lavcac3enc.00)
[ 0.512][i][cplayer] Track switched:
[ 0.512][i][cplayer] (+) Video --vid=1 (*) (h264 1920x800 23.976fps)
[ 0.512][i][cplayer] (+) Audio --aid=1 --alang=eng (*) (aac 2ch 48000Hz)
[ 0.512][v][cplayer] Set property: aid=1 -> 1
[ 0.513][v][af] [in] 48000Hz stereo 2ch floatp
[ 0.513][v][af] [lavcac3enc] 48000Hz stereo 2ch floatp
[ 0.513][v][af] [userspeed] 48000Hz stereo 2ch spdif-ac3
[ 0.513][v][af] [userspeed] (disabled)
[ 0.513][v][af] [convert] 48000Hz stereo 2ch spdif-ac3
[ 0.513][v][ao] Trying audio driver 'wasapi'
[ 0.513][v][ao/wasapi] requested format: 48000 Hz, stereo channels, spdif-ac3
[ 0.513][d][ao/wasapi] Init wasapi
[ 0.513][d][ao/wasapi] Find device ''
[ 0.516][v][ao/wasapi] No device specified. Selecting default.
[ 0.521][v][ao/wasapi] Selecting device '{bcad7374-3085-42e2-a741-ae21c5192b08}' (6 - SONY AVAMP (AMD High Definition Audio Device))
[ 0.521][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{bcad7374-3085-42e2-a741-ae21c5192b08}
[ 0.529][d][ao/wasapi] Init wasapi thread
[ 0.529][d][ao/wasapi] Activating pAudioClient interface
[ 0.529][d][ao/wasapi] Probing formats
[ 0.530][v][ao/wasapi] Trying stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) -> unsupported
[ 0.530][d][ao/wasapi] Thread shutdown
[ 0.530][d][ao/wasapi] Uninit wasapi
[ 0.530][d][ao/wasapi] Thread uninit done
[ 0.530][d][ao/wasapi] Thread return
[ 0.531][d][ao/wasapi] Uninit wasapi done
[ 0.531][v][ao] Trying audio driver 'openal'
[ 0.531][v][ao/openal] requested format: 48000 Hz, stereo channels, spdif-ac3
[ 0.550][f][ao/openal] Can't find appropriate sample format.
[ 0.555][e][ao] Failed to initialize audio driver 'openal'
[ 0.555][v][cplayer] Falling back to PCM output.
[ 0.556][v][ad] Codec list:
[ 0.556][v][ad] aac - AAC (Advanced Audio Coding)
[ 0.556][v][ad] aac_fixed (aac) - AAC (Advanced Audio Coding)
[ 0.556][v][ad] Opening decoder aac
[ 0.556][v][ad] Requesting 1 threads for decoding.
[ 0.556][v][ad] Selected codec: aac (AAC (Advanced Audio Coding))
[ 0.557][i][cplayer] Track switched:
[ 0.557][i][cplayer] (+) Video --vid=1 (*) (h264 1920x800 23.976fps)
[ 0.557][i][cplayer] (+) Audio --aid=1 --alang=eng (*) (aac 2ch 48000Hz)
[ 0.557][v][cplayer] Set property: sid="no" -> 1
[ 0.557][d][cplayer] Run command: seek, flags=0, args=[441.000000, absolute, exact]
[ 0.557][v][lavf] queuing seek to 441.000000
[ 0.557][v][lavf] cached range 0: 10.510500 <-> 147.147000 (bof=0, eof=0)
[ 0.557][v][lavf] execute seek (to 441.000000 flags 32)
[ 0.557][v][lavf] seek done
[ 0.558][v][cplayer] hr-seek, skipping to 441.000000
[ 0.558][d][cache] request seek: 29422201 <= to=150707509 (cur=40239326) <= 49836665
[ 0.558][v][cache] Dropping cache at pos 150707509, cached range: 29422201-49902201.
[ 0.558][v][cache] Seeking underlying stream: 49902201 -> 150707509
[ 0.558][d][cache] request seek: 150707509 <= to=150804038 (cur=150740277) <= 150773045
[ 0.558][v][af] [in] 48000Hz stereo 2ch floatp
[ 0.558][v][af] [lavcac3enc] 48000Hz stereo 2ch floatp
[ 0.558][v][af] [userspeed] 48000Hz stereo 2ch spdif-ac3
[ 0.558][v][af] [convert] 48000Hz stereo 2ch spdif-ac3
[ 0.558][v][ao] Trying audio driver 'wasapi'
[ 0.558][v][ao/wasapi] requested format: 48000 Hz, stereo channels, spdif-ac3
[ 0.558][d][ao/wasapi] Init wasapi
[ 0.558][d][ao/wasapi] Find device ''
[ 0.561][v][ao/wasapi] No device specified. Selecting default.
[ 0.564][v][ao/wasapi] Selecting device '{bcad7374-3085-42e2-a741-ae21c5192b08}' (6 - SONY AVAMP (AMD High Definition Audio Device))
[ 0.564][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{bcad7374-3085-42e2-a741-ae21c5192b08}
[ 0.570][d][ao/wasapi] Init wasapi thread
[ 0.570][d][ao/wasapi] Activating pAudioClient interface
[ 0.570][d][ao/wasapi] Probing formats
[ 0.571][v][ao/wasapi] Trying stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) -> unsupported
[ 0.571][d][ao/wasapi] Thread shutdown
[ 0.571][d][ao/wasapi] Uninit wasapi
[ 0.571][d][ao/wasapi] Thread uninit done
[ 0.571][d][ao/wasapi] Thread return
[ 0.571][d][ao/wasapi] Uninit wasapi done
[ 0.571][v][ao] Trying audio driver 'openal'
[ 0.571][v][ao/openal] requested format: 48000 Hz, stereo channels, spdif-ac3
[ 0.587][f][ao/openal] Can't find appropriate sample format.
[ 0.595][e][ao] Failed to initialize audio driver 'openal'
[ 0.595][e][cplayer] Could not open/initialize audio device -> no sound.
[ 0.595][v][ad] Uninit decoder.
[ 0.596][v][lavf] deselect track 1
[ 0.601][i][cplayer] Audio: no audio
[ 0.602][d][cache] request seek: 174124899 <= to=184434597 (cur=184430435) <= 194539363
[ 0.602][v][vd] Pixel formats supported by decoder: cuda dxva2_vld d3d11va_vld d3d11 yuv420p
[ 0.602][v][vd] Codec profile: High (0x64)
[ 0.602][v][vd] Requesting pixfmt 'd3d11' from decoder.
[ 0.602][d][ffmpeg/video] h264: Decoder GUIDs reported as supported:
[ 0.602][d][ffmpeg/video] h264: {ee27417f-5e28-4e65-beea-1d26b508adc9} 103 106
[ 0.602][d][ffmpeg/video] h264: {bf22ad00-03ea-4690-8077-473346209b7e} 103 106
[ 0.602][d][ffmpeg/video] h264: {1b81be68-a0c7-11d3-b984-00c04f2e73c5} 103 106
[ 0.602][d][ffmpeg/video] h264: {4245f676-2bbc-4166-a0bb-54e7b849c380} 103 106
[ 0.602][d][ffmpeg/video] h264: {6719b6fb-5cad-4acb-b00a-f3bfdec38727} 103 106
[ 0.602][d][ffmpeg/video] h264: {9901ccd3-ca12-4b7e-867a-e2223d9255c3} 103 106
[ 0.602][d][cache] request seek: 174583651 <= to=185160228 (cur=185155493) <= 194998115
[ 0.602][d][ffmpeg/video] h264: {d79be8da-0cf1-4c81-b82a-69a4e236f43d} 103 106
[ 0.602][d][ffmpeg/video] h264: {f9aaccbb-c2b6-4cfc-8779-5707b1760552} 103 106
[ 0.602][d][ffmpeg/video] h264: {1b81bea3-a0c7-11d3-b984-00c04f2e73c5} 103 106
[ 0.602][d][ffmpeg/video] h264: {ca15d19a-2b48-43d6-979e-7a6e9c802ff8} 103 106
[ 0.602][d][ffmpeg/video] h264: {7c74adc6-e2ba-4ade-86de-30beabb40cc1} 103 106
[ 0.602][d][ffmpeg/video] h264: {ed418a9f-010d-4eda-9ae3-9a65358d8d2e} 103 106
[ 0.602][d][ffmpeg/video] h264: {1b81bea2-a0c7-11d3-b984-00c04f2e73c5} 103 106
[ 0.603][d][ffmpeg/video] h264: {1b81be94-a0c7-11d3-b984-00c04f2e73c5} 103 106
[ 0.603][d][ffmpeg/video] h264: {103473e4-10ea-11df-9a92-2ba055d89593} 103 106
[ 0.603][d][ffmpeg/video] h264: {84ad67f6-4c21-419a-9f0b-24f0578906c1} 103 106
[ 0.603][d][cache] request seek: 175239011 <= to=185877980 (cur=185873355) <= 195653475
[ 0.603][d][ffmpeg/video] h264: {725ad240-786c-471e-ad3c-38f739936517} 103 106
[ 0.603][d][ffmpeg/video] h264: {95664ff5-9e03-4c74-bb4f-9178d6035e58} 103 106
[ 0.603][d][ffmpeg/video] h264: {603a4756-a864-4f91-bb62-2c935b7a1391} 103 106
[ 0.603][d][ffmpeg/video] h264: Reinit context to 1920x800, pix_fmt: d3d11
[ 0.604][d][cache] request seek: 176353123 <= to=187633983 (cur=187629832) <= 196767587
[ 0.604][d][cache] request seek: 176418659 <= to=187770405 (cur=187765055) <= 196833123
[ 0.606][d][cache] request seek: 178450275 <= to=190954264 (cur=190949821) <= 198864739
[ 0.611][v][vd] Decoder format: 1920x800 [0:1] d3d11[nv12] bt.709/bt.709/auto/limited/auto CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000)
[ 0.611][d][cache] request seek: 184020835 <= to=196092651 (cur=196087741) <= 204435299
[ 0.612][d][cache] request seek: 184676195 <= to=196621621 (cur=196616939) <= 205090659
[ 0.618][d][cache] request seek: 189984611 <= to=202917430 (cur=202912189) <= 210399075
[ 0.619][d][cache] request seek: 190836579 <= to=204007535 (cur=204002054) <= 211251043
[ 0.620][d][cache] request seek: 191557475 <= to=205048972 (cur=205043810) <= 211971939
[ 0.621][d][cache] request seek: 192585013 <= to=206503757 (cur=206498699) <= 212999477
[ 0.621][d][cache] request seek: 192716085 <= to=206715727 (cur=206710312) <= 213130549
[ 0.627][d][cache] request seek: 197893429 <= to=213007066 (cur=213001900) <= 218307893
[ 0.634][d][cache] request seek: 207002933 <= to=224252727 (cur=224248084) <= 227417397
[ 0.636][d][cache] request seek: 209100085 <= to=226377276 (cur=226372113) <= 229514549
[ 0.637][d][cache] request seek: 210083125 <= to=227430276 (cur=227425852) <= 230497589
[ 0.638][d][cache] request seek: 211328309 <= to=229010184 (cur=229004670) <= 231742773
[ 0.640][d][cache] request seek: 212409653 <= to=231831988 (cur=231826724) <= 232824117
[ 0.640][d][cache] request seek: 212409653 <= to=232489805 (cur=232485351) <= 232824117
[ 0.642][d][cache] request seek: 213785909 <= to=234112564 (cur=234107025) <= 234200373
[ 0.644][d][cache] request seek: 215751989 <= to=236145625 (cur=236140238) <= 236166453
[ 0.644][d][cache] request seek: 216145205 <= to=236444728 (cur=236440537) <= 236559669
[ 0.648][d][cache] request seek: 220339509 <= to=240748517 (cur=240743094) <= 240753973
[ 0.648][d][cache] request seek: 220732725 <= to=241120236 (cur=241114596) <= 241147189
[ 0.649][d][cache] request seek: 221257013 <= to=241657637 (cur=241652176) <= 241671477
[ 0.650][d][cache] request seek: 222371125 <= to=242692019 (cur=242687285) <= 242785589
[ 0.651][d][cache] request seek: 223354165 <= to=243707591 (cur=243703093) <= 243768629
[ 0.659][d][cache] request seek: 232201525 <= to=252554615 (cur=252550453) <= 252615989
[ 0.663][d][cache] request seek: 236756277 <= to=257175954 (cur=257170741) <= 257170741
[ 0.670][d][cache] request seek: 244292917 <= to=264712142 (cur=264707381) <= 264707381
[ 0.670][d][cache] request seek: 244817205 <= to=265237110 (cur=265231669) <= 265231669
[ 0.671][d][cache] request seek: 245865781 <= to=266251665 (cur=266247477) <= 266280245
[ 0.672][d][cache] request seek: 246652213 <= to=267070996 (cur=267066677) <= 267066677
[ 0.673][d][cache] request seek: 248094005 <= to=268513688 (cur=268508469) <= 268508469
[ 0.676][d][cache] request seek: 251632949 <= to=271888573 (cur=271883573) <= 272047413
[ 0.680][d][cache] request seek: 256843061 <= to=277234396 (cur=277229207) <= 277257525
[ 0.681][d][cache] request seek: 257957173 <= to=278347580 (cur=278342388) <= 278371637
[ 0.682][d][cache] request seek: 258874677 <= to=279228596 (cur=279223605) <= 279289141
[ 0.690][d][cache] request seek: 268049717 <= to=288436857 (cur=288431413) <= 288464181
[ 0.690][d][cache] request seek: 268442933 <= to=288731313 (cur=288726325) <= 288857397
[ 0.691][d][cache] request seek: 269950261 <= to=290336307 (cur=290331957) <= 290364725
[ 0.694][d][cache] request seek: 273161525 <= to=293515889 (cur=293510453) <= 293575989
[ 0.700][d][cache] request seek: 280599861 <= to=300953612 (cur=300948789) <= 301014325
[ 0.700][d][cache] request seek: 280730933 <= to=301116996 (cur=301112629) <= 301145397
[ 0.706][d][cache] request seek: 288070965 <= to=308465394 (cur=308459883) <= 308485429
[ 0.783][d][cache] request seek: 300145973 <= to=310390731 (cur=310385973) <= 320625973
[ 0.995][v][cplayer] first video frame after restart shown
[ 0.995][v][cplayer] playback restart complete
[ 5.291][d][cache] request seek: 301767080 <= to=312012060 (cur=312007080) <= 322247080
[ 9.764][d][cplayer] Run command: cycle, flags=0, args=[pause, (NULL)]
[ 9.764][v][cplayer] Set property: pause -> 1
[ 11.797][d][cplayer] Run command: quit, flags=9, args=[0]
[ 11.797][v][cplayer] EOF code: 5
[ 11.797][v][vd] Uninit decoder.
[ 11.832][v][ipc_0] Client disconnected
[ 11.832][v][ipc_0] Exiting...
[ 11.853][v][cache] Terminating cache...
[ 11.853][v][cache] Cache exiting...
[ 11.855][v][cplayer] finished playback, success (reason 3)
[ 11.856][i][cplayer]
[ 11.856][i][cplayer] Exiting... (Quit)
[ 11.856][v][refreshrate] Exiting...
[ 11.856][v][ytdl_hook] Exiting...
[ 11.856][v][stats] Exiting...
[ 11.881][d][vo/gpu] flushing shader cache
[ 11.881][v][vo/gpu/win32] uninit
Guest asrequested
Turn off exclusive mode
Guest asrequested
Or you can try using this, instead:
af=surround:chl_out=5.1
I didn't have exclusive mode enabled, I'm not sure why it said that... But the line you posted seems to work, thanks!
Will this affect anything that has a proper 5.1 (or higher) track? or does it leave that alone?
I'm not an audiophile by any means, but I would obviously like everything to sound as good as possible (within reason).
EDIT: After looking through a handful of titles, I've got a mixture of AAC Stereo, AAC 5.1, DTS 5.1 and Dolby Digital 5.1 (I'm sure there are others as well); I just want to make sure I'm not losing quality on some of the titles that already have 5.1 audio by using the mpv code to re-encode the stereo tracks.
Edited by pmac
Guest asrequested
That's a bit vague, but I think you mean bitstreamed audio? No, it won't affect the audio you have chosen to pass through, in the Theater settings. What it does is upmix any non-bitreamed stereo audio, to 5.1 PCM
Edited by Doofus
Okay, that clears it up a bit for me (I think, lol). Thank you. Since I don't know anything about fiddling with mpv, I just want to make sure I'm getting the most out of it :)
I just tested an AAC 5.1 Movie with and without that filter, and there's a quite noticeable difference in sound quality. With the filter it's much quieter and is missing a lot of the sound effects in the rear channels compared to having the filter off. I have passthrough enabled for all formats, and they're all compatible with my receiver.
Guest asrequested
Post a screenshot of all of your audio settings in Theater.
Guest asrequested
Put this in your mpv.conf, play one video and post your log
af=lavcac3enc=yes:384:2
audio-exclusive=yes
