CBers 7554 Posted June 2, 2015 Author Posted June 2, 2015 Post your problems on the Sonarr forums, as there is more expertise there. https://forums.sonarr.tv
CBers 7554 Posted June 2, 2015 Author Posted June 2, 2015 (edited) @@Lee & @@Talos Found a couple of posts, one on Sonarr forums and one on Reddit, which is linked to from the Sonarr post. https://forums.sonarr.tv/t/sonarr-not-performing-check-for-finished-downloads/5828 http://www.reddit.com/r/usenet/comments/386fol/sonarr_no_longer_post_processing_downloads_all_of/ . Edited June 2, 2015 by CBers
Lee 212 Posted June 3, 2015 Posted June 3, 2015 I'm getting divorced atm. So I'm at my mothers until the ex-wife buggers off .. Impossible for me to look into it until then! F*cking solicitors are taking ages....
Overseer 66 Posted June 4, 2015 Posted June 4, 2015 Latest post today from one of the team members. Some good news. Tnx to a memory dump a user provided us we've been put on the right trail.markus already committed a fix for the problem on develop, but we weren't sure yet if that was the cause. This was a typical Murphy scenario.Tnx to a tiny bug, if 3 specific things happened at the same time, Sonarr would end up with a stale cached command state, preventing that command from ever running again until the app got restarted. Once we figured out how those 3 things played a role, it became much easier to get it to reproduce.So the fix markus applied earlier is now confirmed with a probability of >95%, if it continues to work we'll cherrypick the fixes to master tomorrow, maybe a bit earlier. Thank you for your patience. 4
