Hyp3rD 10 Posted February 16, 2020 Author Posted February 16, 2020 (edited) And you can reproduce my bug? So, it’s not only the version of my server that cause this? Can I or can you find a way to show it to softworkz? For a access to my server, I don’t ask a tech support of my OS or something like that, when I propose it, it was just a access to the Emby web app just to permit to watch what the bug does... Edited February 16, 2020 by Hyp3rD
Luke 42204 Posted February 16, 2020 Posted February 16, 2020 I had trouble resuming that file in Chrome, yes.
Hyp3rD 10 Posted February 16, 2020 Author Posted February 16, 2020 Good, how can we help softworkz to see the problem?
Luke 42204 Posted February 16, 2020 Posted February 16, 2020 @@softworkz i tested with the french audio track selected, subtitles off, and resuming at 21:18.
softworkz 5129 Posted February 16, 2020 Posted February 16, 2020 @@softworkz i tested with the french audio track selected, subtitles off, and resuming at 21:18. @@Luke Works fine for me. I tried with hw acceeleration off as the original log didn't involve hwa. Did you test the same video that I did? I got the one without subtitles:
Hyp3rD 10 Posted February 16, 2020 Author Posted February 16, 2020 It’s probably more easy to reproduce the bug with the file that I have just send you in PM, but Luke can confirm the file that he use
Hyp3rD 10 Posted February 16, 2020 Author Posted February 16, 2020 @@Luke S03E17? If it’s this one, you can check the last PM softworkz
softworkz 5129 Posted February 17, 2020 Posted February 17, 2020 I tried with the other file now and it worked fine. No problem with resuming: @@Hyp3rD - I know why it fails in your case. As mentioned, there's a known bug related to VTT subtitles that has been fixed in the beta channel. It's not only a guess: I can see the bug happening in your logfile. @@Luke - The only part of the story that I can't explain is why you say you can reproduce. I'm afraid, but I'd need to see a log file from your test to understand what's happening at your side.
softworkz 5129 Posted February 17, 2020 Posted February 17, 2020 @@Luke - The only part of the story that I can't explain is why you say you can reproduce. I'm afraid, but I'd need to see a log file from your test to understand what's happening at your side. Maybe the ffmpeg didn't get updated in the build output folder..?
Hyp3rD 10 Posted February 17, 2020 Author Posted February 17, 2020 (edited) Ok, I trust you, I will wait the update with impatiently The only part that afraid me is the file with no sub that do the same bug (First PM). But, if you can’t reproduce it, I will hope that is the ffmpeg update that correct this on your side... If I want to give a try to the beta, I use the backup plugin, it’s just the restore part that afraid me Edit: It’s seem that I can’t use backup plugin... I think that I have not the choice to wait for the moment... Edited February 17, 2020 by Hyp3rD
softworkz 5129 Posted February 17, 2020 Posted February 17, 2020 @Hyp3rD - why not try the portable install of the beta? You need to shut down your regular Emby Server and extract the portable version into a folder of your choosing (totally separate from your regular Emby installation). This is the link to the portable beta: https://github.com/MediaBrowser/Emby.Releases/releases/download/4.4.0.14/embyserver-win-x64-4.4.0.14.7z Instructions for the portable installation: https://emby.media/windows-server.html Since this is not an upgrade, you will need to set this up from scratch, but all you need to test this is to add a library with the test files. (to make sure that the beta doesn't interfere with your regular media folders, you could even just copy the files you want to test to another location, and use this location for the library. This way, you can be sure that your regular installation remains absolutely untouched.
Hyp3rD 10 Posted February 18, 2020 Author Posted February 18, 2020 Hello @@softworkz,First, very good idea, I did not even remember that there was a portable version, shame on me ...Second, I tried version 4.4.0.15, and the bug is still there, but less that before, maybe 1/3.Here is the log of the ffmpeg. ffmpeg-transcode-b9b989dc-866e-4898-944b-ee69e0967407_1.txt
softworkz 5129 Posted February 18, 2020 Posted February 18, 2020 So, with this log it simply does not start playing in Chrome desktop browser?
softworkz 5129 Posted February 18, 2020 Posted February 18, 2020 I've just tried this with your video file in a way that I got almost the exact same ffmpeg log as you, and in my case it started playing without problem. You have subtitles set to off when trying to resume, right?
Hyp3rD 10 Posted February 18, 2020 Author Posted February 18, 2020 Yes for the 2 questions, Chrome and sub off.
Hyp3rD 10 Posted February 18, 2020 Author Posted February 18, 2020 Do you need the server or browser log?
softworkz 5129 Posted February 18, 2020 Posted February 18, 2020 I think I got a hook on it now. Could you please set the x264 encoding preset to 'slower' and retry?
Hyp3rD 10 Posted February 18, 2020 Author Posted February 18, 2020 I have set Auto to slower, and sadly, same result at the first try...
Hyp3rD 10 Posted February 18, 2020 Author Posted February 18, 2020 If it's can help... localhost-1581987698160.log embyserver.txt ffmpeg-transcode-7a11e2ce-0cb3-4261-9f1e-555cad70d9f2_1.txt
Hyp3rD 10 Posted February 19, 2020 Author Posted February 19, 2020 Do you have enough informations @@softworkz? I’m there if I can help. Have a nice day!
Hicko17 1 Posted February 19, 2020 Posted February 19, 2020 You guys may of already tested this but I can confirm that with the current stable version of Emby, resume playback works with Edge, mobile app and Windows Theater. Chrome is a no go at the moment. Edge however, does not display subtitles, no big deal for me as I don't use Edge as my default browser. Thanks for the great work.
softworkz 5129 Posted February 19, 2020 Posted February 19, 2020 Do you have enough informations @@softworkz? I’m there if I can help. Have a nice day! I can actually reproduce now and I spent a long time on this. Whether resume works or not depends on the point-in-time to resume. The video has a long keyframe interval (10s) and the segments aren't sliced as they're supposed to be. But why it happens here and not in other cases - I can't say yet. About how many files are we talking about here, that expose this kind of problem (with the latest beta .15) ?
Hyp3rD 10 Posted February 19, 2020 Author Posted February 19, 2020 For now, I can say practically the entire season. I should made more test to be more accurate. What is strange is that in the version 4.2 I never had any problems... When I will be at home, I will test it, do you want a specific procedure or configuration? @@softworkz
