Luke 42204 Posted February 15, 2020 Posted February 15, 2020 did you make sure the problem also happens with the sample?
Hyp3rD 10 Posted February 15, 2020 Author Posted February 15, 2020 It's should, but I have send you a another one in your PM that is the file that is show in the log on the #6 reply on the forum, just in case...
Hyp3rD 10 Posted February 15, 2020 Author Posted February 15, 2020 (edited) I have made some tests, and I don't know if it's just a fluke, but on Edge 18, it seems to work very well compared to Edge 80 beta, Firefox 73 and Chrome 79 that does'nt resume playback... Edited February 15, 2020 by Hyp3rD
Luke 42204 Posted February 15, 2020 Posted February 15, 2020 Yes i can reproduce with your latest sample. I've added @@softworkz so that he can take a look. Thanks.
Hyp3rD 10 Posted February 15, 2020 Author Posted February 15, 2020 The link was valid just for 1 download, do you want that I publish it a another time or you will?
Luke 42204 Posted February 15, 2020 Posted February 15, 2020 If you could that would be great, thanks.
Hyp3rD 10 Posted February 15, 2020 Author Posted February 15, 2020 Ok, but it will be valid only 24h, the limit of firefox send... And finally, Edge 18 seem to make the same thing after some retry/tests...
softworkz 5129 Posted February 15, 2020 Posted February 15, 2020 Hyp3rD @Luke -. This is the well-known vtt subtitle problem. It is fixed for Windows since beta 4.4.0.12 and for Linux since beta 4.4.0.14
Hyp3rD 10 Posted February 15, 2020 Author Posted February 15, 2020 @@softworkz It's made the same thing with a video file that does'nt have subtitle, check the logs in this thread...
softworkz 5129 Posted February 15, 2020 Posted February 15, 2020 Yes i can reproduce with your latest sample. I've added @@softworkz so that he can take a look. Thanks. Does it reproduce with the latest beta as well? @@Hyp3rD - Is it always about 10bit source videos?
Hyp3rD 10 Posted February 15, 2020 Author Posted February 15, 2020 I don’t have tested this on the beta, so I don’t know. For the source, it’s a good question, but I thing that is possible, it’s my primary template since a long time...
softworkz 5129 Posted February 15, 2020 Posted February 15, 2020 What kind of template are you referring to?
Hyp3rD 10 Posted February 15, 2020 Author Posted February 15, 2020 CRF22, PROFILE:MAIN10, LEVEL4.1, DEPHT:10BITS, HE-AAC 0.30 The most part of my library have this template...
softworkz 5129 Posted February 15, 2020 Posted February 15, 2020 So you're manually converting all media using a 3rd party tool before adding to the Emby library?
Hyp3rD 10 Posted February 15, 2020 Author Posted February 15, 2020 @@softworkz Do you need a access to my server for your test, or you have everything that you need?
Luke 42204 Posted February 15, 2020 Posted February 15, 2020 I think he has everything he needs. Thanks for the help.
softworkz 5129 Posted February 15, 2020 Posted February 15, 2020 Yes i can reproduce with your latest sample. I've added @@softworkz so that he can take a look. Thanks. I'm unable to reproduce with the sample (S01E01). I can play, skip, stop and resume without problems.. @@Luke - How did you reproduce it?
softworkz 5129 Posted February 15, 2020 Posted February 15, 2020 Works fine for me. I tried with hw acceeleration off as the original log didn't involve hwa. Did you test the same video that I did? I got the one without subtitles:
Hyp3rD 10 Posted February 15, 2020 Author Posted February 15, 2020 (edited) @@softworkz This is the example that you can find in the first message of the PM, it this sample, but with the log of Chrome. The ffmpeg is the #10 on this forum... As you can see, it's seem to start something, but not the video on the player... Your test is on 4.3.1 or 4.4.14 ? It's very weird, I have test it on 3 computers, on local lan and in remote with 4.3.1... Firefox, Chrome and Edge... Edited February 15, 2020 by Hyp3rD
softworkz 5129 Posted February 15, 2020 Posted February 15, 2020 We might be facing different issues here. The excessive vtt subtitles generation is a known problem that is fixed in the current beta. Currently, we're testing in the beta branch only. The next release is imminent and there won't be any fixes made for the 4.3.x version range. Migrating to beta and going back to an earlier release version afterwards is not recommended and likely to cause problems. But for a quick test, you can always do a backup of all library and configuration data, update to beta, do some testing and possibly return to the release build by restoring the saved data.
Hyp3rD 10 Posted February 15, 2020 Author Posted February 15, 2020 I will check what I will do, but if you want to compare, my offer to create a temp account on my server is still there, I admit that i'm curious if you will have the same result on mine...
softworkz 5129 Posted February 15, 2020 Posted February 15, 2020 I will check what I will do, but if you want to compare, my offer to create a temp account on my server is still there, I admit that i'm curious if you will have the same result on mine... You mean an Emby server account or an administrative OS account? Either way I'm afraid, I don't have enough time for this. Why don't you install 4.4.14 yourself?
Hyp3rD 10 Posted February 16, 2020 Author Posted February 16, 2020 I'm afraid of scrapping my setup ... And you @@Luke, you tried with which version of the server?
