Happy2Play 9806 Posted February 14, 2020 Posted February 14, 2020 I am out of ideas. Only other thing I could suggest is making a copy of the database and using something like DB Browser for SQLite to look at the MediaItems table to see if there are rogue Spider-Man entries. Also that last log does not show the movies being removed from the database, unless those are only shown in Debug logging.
Hyp3rD 10 Posted February 14, 2020 Author Posted February 14, 2020 I can try, can you just point me the right file that I have to change and some indications for the SQL Browser? Thanks!
Solution Happy2Play 9806 Posted February 14, 2020 Solution Posted February 14, 2020 I can try, can you just point me the right file that I have to change and some indications for the SQL Browser? Thanks! Ensure you only work with a copy of the database, you may have to close Emby to make a copy. C:\Users\nas\AppData\Roaming\Emby-Server\programdata\data\library.db 1
Luke 42216 Posted February 14, 2020 Posted February 14, 2020 I thought it was the same problem as the other thread, isn't that the answer?
Happy2Play 9806 Posted February 14, 2020 Posted February 14, 2020 (edited) I thought it was the same problem as the other thread, isn't that the answer? I would think so but it would appear the user is not getting the updated data or it is not getting updated in Emby. 2020-02-13 18:05:39.789 Info Auto Box Sets: Verified set 556 as Spider-Man Collection - creating... 2020-02-13 18:05:39.834 Info Auto Box Sets: Verified set 531241 as Spider-Man Collection - creating... The urls show the new info. Edited February 14, 2020 by Happy2Play
Luke 42216 Posted February 14, 2020 Posted February 14, 2020 Did you wait 24 hours until after you updated movie db?
Luke 42216 Posted February 14, 2020 Posted February 14, 2020 You probably need to refresh the metadata for the movies so that they get new TMDB collection IDs.
Happy2Play 9806 Posted February 14, 2020 Posted February 14, 2020 Ah I wasn't thinking of the server cache as the direct urls where updated.
