troyhough 61 Posted February 10, 2020 Posted February 10, 2020 (edited) I figured out how to create a tuner lock. Can you please fix this? 1. Open Chrome Android Emby Web (4.3.1.35) on my Pixel 2 XL 2. Play a Live TV show and make it full screen (HDHomerun Quatro Tuner) 3. Hit the Homescreen center button to minimize (Picture in Picture) the playing TV show while you can do other things on the phone 4. Simply close the Emby show by tapping the Picture in Picture box and hit the X. TaDaaa... Tuner Lock. Edited February 10, 2020 by troyhough
Luke 42241 Posted February 11, 2020 Posted February 11, 2020 And what if you exit playback normally, how does that compare?
troyhough 61 Posted February 11, 2020 Author Posted February 11, 2020 And what if you exit playback normally, how does that compare? Clicking the X to close the window isn't normal? Can you please be more specific? Thanks
troyhough 61 Posted February 15, 2020 Author Posted February 15, 2020 Clicking the X to close the window isn't normal? Can you please be more specific? Thanks @@Luke ?
troyhough 61 Posted February 21, 2020 Author Posted February 21, 2020 I just tried it again today. After checking the HDHR status again a couple hours later, the tuner was released. I am not sure how long it took but at least it wasn't forever.
Luke 42241 Posted March 1, 2020 Posted March 1, 2020 Clicking the X to close the window isn't normal? Can you please be more specific? Thanks I mean if you use the Emby back button to stop playback. How does that compare?
troyhough 61 Posted March 3, 2020 Author Posted March 3, 2020 I mean if you use the Emby back button to stop playback. How does that compare? When watching the small box (PnP) and you click on the box, there is no back button. There is the X button, square to expand full screen, Gear, and the controls of back, pause, and forward. So the natural (normal) procedure for stopping playback would be to hit the X button.
Luke 42241 Posted March 3, 2020 Posted March 3, 2020 How about hitting back without using PiP? How does that compare?
