thrillcat 14 Posted February 10, 2020 Posted February 10, 2020 (edited) So I have a certain .mkv rip from a blu-ray in my library. For whatever reason, when playing on my Shield, if I select the 5.1 DTS HD audio track, the video appears to skip, almost as if it's trying to play a 24p track at 29.97 or something. It seems to be a steadily timed skip throughout. Switch to the DTS or Uncompressed 2.0 track and it plays fine. It does the same thing in Plex on the Shield. It plays fine in Plex and Infuse on the AppleTV. It's not a bandwidth thing, as I am hardwired to the network, and have zero problem playing any other content - UHD, HD, DTSX, DTSHDMA, etc., nothing else seems to demonstrate this issue. Is there anything in the file specs that looks odd? I didn't see anything. It's almost like the DTS-HD 5.1 track is looking for a 29.97 video file to lock to, while the other two are fine with the 23.98 track, and the Shield is the only device that can't handle it. Log attached, looks like playback attempts were around 20:53:57.890. Media Info Video Title1080p H264 CodecH264 AVCYes ProfileHigh Level41 Resolution1920x1080 Aspect ratio16:9 AnamorphicNo InterlacedNo Framerate23.976 Bitrate37,908 kbps Color primariesbt709 Color spacebt709 Color transferbt709 Bit depth8 bit Pixel formatyuv420p Ref frames1 NAL4 Audio Title English PCM_S24LE 2 ch (Default) LanguageEnglish CodecPCM_S24LE Channels2 ch Bitrate4,608 kbps Sample rate96,000 Hz Bit depth24 bit DefaultYes Audio Title English DTS 5.1 LanguageEnglish CodecDTS ProfileDTS-HD MA Layout5.1 Channels6 ch Sample rate96,000 Hz Bit depth24 bit DefaultNo Audio Title English DTS 5.1 LanguageEnglish CodecDTS ProfileDTS Layout5.1 Channels6 ch Bitrate1,536 kbps Sample rate48,000 Hz DefaultNo Container mkv PathE:\Concert Films\Pink_Floyd_The_Later_Years_Delicate_Sound_of_Thunder\BD_DISC7_t00.mkv Size31303 MB embyserver-63716889599.txt Edited February 10, 2020 by thrillcat
thrillcat 14 Posted February 10, 2020 Author Posted February 10, 2020 Was there an ffmpeg log as well? I didn’t see one. Will look again tonight. Sent from my iPhone using Tapatalk
FrostByte 5454 Posted February 10, 2020 Posted February 10, 2020 The sample rate is a little higher than normal. All of my DTS including DTS-HD is all 48,000
thrillcat 14 Posted February 10, 2020 Author Posted February 10, 2020 (edited) The sample rate is a little higher than normal. All of my DTS including DTS-HD is all 48,000Yeah, it’s a hi-res audio track, and doing a little research it seems like it’s definitely just a shortcoming of the Shield. It doesn’t play surround hi-res. Perhaps Emby could flag these files when playback on a Shield is attempted and transcode to DTSHDMA at 48, so we’re at least not forced into the lossy DTS if we want surround? Sent from my iPhone using Tapatalk Edited February 10, 2020 by thrillcat
Luke 42246 Posted February 11, 2020 Posted February 11, 2020 Does that other server convert the audio when that track is selected?
thrillcat 14 Posted February 11, 2020 Author Posted February 11, 2020 Does that other server convert the audio when that track is selected? The other server on Shield has the same stutter, direct play. On AppleTV, every app and server coverts to 48k PCM. Sent from my iPhone using Tapatalk
Luke 42246 Posted February 11, 2020 Posted February 11, 2020 Yea it's a difficult situation, where probably it may technically support it but in this case it's just not playing it well. We'll see what @@ebr thinks. Thanks.
ebr 16338 Posted February 11, 2020 Posted February 11, 2020 We can't transcode to a downsampled DTS HD. If the app can see that the sample rate is over spec, then we'd have to transcode to DD.
